Hi all,
I need to know the solution as I have received fail massage of fail building.
8:49:11 PM: Netlify Build
8:49:11 PM: ────────────────────────────────────────────────────────────────
8:49:11 PM:
8:49:11 PM: ❯ Version
8:49:11 PM: @netlify/build 29.36.5
8:49:11 PM:
8:49:11 PM: ❯ Flags
8:49:11 PM: baseRelDir: true
8:49:11 PM: buildId: 660021167fedffd3a35436fc
8:49:11 PM: deployId: 660021167fedffd3a35436fe
8:49:11 PM:
8:49:11 PM: ❯ Current directory
8:49:11 PM: /opt/build/repo
8:49:11 PM:
8:49:11 PM: ❯ Config file
8:49:11 PM: No config file was defined: using default values.
8:49:11 PM:
8:49:11 PM: ❯ Context
8:49:11 PM: production
8:49:11 PM:
8:49:11 PM: Build command from Netlify app
8:49:11 PM:
8:49:11 PM: $ npm run build
8:49:11 PM: > build
8:49:11 PM: > vite build
8:49:12 PM: Failed during stage “building site”: Build script returned non-zero exit code: 2
8:49:12 PM: The CJS build of Vite"s Node API is deprecated. See Troubleshooting | Vite for more details.
vite v5.2.5 building for production…
8:49:12 PM: ✓ 0 modules transformed.
8:49:12 PM: x Build failed in 37ms
8:49:12 PM: error during build:
8:49:12 PM: Error: [vite:build-html] Unable to parse HTML; parse5 error code unexpected-character-in-attribute-name
8:49:12 PM: at /opt/build/repo/index.html:12:13
8:49:12 PM: 10 |
Today is Louis"s birthday
11 | <img id=“bff-img” src=louis — Postimages
8:49:12 PM: 12 |
6 years old
8:49:12 PM: | ^
8:49:12 PM: 13 |
25.06.2018
8:49:12 PM: 14 |
8:49:12 PM: file: /opt/build/repo/index.html
8:49:12 PM: at handleParseError (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-DETuI4x9.js:30589:11)
8:49:12 PM: at Parser.onParseError (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-DETuI4x9.js:30515:13)
8:49:12 PM: at Tokenizer._err (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:1125:89)
8:49:12 PM: at Tokenizer._stateAttributeName (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:2517:22)
8:49:12 PM: at Tokenizer._stateBeforeAttributeName (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:2489:22)
8:49:12 PM: at Tokenizer._callState (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:1608:22)
8:49:12 PM: at Tokenizer._runParsingLoop (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:1149:22)
8:49:12 PM: at Tokenizer.write (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:1174:14)
8:49:12 PM: at Parser.parse (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:4856:26)
8:49:12 PM: at parse (file:///opt/build/repo/node_modules/vite/dist/node/chunks/dep-CrWVpuYf.js:7927:19)
8:49:12 PM:
8:49:12 PM: “build.command” failed
8:49:12 PM: ────────────────────────────────────────────────────────────────
8:49:12 PM:
8:49:12 PM: Error message
8:49:12 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
8:49:12 PM:
8:49:12 PM: Error location
8:49:12 PM: In Build command from Netlify app:
8:49:12 PM: npm run build
8:49:12 PM:
8:49:12 PM: Resolved config
8:49:12 PM: build:
8:49:12 PM: command: npm run build
8:49:12 PM: commandOrigin: ui
8:49:12 PM: publish: /opt/build/repo/dist
8:49:12 PM: publishOrigin: ui
8:49:12 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:49:12 PM: Failing build: Failed to build site
8:49:12 PM: Finished processing build request in 22.938s
