Deploy stuck on Building without any errors
Hi,
I already tried for multiple hours to get my deploy up and running. It builds forever and never gets to ‘Deploying’. Everything works perfectly fine locally - no errors. I also tried ‘yarn run build’ instead → this also works. But I need generate because form detection won’t work when i use the build command.
Huge thanks in advance!!
Build command: yarn run generate
Publish directory: dist
Using Nuxt3 + Storyblok
What I tried:
  • Push empty Dist folder and remove Dist from gitignore
  • ‘yarn run build’ instead of ‘yarn run generate’ → this works
  • Dependency management is set to Node.js: 20.x
Here the Logs:
3:47:32 PM: build-image version: ebe1739aa70e1db449262aa2ac466dad070382fb (focal)
3:47:32 PM: buildbot version: 211f66487a631406c3c0b2b43c8b33d0bb175356
3:47:32 PM: Building without cache
3:47:32 PM: Starting to prepare the repo for build
3:47:32 PM: No cached dependencies found. Cloning fresh repo
3:47:32 PM: git clone --filter=blob:none https://github.com/dnlsptzk/spatzek-studio-2024
3:47:33 PM: Preparing Git Reference refs/heads/main
3:47:35 PM: Starting to install dependencies
3:47:35 PM: Python version set to 3.8
3:47:35 PM: Attempting Ruby version 2.7.2, read from environment
3:47:35 PM: Using Ruby version 2.7.2
3:47:36 PM: Started restoring cached go cache
3:47:36 PM: Finished restoring cached go cache
3:47:36 PM: go version go1.19.13 linux/amd64
3:47:36 PM: Using PHP version 8.0
3:47:37 PM: Downloading and installing node v20.11.0...
3:47:37 PM: Downloading https://nodejs.org/dist/v20.11.0/node-v20.11.0-linux-x64.tar.xz...
3:47:37 PM: Computing checksum with sha256sum
3:47:38 PM: Checksums matched!
3:47:40 PM: Now using node v20.11.0 (npm v10.2.4)
3:47:40 PM: Enabling Node.js Corepack
3:47:40 PM: Started restoring cached build plugins
3:47:40 PM: Finished restoring cached build plugins
3:47:40 PM: Started restoring cached corepack dependencies
3:47:40 PM: Finished restoring cached corepack dependencies
3:47:40 PM: Started restoring cached yarn cache
3:47:40 PM: Finished restoring cached yarn cache
3:47:40 PM: No yarn workspaces detected
3:47:40 PM: Started restoring cached node modules
3:47:40 PM: Finished restoring cached node modules
3:47:41 PM: Installing npm packages using Yarn version 1.22.19
3:47:41 PM: yarn install v1.22.19
3:47:41 PM: [1/4] Resolving packages...
3:47:41 PM: [2/4] Fetching packages...
3:47:51 PM: warning vscode-languageclient@7.0.0: The engine "vscode" appears to be invalid.
3:47:51 PM: [3/4] Linking dependencies...
3:47:51 PM: warning " > @nuxt/devtools@1.0.4" has unmet peer dependency "vite@*".
3:47:51 PM: warning "@nuxt/devtools > @nuxt/devtools-kit@1.0.4" has unmet peer dependency "vite@*".
3:47:51 PM: warning "@nuxt/devtools > vite-plugin-inspect@0.7.42" has unmet peer dependency "vite@^3.1.0 || ^4.0.0 || ^5.0.0-0".
3:47:51 PM: warning "@nuxt/devtools > vite-plugin-vue-inspector@4.0.1" has unmet peer dependency "vite@^3.0.0-0 || ^4.0.0-0 || ^5.0.0-0".
3:47:52 PM: [4/4] Building fresh packages...
3:47:54 PM: $ nuxt prepare
3:47:55 PM: [success] Types generated in .nuxt
3:47:55 PM: Done in 14.51s.
3:47:55 PM: npm packages installed using Yarn
3:47:56 PM: Successfully installed dependencies
3:47:56 PM: Starting build script
3:47:57 PM: Detected 1 framework(s)
3:47:57 PM: "nuxt" at version "3.8.2"
3:47:57 PM: Section completed: initializing
3:47:58 PM: ​
3:47:58 PM: Netlify Build
3:47:58 PM: ────────────────────────────────────────────────────────────────
3:47:58 PM: ​
3:47:58 PM: ❯ Version
3:47:58 PM:   @netlify/build 29.32.0
3:47:58 PM: ​
3:47:58 PM: ❯ Flags
3:47:58 PM:   baseRelDir: true
3:47:58 PM:   buildId: 65a54566b1550b1a9dc42e3a
3:47:58 PM:   deployId: 65a54566b1550b1a9dc42e3c
3:47:58 PM: ​
3:47:58 PM: ❯ Current directory
3:47:58 PM:   /opt/build/repo
3:47:58 PM: ​
3:47:58 PM: ❯ Config file
3:47:58 PM:   No config file was defined: using default values.
3:47:58 PM: ​
3:47:58 PM: ❯ Context
3:47:58 PM:   production
3:47:58 PM: ​
3:47:58 PM: Build command from Netlify app
3:47:58 PM: ​
3:47:58 PM: $ yarn run generate
3:47:58 PM: yarn run v1.22.19
3:47:58 PM: $ nuxt generate
3:47:59 PM: [log] Nuxt 3.8.2 with Nitro 2.8.1
3:47:59 PM: [info] Using Nitro server preset: `static`
3:48:00 PM: [info] Building client...
3:48:00 PM: [info] vite v4.5.1 building for production...
3:48:00 PM: [info] transforming...
3:48:04 PM: [info] ✓ 277 modules transformed.
3:48:05 PM: [info] rendering chunks...
3:48:05 PM: [info] computing gzip size...
3:48:05 PM: [info] .nuxt/dist/client/manifest.json                                  11.52 kB │ gzip:   1.50 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/_...slug_.64fc3c36.css                    0.07 kB │ gzip:   0.08 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/SvgSpatzekLogo.4f3d26f9.css               0.10 kB │ gzip:   0.10 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/entry.f55ff283.css                        0.13 kB │ gzip:   0.12 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Page.075f6fa2.css                         0.23 kB │ gzip:   0.16 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreIntroPic.b7af0596.css                0.45 kB │ gzip:   0.27 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/FeaturedProjects.ce29efb2.css             0.72 kB │ gzip:   0.34 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutServices.1015c138.css                0.78 kB │ gzip:   0.40 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/ProjectCard.c4156325.css                  0.83 kB │ gzip:   0.38 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Footer.1f0ce77f.css                       1.00 kB │ gzip:   0.43 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/ProjectCardTeaser.175ffdd6.css            1.04 kB │ gzip:   0.41 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutIntro.d968fcce.css                   1.24 kB │ gzip:   0.46 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/SvgGlobeIcon.ff558d4c.css                 1.35 kB │ gzip:   0.36 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutInfo.c129a758.css                    1.44 kB │ gzip:   0.56 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutAwards.3eb9d4f7.css                  1.46 kB │ gzip:   0.48 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/WorkOverview.4cc372c7.css                 1.57 kB │ gzip:   0.64 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeAbout.efe749ee.css                    1.82 kB │ gzip:   0.68 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeStore.ab49c425.css                    1.89 kB │ gzip:   0.65 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeIntro.e8238e0e.css                    2.00 kB │ gzip:   0.69 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreIntro.5aa60d04.css                   2.16 kB │ gzip:   0.67 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutProcessFaq.7eb11ffc.css              2.41 kB │ gzip:   0.72 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Project.8c4d1106.css                      3.54 kB │ gzip:   0.90 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreItems.f8c5f706.css                   4.43 kB │ gzip:   0.99 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/default.c8e7ef46.css                      9.75 kB │ gzip:   2.13 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Imprint.681ab5a2.js                       0.25 kB │ gzip:   0.21 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/elements.5547b51a.js                      0.37 kB │ gzip:   0.27 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/FallbackComponent-ddf2f161.9cc41616.js    0.49 kB │ gzip:   0.35 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/state.35b3c081.js                         0.53 kB │ gzip:   0.33 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Page.e3f28a0e.js                          0.58 kB │ gzip:   0.40 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/FeaturedProjects.dd686c08.js              0.67 kB │ gzip:   0.42 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/_...slug_.e3f63f66.js                     0.76 kB │ gzip:   0.50 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/ProjectCard.e5aa0d13.js                   0.79 kB │ gzip:   0.44 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutServices.5e074a38.js                 0.83 kB │ gzip:   0.46 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutIntro.412c93ae.js                    0.86 kB │ gzip:   0.48 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutAwards.df3330fe.js                   0.90 kB │ gzip:   0.45 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/ProjectCardTeaser.6873ea31.js             0.91 kB │ gzip:   0.50 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeStore.8043fbb3.js                     1.08 kB │ gzip:   0.55 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Footer.09ddc24a.js                        1.10 kB │ gzip:   0.64 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeAbout.e29ea1a6.js                     1.17 kB │ gzip:   0.61 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutInfo.b90534b7.js                     1.37 kB │ gzip:   0.54 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreIntro.0d1abe16.js                    1.47 kB │ gzip:   0.68 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/AboutProcessFaq.4590b180.js               1.49 kB │ gzip:   0.63 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/WorkOverview.71fbb4cc.js                  2.18 kB │ gzip:   1.14 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreItems.184a3258.js                    2.58 kB │ gzip:   1.06 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/SvgGlobeIcon.a629cfcf.js                  2.75 kB │ gzip:   0.94 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/SvgSpatzekLogo.73a9afdd.js                3.24 kB │ gzip:   1.46 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/Project.d746bfa1.js                       3.45 kB │ gzip:   1.29 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/StoreIntroPic.e8c21200.js                 3.80 kB │ gzip:   1.92 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/HomeIntro.c50c29a1.js                     8.78 kB │ gzip:   3.47 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/nuxt-img.d689e01b.js                      9.60 kB │ gzip:   3.95 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/entry.fc859eb7.js                       299.98 kB │ gzip: 115.22 kB
3:48:05 PM: [info] .nuxt/dist/client/_nuxt/default.573194cf.js                     660.85 kB │ gzip: 173.91 kB
3:48:05 PM: [warn]
3:48:05 PM: (!) Some chunks are larger than 500 kBs after minification. Consider:
3:48:05 PM: - Using dynamic import() to code-split the application
3:48:05 PM: - Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
3:48:05 PM: - Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
3:48:05 PM: [info] ✓ built in 4.55s
3:48:05 PM: [success] Client built in 4617ms
3:48:05 PM: [info] Building server...
3:48:05 PM: [info] vite v4.5.1 building SSR bundle for production...
3:48:05 PM: [info] transforming...
3:48:07 PM: [info] ✓ 211 modules transformed.
3:48:07 PM: [info] rendering chunks...
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Page-styles.b1924bb2.mjs                    0.14 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/entry-styles.42232591.mjs                   0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Project-styles.eabcfe24.mjs                 0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutInfo-styles.384b180f.mjs               0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/_...slug_-styles.cc43eb16.mjs               0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeAbout-styles.8a5af48e.mjs               0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeStore-styles.c9556dc7.mjs               0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutIntro-styles.af3f3427.mjs              0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutAwards-styles.5943ba5e.mjs             0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/WorkOverview-styles.7e33dca5.mjs            0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutServices-styles.b6fe51cf.mjs           0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutProcessFaq-styles.dba35e63.mjs         0.17 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/FeaturedProjects-styles.588edc9f.mjs        0.17 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeIntro-styles.4b74f1e0.mjs               0.22 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreIntro-styles.04f6c754.mjs              0.23 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreItems-styles.29e4c0df.mjs              0.23 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles.79084359.mjs                 0.90 kB
3:48:07 PM: [info] .nuxt/dist/server/styles.mjs                                        1.96 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-12.mjs-9c950ad1.js           0.24 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/_...slug_-styles-1.mjs-82312c37.js          0.25 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-7.mjs-c3b5e7fb.js            0.29 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-6.mjs-ed8e4353.js            0.29 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeIntro-styles-1.mjs-331059d3.js          0.30 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-3.mjs-5879f330.js            0.31 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/entry-styles-2.mjs-32097206.js              0.33 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Page-styles-1.mjs-fffa5f7f.js               0.39 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-2.mjs-f64cdaa1.js            0.40 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-10.mjs-133a24c7.js           0.54 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-9.mjs-c537e0b9.js            0.54 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-11.mjs-0f6fddcc.js           0.55 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Imprint-6f7daa8d.js                         0.81 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/FallbackComponent-ddf2f161-7480cb0a.js      0.90 kB │ map:   1.61 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/FeaturedProjects-styles-1.mjs-861d90ec.js   0.95 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutServices-styles-1.mjs-31e69f79.js      0.97 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/state-21b16c03.js                           1.01 kB │ map:   2.26 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreIntro-styles-1.mjs-182d51c4.js         1.06 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/island-renderer-5c93f643.js                 1.15 kB │ map:   1.52 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreItems-styles-2.mjs-e4dd9fef.js         1.25 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutIntro-styles-1.mjs-2c796c37.js         1.42 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreIntro-styles-2.mjs-f88660fc.js         1.52 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutInfo-styles-1.mjs-9fbd8a9d.js          1.63 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutAwards-styles-1.mjs-4b9d736b.js        1.65 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutServices-77eb1209.js                   1.70 kB │ map:   0.14 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/WorkOverview-styles-1.mjs-1808c2b6.js       1.76 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutAwards-84dd985a.js                     1.83 kB │ map:   0.13 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-5.mjs-6391b78a.js            1.85 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/ProjectCardTeaser-d4fc55f3.js               1.88 kB │ map:   0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-4.mjs-afca8621.js            1.89 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/FeaturedProjects-641832f9.js                1.96 kB │ map:   0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-8.mjs-8b2be4a6.js            1.97 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeAbout-styles-1.mjs-2d027228.js          2.00 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Page-79c90b89.js                            2.01 kB │ map:   0.86 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeStore-styles-1.mjs-0b423de2.js          2.07 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutIntro-19e19952.js                      2.12 kB │ map:   2.53 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeIntro-styles-2.mjs-ba0db8f5.js          2.13 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/_...slug_-f2cc7927.js                       2.22 kB │ map:   3.25 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutProcessFaq-styles-1.mjs-43500423.js    2.61 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutProcessFaq-8fb8930e.js                 2.61 kB │ map:   0.14 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeStore-af82f3c2.js                       2.64 kB │ map:   3.91 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Footer-a6010ba4.js                          2.68 kB │ map:   2.66 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeAbout-81a62bcc.js                       2.76 kB │ map:   4.74 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/AboutInfo-54620232.js                       2.89 kB │ map:   3.64 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/ProjectCard-bfcf48e2.js                     2.94 kB │ map:   0.16 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/WorkOverview-42e1ecfe.js                    3.46 kB │ map:   5.63 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreItems-styles-1.mjs-53473ed2.js         3.58 kB │ map:   0.12 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreIntro-4fc6ef4b.js                      3.67 kB │ map:   3.98 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-styles-1.mjs-77ee0c46.js            3.67 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/entry-styles-1.mjs-40df9cd2.js              3.69 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Project-styles-1.mjs-8c6fe433.js            3.72 kB │ map:   0.11 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/SvgSpatzekLogo-e1de9ada.js                  3.91 kB │ map:   3.68 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/SvgGlobeIcon-d85f8ae4.js                    3.96 kB │ map:   0.15 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreIntroPic-329b09ea.js                   5.44 kB │ map:   5.66 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/StoreItems-6bccc079.js                      5.61 kB │ map:   7.80 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/Project-5b9c03d0.js                         7.77 kB │ map:   9.75 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/HomeIntro-4f58aa0e.js                      10.93 kB │ map:  13.04 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/nuxt-img-94b00960.js                       19.43 kB │ map:  44.92 kB
3:48:07 PM: [info] .nuxt/dist/server/_nuxt/default-070747c0.js                        34.54 kB │ map:  67.89 kB
3:48:07 PM: [info] .nuxt/dist/server/server.mjs                                       75.19 kB │ map: 163.00 kB
3:48:07 PM: [info] ✓ built in 1.93s
3:48:07 PM: [success] Server built in 1938ms
3:48:07 PM: [info] [nitro] Initializing prerenderer
3:48:08 PM: [info] [nitro] Prerendering 3 initial routes with crawler
3:48:08 PM: [log] [nitro]   ├─ /200.html (32ms)
3:48:08 PM: [log] [nitro]   ├─ /404.html (33ms)
3:48:08 PM: [log] [nitro]   ├─ / (440ms)
3:48:08 PM: [log] [nitro]   ├─ /_payload.json (29ms)
3:48:09 PM: [log] [nitro]   ├─ /work/ (356ms)
3:48:09 PM: [log] [nitro]   ├─ /work/_payload.json (7ms)
3:48:09 PM: [log] [nitro]   ├─ /work/bugatti (316ms)
3:48:09 PM: [log] [nitro]   ├─ /work/bugatti/_payload.json (0ms)
3:48:09 PM: [log] [nitro]   ├─ /imprint (1007ms)
3:48:09 PM: [log] [nitro]   ├─ /imprint/_payload.json (1ms)
3:48:09 PM: [log] [nitro]   ├─ /store (1027ms)
3:48:09 PM: [log] [nitro]   ├─ /store/_payload.json (0ms)
3:48:10 PM: [log] [nitro]   ├─ /about (1185ms)
3:48:10 PM: [log] [nitro]   ├─ /about/_payload.json (0ms)
3:48:10 PM: [log] [nitro]   ├─ /work/viita-watches (1322ms)
3:48:10 PM: [log] [nitro]   ├─ /work/sixmorevodka (1327ms)
3:48:10 PM: [log] [nitro]   ├─ /work/viita-watches/_payload.json (0ms)
3:48:10 PM: [log] [nitro]   ├─ /work/sixmorevodka/_payload.json (1ms)
3:48:10 PM: [log] [nitro]   ├─ /work/blumenkopf (1009ms)
3:48:10 PM: [log] [nitro]   ├─ /work/blumenkopf/_payload.json (0ms)
3:48:10 PM: [success] [nitro] Generated public dist
3:48:10 PM: [success] [nitro] You can preview this build using `npx serve .output/static`
3:48:10 PM: [success] You can now deploy `dist` to any static hosting!
I’m struggling with the same issue for two days and have not been able to find anything yet.
Build command stuck at You can deploy this build using npx firebase-tools deploy
and never exit
I found the issue:
For me it was a setInterval function that I had to call onMounted() not before.
Hi :wave:t6: thanks for writing back in and sharing you found your solution!
