Netlify site name: cozy-blancmange-762924.netlify.app/
After cloning the site locally, I experienced build errors when running npm install. Below is the error output. I can’t include the complete output because it contains links to registry.npmjs and your forum post processor precludes more then 2 links for new users. In addition to helping me with my error, can you also change settings so new users can post errors with more then 2 links?
@steveopixie go ahead and post additional context in a reply to your post so we can see more. The ability to post more than one link here will be unlocked for you pretty quickly if you continue to be active here.
Not sure if that template you’re deploying is the most up to date way to get a Hugo CMS on Netlify but I wanted to make sure you saw this page from the Netlify docs which describes what seems to be a cleaner integration. I’ve been wrong before though.
It means exactly what it says. The old flags --global and --local are deprecated in favour of --location=global or --location=local. This is an NPM thing
This is what I see running npm start
<i> [webpack-dev-server] Project is running at:
<i> [webpack-dev-server] Loopback: http://localhost:3000/
<i> [webpack-dev-server] On Your Network (IPv4): http://192.168.0.137:3000/
<i> [webpack-dev-server] On Your Network (IPv6): http://[fe80::1]:3000/
Which shows where things are running. And it does say in the README.md under Local Development
Local Development
Clone this repository, and run yarn or npm install from the new folder to install all required dependencies.
Then start the development server with yarn start or npm start.
Thanks for great support on this issue. I appreciate your help.
I just recloned the repo and ran npm install --legacy-peer-deps and got the output below. Is the an npm thing, or a hugo thing, or something specific to the template that Netlify maintains? If you are running the same command against the same cloned repo, shouldn’t we be getting similar results?
Thank you very much.
Here is the output:
npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort#browser_compatibility
npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.
npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
npm WARN deprecated mini-create-react-context@0.4.1: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
npm WARN deprecated memoize-one@4.1.0: New custom equality api does not play well with all equality helpers. Please use v5.x
npm WARN deprecated html-webpack-plugin@3.2.0: 3.x is no longer supported
npm WARN deprecated redux-devtools-extension@2.13.9: Package moved to @redux-devtools/extension.
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
npm WARN deprecated tar@2.2.2: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
npm ERR! code 1
npm ERR! path C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-sass
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node scripts/build.js
npm ERR! Building: C:\Program Files\nodejs\node.exe C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-gyp\bin\node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp verb cli [
npm ERR! gyp verb cli 'C:\\Program Files\\nodejs\\node.exe',
npm ERR! gyp verb cli 'C:\\local-work\\Netlify-Sites\\one-click-hugo-cms\\node_modules\\node-gyp\\bin\\node-gyp.js',
npm ERR! gyp verb cli 'rebuild',
npm ERR! gyp verb cli '--verbose',
npm ERR! gyp verb cli '--libsass_ext=',
npm ERR! gyp verb cli '--libsass_cflags=',
npm ERR! gyp verb cli '--libsass_ldflags=',
npm ERR! gyp verb cli '--libsass_library='
npm ERR! gyp verb cli ]
npm ERR! gyp info using node-gyp@3.8.0
npm ERR! gyp info using node@16.18.0 | win32 | x64
npm ERR! gyp verb command rebuild []
npm ERR! gyp verb command clean []
npm ERR! gyp verb clean removing "build" directory
npm ERR! gyp verb command configure []
npm ERR! gyp verb check python checking for Python executable "python2" in the PATH
npm ERR! gyp verb `which` failed Error: not found: python2
npm ERR! gyp verb `which` failed at getNotFoundError (C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-gyp\node_modules\which\which.js:13:12)
npm ERR! gyp verb `which` failed at F (C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-gyp\node_modules\which\which.js:68:19)
npm ERR! gyp verb `which` failed at E (C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-gyp\node_modules\which\which.js:80:29)
npm ERR! gyp verb `which` failed at C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-gyp\node_modules\which\which.js:89:16
npm ERR! gyp verb `which` failed at C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\isexe\index.js:42:5
npm ERR! gyp verb `which` failed at C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\isexe\windows.js:36:5
npm ERR! gyp verb `which` failed at FSReqCallback.oncomplete (node:fs:202:21)
npm ERR! gyp verb `which` failed python2 Error: not found: python2
npm ERR! gyp verb `which` failed at FSReqCallback.oncomplete (node:fs:202:21) {
npm ERR! gyp verb `which` failed code: 'ENOENT'
npm ERR! gyp verb `which` failed }
npm ERR! gyp verb check python checking for Python executable "python" in the PATH
npm ERR! gyp verb `which` succeeded python C:\Python310\python.EXE
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Command failed: C:\Python310\python.EXE -c import sys; print "%s.%s.%s" % sys.version_info[:3];
npm ERR! gyp ERR! stack File "<string>", line 1
npm ERR! gyp ERR! stack import sys; print "%s.%s.%s" % sys.version_info[:3];
npm ERR! gyp ERR! stack ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
npm ERR! gyp ERR! stack SyntaxError: Missing parentheses in call to 'print'. Did you mean print(...)?
npm ERR! gyp ERR! stack at ChildProcess.exithandler (node:child_process:402:12)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at maybeClose (node:internal/child_process:1100:16)
npm ERR! gyp ERR! stack at Socket.<anonymous> (node:internal/child_process:458:11)
npm ERR! gyp ERR! stack at Socket.emit (node:events:513:28)
npm ERR! gyp ERR! stack at Pipe.<anonymous> (node:net:301:12)
npm ERR! gyp ERR! System Windows_NT 10.0.19044
npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\local-work\\Netlify-Sites\\one-click-hugo-cms\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
npm ERR! gyp ERR! cwd C:\local-work\Netlify-Sites\one-click-hugo-cms\node_modules\node-sass
npm ERR! gyp ERR! node -v v16.18.0
npm ERR! gyp ERR! node-gyp -v v3.8.0
npm ERR! gyp ERR! not ok
npm ERR! Build failed with error code: 1
I am running NodeJS v16.16.0(as per your OP @steveopixie) and have no such issues. It is possible this is a Windows-specific issue (I use macOS.)
Could you try
The issue is due to node-sass(this is in the original post, I just missed it.) When using NodeJS 16, node-sass 6.0+ is required. The version npm is trying to install is earlier and thus incompatible. Thus is tries to build it and fails.
This reason I didn’t see the error is node-sass wasn’t installed when I ran npm install. Looking through the package-lock.json it is a peer dependency of sass-loader and marked as optional, not a direct dependency of the project. You could try running npm install --omit peer or npm install --omit optional
Another option you might try is adding node-sass as a dependency in the package.json after cloning, e.g.
"node-sass": "^6.0.1"
and see if this works (this version of the package is compatible with NodeJS 16.)
