I am aware that the other thread here, exists - however there seemed to be a resolution there that does not apply to my use case. In my example,
- the app uses Typescript,
- uses yarn to install (unlike npm in the other thread),
- and uses GitHub to create deployments.
Problem:
Pretty much every time a deploy preview is created for the app, it fails to build. If I go onto the UI, go to “Retry deploy” and choose “clear cache and deploy site” then it works, with no other changes/action. It’s rather frustrating to have deploy previews fail just to have to go in manually and clear cache and redeploy.
App name:
cytera-app
Error Log:
yarn run v1.17.0
$ react-scripts build
Creating an optimized production build...
Failed to compile.
./src/index.tsx
Error: [BABEL] /opt/build/repo/src/index.tsx: Cannot find module '@babel/helper-call-delegate'
Require stack:
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/plugin-transform-parameters/lib/params.js
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/plugin-transform-parameters/lib/index.js
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/preset-env/lib/available-plugins.js
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/preset-env/lib/plugins-compat-data.js
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/preset-env/lib/normalize-options.js
- /opt/build/repo/node_modules/babel-preset-react-app/node_modules/@babel/preset-env/lib/index.js
- /opt/build/repo/node_modules/babel-preset-react-app/create.js
- /opt/build/repo/node_modules/babel-preset-react-app/index.js
- /opt/build/repo/node_modules/react-scripts/node_modules/@babel/core/lib/config/files/plugins.js
- /opt/build/repo/node_modules/react-scripts/node_modules/@babel/core/lib/config/files/index.js
- /opt/build/repo/node_modules/react-scripts/node_modules/@babel/core/lib/index.js
- /opt/build/repo/node_modules/react-scripts/node_modules/babel-loader/lib/index.js
- /opt/build/repo/node_modules/loader-runner/lib/loadLoader.js
- /opt/build/repo/node_modules/loader-runner/lib/LoaderRunner.js
- /opt/build/repo/node_modules/webpack/lib/NormalModule.js
- /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js
- /opt/build/repo/node_modules/webpack/lib/Compiler.js
- /opt/build/repo/node_modules/webpack/lib/webpack.js
- /opt/build/repo/node_modules/react-scripts/scripts/build.js (While processing: "/opt/build/repo/node_modules/babel-preset-react-app/index.js")
error Command failed with exit code 1.
Package.json (since it was requested in the other thread)
"name": "app",
"version": "0.1.0",
"private": true,
"scripts": {
"build": "yarn build:web && npx cap copy",
"build:web": "react-scripts build",
"dev": "yarn start",
"doc": "doctoc README.md",
"eject": "react-scripts eject",
"generate": "node bin/generate_assets.js",
"postinstall": "yarn run requirements-check",
"lint": "eslint './src/**/*.{ts,tsx}'",
"lint-staged": "lint-staged",
"pretty-staged": "pretty-quick --staged",
"production": "react-scripts build && serve -s build",
"requirements-check": "node scripts/check_node_version.js",
"sort-package-json": "sort-package-json",
"start": "react-scripts start",
"test": "DISABLE_LOGS=true react-scripts test"
"husky": {
"hooks": {
"pre-commit": "npm-run-all sort-package-json pretty-staged lint-staged"
"lint-staged": {
"*.{ts,tsx}": "yarn run lint"
"browserslist": [
">0.2%",
"not dead",
"not ie <= 11",
"not op_mini all"
"prettier": "@hackscience/prettier-config",
"dependencies": {
"@apollo/react-hooks": "^3.1.3",
"@capacitor/cli": "^1.5.1",
"@capacitor/core": "1.5.1",
"@capacitor/ios": "^1.0.0-beta.19",
"@ionic/react": "^5.1.1",
"@material-ui/core": "^4.5.2",
"@material-ui/icons": "^4.5.1",
"@material-ui/styles": "^4.5.2",
"@types/debug": "^4.1.5",
"@types/jest": "25.2.3",
"@types/node": "14.0.9",
"@types/react": "16.9.35",
"@types/react-dom": "16.9.8",
"@types/react-router": "^5.1.7",
"@types/react-router-dom": "^5.1.2",
"@types/webpack-env": "^1.13.9",
"apollo-cache-inmemory": "^1.6.6",
"apollo-client": "^2.6.10",
"apollo-link": "^1.2.14",
"apollo-link-context": "^1.0.20",
"apollo-link-error": "^1.1.13",
"apollo-link-http": "^1.5.17",
"debug": "^4.1.1",
"graphql": "^15.0.0",
"graphql-tag": "^2.10.3",
"node-sass": "^4.13.0",
"react": "^16.8.4",
"react-apollo": "^3.1.5",
"react-dom": "^16.8.4",
"react-router": "^5.0.0",
"react-router-dom": "^5.1.0",
"react-scripts": "3.4.1",
"semver": "^7.3.2",
"typescript": "3.9.3"
"devDependencies": {
"@hackscience/prettier-config": "^1.0.2",
"@ionic/cli": "^6.10.0",
"@types/react-test-renderer": "^16.9.2",
"@typescript-eslint/eslint-plugin": "^3.1.0",
"@typescript-eslint/parser": "^3.1.0",
"doctoc": "^1.4.0",
"eslint-config-prettier": "^6.11.0",
"eslint-config-react": "^1.1.7",
"eslint-plugin-prettier": "^3.1.3",
"husky": "^4.2.5",
"imagemagick": "^0.1.3",
"jest-localstorage-mock": "^2.4.2",
"lint-staged": "^10.2.8",
"npm-run-all": "^4.1.5",
"prettier": "^2.0.5",
"pretty-quick": "^2.0.0",
"react-test-renderer": "^16.13.1",
"sort-package-json": "^1.22.1"
"engines": {
"node": ">=12.18.0"
"engineStrict": true
