I use the Eleventy build events beforeBuild and afterBuild (Events — Eleventy) in my pipeline to process my assets, and they are working great when I run a local build, but they are not getting fired when the command is run by Netlify.
I inserted console logs at several steps to keep track of the build process. I can see the messages printed on my local console but can’t see any in the Netlify deploy logs. Moreover, my assets are dependant on the code that runs in those events to be inserted in the final build folder, and they are not in said folder once Netlify is done.
Site: https://hardcore-bartik-f05f55.netlify.app/
Deploy log:
7:08:40 PM: Build ready to start
7:08:42 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
7:08:42 PM: build-image tag: v3.4.1
7:08:42 PM: buildbot version: 0a44c930054be748eff0c581d346282fece89cc0
7:08:42 PM: Fetching cached dependencies
7:08:42 PM: Starting to download cache of 100.1MB
7:08:44 PM: Finished downloading cache in 2.06569409s
7:08:44 PM: Starting to extract cache
7:08:48 PM: Finished extracting cache in 3.891776889s
7:08:48 PM: Finished fetching cache in 6.03223225s
7:08:48 PM: Starting to prepare the repo for build
7:08:49 PM: Preparing Git Reference refs/heads/main
7:08:51 PM: Starting build script
7:08:51 PM: Installing dependencies
7:08:51 PM: Python version set to 2.7
7:08:51 PM: Started restoring cached node version
7:08:54 PM: Finished restoring cached node version
7:08:55 PM: v12.18.0 is already installed.
7:08:56 PM: Now using node v12.18.0 (npm v6.14.4)
7:08:56 PM: Started restoring cached build plugins
7:08:56 PM: Finished restoring cached build plugins
7:08:56 PM: Attempting ruby version 2.7.1, read from environment
7:08:57 PM: Using ruby version 2.7.1
7:08:58 PM: Using PHP version 5.6
7:08:58 PM: 5.2 is already installed.
7:08:58 PM: Using Swift version 5.2
7:08:58 PM: Started restoring cached node modules
7:08:58 PM: Finished restoring cached node modules
7:08:58 PM: Installing NPM modules using NPM version 6.14.4
7:09:03 PM: audited 686 packages in 4.04s
7:09:03 PM: 34 packages are looking for funding
7:09:03 PM: run npm fund for details
7:09:03 PM: found 0 vulnerabilities
7:09:03 PM: NPM modules installed
7:09:04 PM: Started restoring cached go cache
7:09:04 PM: Finished restoring cached go cache
7:09:04 PM: go version go1.14.4 linux/amd64
7:09:04 PM: Installing missing commands
7:09:04 PM: Verify run directory
7:09:05 PM:
7:09:05 PM: ┌─────────────────────────────┐
7:09:05 PM: │ Netlify Build │
7:09:05 PM: └─────────────────────────────┘
7:09:05 PM:
7:09:05 PM: ❯ Version
7:09:05 PM: @netlify/build 5.0.2
7:09:05 PM:
7:09:05 PM: ❯ Flags
7:09:05 PM: deployId: 5f960578559b920007fcc51d
7:09:05 PM: mode: buildbot
7:09:05 PM:
7:09:05 PM: ❯ Current directory
7:09:05 PM: /opt/build/repo
7:09:05 PM:
7:09:05 PM: ❯ Config file
7:09:05 PM: /opt/build/repo/netlify.toml
7:09:05 PM:
7:09:05 PM: ❯ Context
7:09:05 PM: production
7:09:05 PM:
7:09:05 PM: ┌───────────────────────────────────┐
7:09:05 PM: │ 1. Build command from Netlify app │
7:09:05 PM: └───────────────────────────────────┘
7:09:05 PM:
7:09:05 PM: $ npm run build
7:09:05 PM: > eleventy-starter@1.0.0 build /opt/build/repo
7:09:05 PM: > set NODE_ENV=production&& rimraf _site && npx @11ty/eleventy
7:09:08 PM: Writing _site/fr/blogue/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/fr/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/fr/a-propos/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/fr/contact/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/fr/404/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/blog/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/about/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/contact/index.html from ./src/site/index.njk.
7:09:08 PM: Writing _site/404/index.html from ./src/site/index.njk.
7:09:08 PM: Benchmark (Data): ./src/site/_data/languages.js took 262ms (10.2%)
7:09:08 PM: Benchmark (Data): ./src/site/_data/pages.js took 824ms (31.9%)
7:09:08 PM: Benchmark (Data): ./src/site/_data/ui.js took 311ms (12.0%)
7:09:08 PM: Copied 6 files / Wrote 10 files in 1.65 seconds (165.0ms each, v0.11.0)
7:09:09 PM:
7:09:09 PM: (build.command completed in 3.8s)
7:09:09 PM:
7:09:09 PM: ┌─────────────────────────────┐
7:09:09 PM: │ Netlify Build Complete │
7:09:09 PM: └─────────────────────────────┘
7:09:09 PM:
7:09:09 PM: (Netlify Build completed in 3.8s)
7:09:09 PM: Caching artifacts
7:09:09 PM: Started saving node modules
7:09:09 PM: Finished saving node modules
7:09:09 PM: Started saving build plugins
7:09:09 PM: Finished saving build plugins
7:09:09 PM: Started saving pip cache
7:09:09 PM: Finished saving pip cache
7:09:09 PM: Started saving emacs cask dependencies
7:09:09 PM: Finished saving emacs cask dependencies
7:09:09 PM: Started saving maven dependencies
7:09:09 PM: Finished saving maven dependencies
7:09:09 PM: Started saving boot dependencies
7:09:09 PM: Finished saving boot dependencies
7:09:09 PM: Started saving go dependencies
7:09:09 PM: Finished saving go dependencies
7:09:09 PM: Build script success
7:09:09 PM: Starting to deploy site from ‘_site’
7:09:09 PM: Creating deploy tree
7:09:09 PM: Creating deploy upload records
7:09:09 PM: 10 new files to upload
7:09:09 PM: 0 new functions to upload
7:09:10 PM: Starting post processing
7:09:11 PM: Post processing - HTML
7:09:11 PM: Post processing - header rules
7:09:11 PM: Post processing - redirect rules
7:09:11 PM: Post processing done
7:09:12 PM: Site is live ![]()
7:09:26 PM: Finished processing build request in 44.207559966s
Here is the log I get when I run a build locally:
npm run build
eleventy-starter@1.0.0 build B:\web\Projects\eleventy-starter
BEFORE BUILD
AFTER BUILD
RUNNING POSTCSS production
POSTCSS MINIFY
Benchmark (Data): ./src/site/_data/languages.js took 1622ms (39.4%)
Benchmark (Data): ./src/site/_data/pages.js took 624ms (15.2%)
Benchmark (Data): ./src/site/_data/ui.js took 499ms (12.1%)
Copied 6 files / Wrote 10 files in 3.09 seconds (309.0ms each, v0.11.1)
POSTCSS DONE
As you can see, I get BEFORE BUILD and AFTER BUILD logs that correspond to the build events. These do not appear in the Netlify deploy log and the assets therefore do not get generated.
