My build worked perfectly. I can run npm run build with no problems at all, but whenever I try and deploy my Next.js project to Netlify I get an odd error. I added simple code today. I think I updated next js but this is it…
Deploy summary
* **Plugin "@netlify/plugin-nextjs" failed**
Error: The directory "/opt/build/repo/build" does not contain a Next.js production build. Perhaps the build command was not run, or you specified the wrong publish directory. In most cases it should be set to ".next", unless you have chosen a custom "distDir" in your Next config. If you are using "next export" then you should set the environment variable NETLIFY_NEXT_PLUGIN_SKIP to "true".
Deploy log
7:40:43 PM: Build ready to start
7:40:45 PM: build-image version: d2c6dbeac570350a387d832f64bc980dc964ad65 (focal)
7:40:45 PM: build-image tag: v4.8.0
7:40:45 PM: buildbot version: d7330f24833f29d0263d28116347ab83094a2561
7:40:45 PM: Fetching cached dependencies
7:40:45 PM: Failed to fetch cache, continuing with build
7:40:45 PM: Starting to prepare the repo for build
7:40:45 PM: No cached dependencies found. Cloning fresh repo
7:40:45 PM: git clone https://github.com/alextseitlin/tatifrank
7:40:48 PM: Preparing Git Reference refs/heads/main
7:40:49 PM: Parsing package.json dependencies
7:40:50 PM: Starting build script
7:40:50 PM: Installing dependencies
7:40:50 PM: Python version set to 2.7
7:40:50 PM: Downloading and installing node v16.15.1...
7:40:51 PM: Downloading https://nodejs.org/dist/v16.15.1/node-v16.15.1-linux-x64.tar.xz...
7:40:51 PM: Computing checksum with sha256sum
7:40:51 PM: Checksums matched!
7:40:54 PM: Now using node v16.15.1 (npm v8.11.0)
7:40:54 PM: Started restoring cached build plugins
7:40:54 PM: Finished restoring cached build plugins
7:40:54 PM: Attempting ruby version 2.7.2, read from environment
7:40:55 PM: Using ruby version 2.7.2
7:40:55 PM: Using PHP version 8.0
7:40:55 PM: No npm workspaces detected
7:40:55 PM: Started restoring cached node modules
7:40:55 PM: Finished restoring cached node modules
7:40:56 PM: Installing NPM modules using NPM version 8.11.0
7:40:56 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
7:40:56 PM: npm WARN config location in the cache, and they are managed by
7:40:56 PM: npm WARN config [`cacache`](http://npm.im/cacache).
7:40:57 PM: npm WARN old lockfile
7:40:57 PM: npm WARN old lockfile The package-lock.json file was created with an old version of npm,
7:40:57 PM: npm WARN old lockfile so supplemental metadata must be fetched from the registry.
7:40:57 PM: npm WARN old lockfile This is a one-time fix-up, please be patient...
7:41:04 PM: npm WARN deprecated har-validator@5.1.5: this library is no longer supported
7:41:05 PM: npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
7:41:05 PM: npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
7:41:11 PM: added 468 packages, and audited 469 packages in 15s
7:41:11 PM: 54 packages are looking for funding
7:41:11 PM: run `npm fund` for details
7:41:11 PM: 1 moderate severity vulnerability
7:41:11 PM: To address all issues (including breaking changes), run:
7:41:11 PM: npm audit fix --force
7:41:11 PM: Run `npm audit` for details.
7:41:11 PM: NPM modules installed
7:41:12 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
7:41:12 PM: npm WARN config location in the cache, and they are managed by
7:41:12 PM: npm WARN config [`cacache`](http://npm.im/cacache).
7:41:12 PM: Started restoring cached go cache
7:41:12 PM: Finished restoring cached go cache
7:41:12 PM: go version go1.16.5 linux/amd64
7:41:12 PM: Installing missing commands
7:41:12 PM: Verify run directory
7:41:13 PM:
7:41:13 PM: ────────────────────────────────────────────────────────────────
7:41:13 PM: Netlify Build
7:41:13 PM:
7:41:13 PM: ❯ Version
7:41:13 PM: @netlify/build 27.1.3
7:41:13 PM:
7:41:13 PM: ❯ Flags
7:41:13 PM: baseRelDir: true
7:41:13 PM: buildId: 62a3740b9c3445000756fb66
7:41:13 PM: deployId: 62a3740b9c3445000756fb68
7:41:13 PM:
7:41:13 PM: ❯ Current directory
7:41:13 PM: /opt/build/repo
7:41:13 PM:
7:41:13 PM: ❯ Config file
7:41:13 PM: No config file was defined: using default values.
7:41:13 PM:
7:41:13 PM: ❯ Context
7:41:13 PM: production
7:41:13 PM:
7:41:13 PM: ❯ Loading plugins
7:41:13 PM: - @netlify/plugin-nextjs@4.8.0 from Netlify app and package.json
7:41:15 PM:
7:41:15 PM: ────────────────────────────────────────────────────────────────
7:41:15 PM: 1. @netlify/plugin-nextjs (onPreBuild event)
7:41:15 PM:
7:41:15 PM: No Next.js cache to restore.
7:41:15 PM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
7:41:15 PM:
7:41:15 PM: (@netlify/plugin-nextjs onPreBuild completed in 25ms)
7:41:15 PM:
7:41:15 PM: 2. Build command from Netlify app
7:41:15 PM:
7:41:15 PM: $ npm run build
7:41:15 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
7:41:15 PM: npm WARN config location in the cache, and they are managed by
7:41:15 PM: npm WARN config [`cacache`](http://npm.im/cacache).
7:41:15 PM: > build
7:41:15 PM: > next build
7:41:15 PM: info - Loaded env from /opt/build/repo/.env
7:41:16 PM: warn - No build cache found. Please configure build caching for faster rebuilds. Read more: https://nextjs.org/docs/messages/no-cache
7:41:16 PM: info - Checking validity of types...
7:41:16 PM: warn - No ESLint configuration detected. Run next lint to begin setup
7:41:16 PM: info - Creating an optimized production build...
7:41:38 PM: info - Compiled successfully
7:41:38 PM: info - Collecting page data...
7:41:42 PM: info - Generating static pages (0/15)
7:41:42 PM: info - Generating static pages (3/15)
7:41:42 PM: info - Generating static pages (7/15)
7:41:42 PM: info - Generating static pages (11/15)
7:41:42 PM: info - Generating static pages (15/15)
7:41:42 PM: info - Finalizing page optimization...
7:41:42 PM: Page Size First Load JS
7:41:42 PM: ┌ λ / 21.4 kB 107 kB
7:41:42 PM: ├ └ css/e26ca492deb0bc43.css 1.22 kB
7:41:42 PM: ├ /_app 0 B 72.5 kB
7:41:42 PM: ├ ○ /404 2.27 kB 85 kB
7:41:42 PM: ├ └ css/0897eed4ad85b783.css 975 B
7:41:42 PM: ├ ○ /about 2.46 kB 85.2 kB
7:41:42 PM: ├ λ /api/hello 0 B 72.5 kB
7:41:42 PM: ├ ○ /contact 639 B 83.3 kB
7:41:42 PM: ├ ○ /fotografas-vilniuje 3.19 kB 85.9 kB
7:41:42 PM: ├ ○ /how-it-works 4.85 kB 87.5 kB
7:41:42 PM: ├ ○ /offerings 2.78 kB 85.5 kB
7:41:42 PM: ├ ○ /photograph-vilnius 4.75 kB 90.7 kB
7:41:42 PM: ├ ○ /portfolio 3.11 kB 85.8 kB
7:41:42 PM: ├ ○ /portfolio/template 2.79 kB 85.5 kB
7:41:42 PM: ├ ○ /privacy 4.56 kB 87.3 kB
7:41:42 PM: ├ ○ /ru/photograph-vilnius 4.94 kB 90.9 kB
7:41:42 PM: ├ ○ /success 527 B 83.2 kB
7:41:42 PM: ├ ○ /terms 4.71 kB 87.4 kB
7:41:42 PM: └ ○ /testimonials 3.68 kB 86.4 kB
7:41:42 PM: + First Load JS shared by all 72.5 kB
7:41:42 PM: ├ chunks/framework-5f4595e5518b5600.js 42 kB
7:41:42 PM: ├ chunks/main-f65e66e62fc5ca80.js 28.6 kB
7:41:42 PM: ├ chunks/pages/_app-9bb1518c22f7a3ca.js 1.03 kB
7:41:42 PM: ├ chunks/webpack-9b312e20a4e32339.js 836 B
7:41:42 PM: └ css/54ea277b8fc11f73.css 3.4 kB
7:41:42 PM: λ (Server) server-side renders at runtime (uses getInitialProps or getServerSideProps)
7:41:42 PM: ○ (Static) automatically rendered as static HTML (uses no initial props)
7:41:42 PM:
7:41:42 PM: (build.command completed in 27.7s)
7:41:42 PM:
7:41:42 PM: ────────────────────────────────────────────────────────────────
7:41:42 PM: 3. @netlify/plugin-nextjs (onBuild event)
7:41:42 PM:
7:41:42 PM:
7:41:42 PM: Plugin "@netlify/plugin-nextjs" failed
7:41:42 PM:
7:41:42 PM: Error message
7:41:42 PM: Error: The directory "/opt/build/repo/build" does not contain a Next.js production build. Perhaps the build command was not run, or you specified the wrong publish directory.
7:41:42 PM: In most cases it should be set to ".next", unless you have chosen a custom "distDir" in your Next config.
7:41:42 PM: If you are using "next export" then you should set the environment variable NETLIFY_NEXT_PLUGIN_SKIP to "true".
7:41:42 PM:
7:41:42 PM: Plugin details
7:41:42 PM: Package: @netlify/plugin-nextjs
7:41:42 PM: Version: 4.8.0
7:41:42 PM: Repository: git+https://github.com/netlify/netlify-plugin-nextjs.git
7:41:42 PM: npm link: https://www.npmjs.com/package/@netlify/plugin-nextjs
7:41:42 PM: Report issues: https://github.com/netlify/netlify-plugin-nextjs/issues
7:41:42 PM:
7:41:42 PM: Error location
7:41:42 PM: In "onBuild" event in "@netlify/plugin-nextjs" from Netlify app and package.json
7:41:42 PM: at checkNextSiteHasBuilt (/node_modules/@netlify/plugin-nextjs/lib/helpers/verification.js:72:16)
7:41:42 PM: at onBuild (/node_modules/@netlify/plugin-nextjs/lib/index.js:40:50)
7:41:42 PM:
7:41:44 PM: Creating deploy upload records
7:41:42 PM: Resolved config
7:41:42 PM: build:
7:41:42 PM: command: npm run build
7:41:42 PM: commandOrigin: ui
7:41:42 PM: environment:
7:41:45 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
7:41:42 PM: - NEXT_PRIVATE_TARGET
7:41:42 PM: publish: /opt/build/repo/build
7:41:42 PM: publishOrigin: ui
7:41:42 PM: plugins:
7:41:42 PM: - inputs: {}
7:41:42 PM: origin: ui
7:41:42 PM: package: '@netlify/plugin-nextjs'
7:41:43 PM: Caching artifacts
7:41:43 PM: Started saving node modules
7:41:43 PM: Finished saving node modules
7:41:43 PM: Started saving build plugins
7:41:43 PM: Finished saving build plugins
7:41:43 PM: Started saving pip cache
7:41:43 PM: Finished saving pip cache
7:41:43 PM: Started saving emacs cask dependencies
7:41:43 PM: Finished saving emacs cask dependencies
7:41:43 PM: Started saving maven dependencies
7:41:43 PM: Finished saving maven dependencies
7:41:43 PM: Started saving boot dependencies
7:41:43 PM: Finished saving boot dependencies
7:41:43 PM: Started saving rust rustup cache
7:41:43 PM: Finished saving rust rustup cache
7:41:43 PM: Started saving go dependencies
7:41:43 PM: Finished saving go dependencies
7:41:44 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
7:41:45 PM: Failing build: Failed to build site
7:41:45 PM: Finished processing build request in 1m0.309699334s
