Error ffprobe was not found when building Gatsby site
Running into issues during build time with ffmpeg and ffprobe. Always get an error saying ffprobe was not found. Any solution to this? I’m basically using gatsby-transformer-ffmpeg and gatsby-plugin-ffmpeg
Hi @hideodaikoku, I moved your post to its own topic since it’s not related to Netlify Lambda Functions.
That said, for any binary executable files like ffmpeg or ffprobe that’s not included in the build-image we use, you’ll need to provide that yourself, by either including the binary in your repository or some other way. It’ll be up to you.
Hopefully that helps point you in the right direction.
Thank you so much for your response! Yes that definitely helps :grinning:
