We need to know your netlify site name. https://pointsvoyager.travel
Build problems?
10:12:58 PM: build-image version: 006dca901dab83234b4881f914ac1a189ff41daa (focal)
10:12:58 PM: buildbot version: e8a1f877a96ee9d2b754bae26acb6bb322cba939
10:12:58 PM: Fetching cached dependencies
10:12:58 PM: Starting to download cache of 134.8MB
10:12:59 PM: Finished downloading cache in 1.367s
10:12:59 PM: Starting to extract cache
10:13:01 PM: Finished extracting cache in 1.525s
10:13:01 PM: Finished fetching cache in 2.952s
10:13:01 PM: Starting to prepare the repo for build
10:13:01 PM: Preparing Git Reference refs/heads/main
10:13:03 PM: Starting to install dependencies
10:13:03 PM: Python version set to 3.8
10:13:03 PM: Attempting Ruby version 2.7.2, read from environment
10:13:04 PM: Using Ruby version 2.7.2
10:13:04 PM: Started restoring cached go cache
10:13:04 PM: Finished restoring cached go cache
10:13:06 PM: go version go1.19.13 linux/amd64
10:13:06 PM: Using PHP version 8.0
10:13:08 PM: Started restoring cached Node.js version
10:13:09 PM: Finished restoring cached Node.js version
10:13:10 PM: v18.20.4 is already installed.
10:13:10 PM: Now using node v18.20.4 (npm v10.7.0)
10:13:10 PM: Enabling Node.js Corepack
10:13:10 PM: Started restoring cached build plugins
10:13:10 PM: Finished restoring cached build plugins
10:13:10 PM: Started restoring cached corepack dependencies
10:13:10 PM: Finished restoring cached corepack dependencies
10:13:10 PM: No npm workspaces detected
10:13:10 PM: Started restoring cached node modules
10:13:10 PM: Finished restoring cached node modules
10:13:10 PM: Installing npm packages using npm version 10.7.0
10:13:11 PM: up to date, audited 342 packages in 874ms
10:13:11 PM: 53 packages are looking for funding
10:13:11 PM: runnpm fundfor details
10:13:11 PM: found 0 vulnerabilities
10:13:11 PM: npm packages installed
10:13:12 PM: Successfully installed dependencies
10:13:12 PM: Starting build script
10:13:13 PM: Detected 1 framework(s)
10:13:13 PM: “vite” at version “4.5.3”
10:13:13 PM: Section completed: initializing
10:13:14 PM:
10:13:14 PM: Netlify Build
10:13:14 PM: ────────────────────────────────────────────────────────────────
10:13:14 PM:
10:13:14 PM: ❯ Version
10:13:14 PM: @netlify/build 29.50.5
10:13:14 PM:
10:13:14 PM: ❯ Flags
10:13:14 PM: baseRelDir: true
10:13:14 PM: buildId: 668dee1fab329e000882b3bc
10:13:14 PM: deployId: 668dee1fab329e000882b3be
10:13:14 PM:
10:13:14 PM: ❯ Current directory
10:13:14 PM: /opt/build/repo
10:13:14 PM:
10:13:14 PM: ❯ Config file
10:13:14 PM: No config file was defined: using default values.
10:13:14 PM:
10:13:14 PM: ❯ Context
10:13:14 PM: production
10:13:14 PM:
10:13:14 PM: Build command from Netlify app
10:13:14 PM:
10:13:14 PM: $ npm run build
10:13:15 PM: > frontend@0.0.0 build
10:13:15 PM: > vite build
10:13:15 PM: vite v4.5.3 building for production…
10:13:15 PM: transforming…
10:13:15 PM: node_modules/@react-oauth/google/dist/index.esm.js (1:0) Module level directives cause errors when bundled, “use client” in “node_modules/@react-oauth/google/dist/index.esm.js” was ignored.
10:13:17 PM: ✓ 448 modules transformed.
10:13:18 PM: Starting post processing
10:13:18 PM: rendering chunks…
10:13:18 PM: computing gzip size…
10:13:18 PM: dist/index.html 1.58 kB │ gzip: 0.97 kB
10:13:18 PM: dist/assets/index-8b86b433.css 45.83 kB │ gzip: 7.64 kB
10:13:18 PM: dist/assets/index-f7cd1e14.js 467.06 kB │ gzip: 132.50 kB
10:13:18 PM: ✓ built in 2.79s
10:13:18 PM:
10:13:18 PM: (build.command completed in 3.3s)
10:13:18 PM:
10:13:18 PM: Deploy site
10:13:18 PM: ────────────────────────────────────────────────────────────────
10:13:18 PM:
10:13:18 PM: Starting to deploy site from ‘dist’
10:13:18 PM: Calculating files to upload
10:13:18 PM: 3 new files to upload
10:13:18 PM: 0 new functions to upload
10:13:18 PM: Section completed: deploying
10:13:18 PM: Site deploy was successfully initiated
10:13:18 PM:
10:13:18 PM: (Deploy site completed in 393ms)
10:13:18 PM:
10:13:18 PM: Netlify Build Complete
10:13:18 PM:
10:13:18 PM: (Netlify Build completed in 3.8s)
10:13:19 PM: Skipping form detection
10:13:19 PM: Post processing - header rules
10:13:19 PM: Post processing - redirect rules
10:13:19 PM: Caching artifacts
10:13:19 PM: Started saving node modules
10:13:19 PM: Finished saving node modules
10:13:19 PM: Started saving build plugins
10:13:19 PM: Finished saving build plugins
10:13:19 PM: Started saving corepack cache
10:13:19 PM: Finished saving corepack cache
10:13:19 PM: Started saving pip cache
10:13:19 PM: Finished saving pip cache
10:13:19 PM: Started saving emacs cask dependencies
10:13:19 PM: Finished saving emacs cask dependencies
10:13:19 PM: Started saving maven dependencies
10:13:19 PM: Finished saving maven dependencies
10:13:19 PM: Started saving boot dependencies
10:13:19 PM: Finished saving boot dependencies
10:13:19 PM: Started saving rust rustup cache
10:13:19 PM: Finished saving rust rustup cache
10:13:19 PM: Started saving go dependencies
10:13:19 PM: Finished saving go dependencies
10:13:19 PM: Build script success
10:13:19 PM: Section completed: building
10:13:20 PM: Post processing done
10:13:20 PM: Section completed: postprocessing
10:13:22 PM: Uploading Cache of size 134.8MB
10:13:24 PM: Site is live
10:13:24 PM: Section completed: cleanup
10:13:24 PM: Finished processing build request in 26.06s -
Did you try [Ask Netlify] - Yes, they said they found a relevant post where support was able to manually cancel the build.
