Hi Netlify community,
I’m running into some issues with my deployment process, and I could use some guidance. Here are the logs in the attachment below:
What’s the name of the site?
Apologies @sid.m here: ehomez
It looks like the most recent failed build is failing with the following error:
7:45:00 AM: Failed to create function: invalid parameter for function creation: Invalid AWS Lambda parameters used in this request.
Could you take a look and ensure your environment variables are defined correctly?
