Hi,
My package.json file was like that before
"name": "gatsby-starter-default",
"private": true,
"description": "A simple starter to get up and developing quickly with Gatsby",
"version": "0.1.0",
"author": "Kyle Mathews <mathews.kyle@gmail.com>",
"dependencies": {
"autoprefixer": "^9.7.6",
"axios": "^0.19.2",
"gatsby": "^2.19.43",
"gatsby-core-utils": "^1.1.1",
"gatsby-image": "^2.2.43",
"gatsby-plugin-i18n": "^1.0.1",
"gatsby-plugin-manifest": "^2.2.47",
"gatsby-plugin-offline": "^3.0.40",
"gatsby-plugin-react-helmet": "^3.1.23",
"gatsby-plugin-react-svg": "^3.0.0",
"gatsby-plugin-sass": "^2.1.31",
"gatsby-plugin-sharp": "^2.4.12",
"gatsby-source-filesystem": "^2.1.55",
"gatsby-source-wordpress": "^3.2.2",
"gatsby-transformer-sharp": "^2.3.18",
"highcharts": "^8.0.4",
"intl": "^1.2.5",
"mobile-device-detect": "^0.3.3",
"node-sass": "^4.13.1",
"prop-types": "^15.7.2",
"ptz-i18n": "^1.0.0",
"react": "^16.12.0",
"react-animate-on-scroll": "^2.1.5",
"react-dom": "^16.12.0",
"react-dropzone": "^10.2.2",
"react-full-page": "^0.1.8",
"react-helmet": "^5.2.1",
"react-hook-form": "^5.4.2",
"react-intl": "^2.8.0",
"react-jsx-highcharts": "^4.0.1",
"react-modal": "^3.11.2",
"react-page-scroller": "^2.0.0-beta",
"react-slick": "^0.25.2",
"slick-carousel": "^1.8.1",
"uuid": "^7.0.2"
"devDependencies": {
"eslint": "^6.8.0",
"eslint-config-airbnb": "^18.1.0",
"eslint-loader": "^3.0.3",
"eslint-plugin-import": "^2.20.1",
"eslint-plugin-jsx-a11y": "^6.2.3",
"eslint-plugin-react": "^7.19.0",
"gatsby-plugin-eslint": "^2.0.8",
"prettier": "^1.19.1"
"keywords": [
"gatsby"
"license": "MIT",
"scripts": {
"build": "gatsby build",
"develop": "gatsby develop",
"format": "prettier --write \"**/*.{js,jsx,json,md}\"",
"start": "npm run develop",
"serve": "gatsby serve",
"clean": "gatsby clean",
"test": "echo \"Write tests! -> https://gatsby.dev/unit-testing\" && exit 1"
"repository": {
"type": "git",
"url": "https://github.com/gatsbyjs/gatsby-starter-default"
"bugs": {
"url": "https://github.com/gatsbyjs/gatsby/issues"
Now according to the link you provided above, I modified it to that
"private": true,
"version": "0.1.0",
"dependencies": {
"axios": "^0.19.2",
"intl": "^1.2.5",
"uuid": "^7.0.2"
"eslint": "^6.8.0",
"keywords": [
"gatsby"
"license": "MIT",
"scripts": {
"repository": {
"type": "git",
"bugs": {
"browserslist": [
"> 1%",
"ie >= 8",
"edge >= 15",
"ie_mob >= 10",
"ff >= 45",
"chrome >= 45",
"safari >= 7",
"opera >= 23",
"ios >= 7",
"android >= 4",
"bb >= 10"
But still, the issue persists
5:48:21 PM: Build ready to start
5:48:21 PM: ---------------------------------------------------------------------DEPRECATION NOTICE: Builds using the Xenial build image will fail after November 15th, 2022.The build image for this site uses Ubuntu 16.04 Xenial Xerus, which is no longer supported.All Netlify builds using the Xenial build image will begin failing in the week of November 15th, 2022.To avoid service disruption, please select a newer build image at the following link:https://app.netlify.com/sites/dazzling-archimedes-f639d4/settings/deploys#build-image-selectionFor more details, visit the build image migration guide:https://answers.netlify.com/t/please-read-end-of-support-for-xenial-build-image-everything-you-need-to-know/68239---------------------------------------------------------------------
5:48:23 PM: build-image version: 1ac2360cf8aee6cb2695dd2682b312fefc908a7f (xenial)
5:48:23 PM: build-image tag: v3.15.0
5:48:23 PM: buildbot version: 28ac1cc020586b1ec2af1c1e9bb64025ce31310b
5:48:23 PM: Fetching cached dependencies
5:48:23 PM: Starting to download cache of 835.1MB
5:48:27 PM: Finished downloading cache in 4.096292423s
5:48:27 PM: Starting to extract cache
5:48:32 PM: Finished extracting cache in 5.051202384s
5:48:32 PM: Finished fetching cache in 9.254377634s
5:48:32 PM: Starting to prepare the repo for build
5:48:33 PM: Preparing Git Reference refs/heads/master
5:48:34 PM: Parsing package.json dependencies
5:48:35 PM: Starting build script
5:48:35 PM: Installing dependencies
5:48:35 PM: Python version set to 2.7
5:48:35 PM: Started restoring cached node version
5:48:37 PM: Finished restoring cached node version
5:48:37 PM: v10.24.1 is already installed.
5:48:38 PM: Now using node v10.24.1 (npm v6.14.12)
5:48:38 PM: Started restoring cached build plugins
5:48:38 PM: Finished restoring cached build plugins
5:48:38 PM: Attempting ruby version 2.6.2, read from environment
5:48:39 PM: Using ruby version 2.6.2
5:48:39 PM: Using PHP version 5.6
5:48:39 PM: Started restoring cached yarn cache
5:48:46 PM: Finished restoring cached yarn cache
5:48:46 PM: No yarn workspaces detected
5:48:46 PM: Started restoring cached node modules
5:48:46 PM: Finished restoring cached node modules
5:48:47 PM: Installing NPM modules using Yarn version 1.17.0
5:48:47 PM: yarn install v1.17.0
5:48:47 PM: [1/4] Resolving packages...
5:48:47 PM: success Already up-to-date.
5:48:47 PM: Done in 0.51s.
5:48:47 PM: NPM modules installed using Yarn
5:48:48 PM: Started restoring cached go cache
5:48:48 PM: Finished restoring cached go cache
5:48:48 PM: Installing Go version 1.12
5:48:48 PM: unset GOOS;
5:48:48 PM: unset GOARCH;
5:48:48 PM: export GOROOT='/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64';
5:48:48 PM: export PATH="/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64/bin:${PATH}";
5:48:48 PM: go version >&2;
5:48:48 PM: export GIMME_ENV='/opt/buildhome/.gimme_cache/env/go1.12.linux.amd64.env';
5:48:48 PM: go version go1.12 linux/amd64
5:48:48 PM: Installing missing commands
5:48:48 PM: Verify run directory
5:48:50 PM: β
5:48:50 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
5:48:50 PM: Netlify Build
5:48:50 PM: β
5:48:50 PM: β― Version
5:48:50 PM: @netlify/build 27.18.6
5:48:50 PM: β
5:48:50 PM: β― Flags
5:48:50 PM: baseRelDir: true
5:48:50 PM: buildId: 633586059687fb1319b565d6
5:48:50 PM: deployId: '633586057214580007549855'
5:48:50 PM: β
5:48:50 PM: β― Current directory
5:48:50 PM: /opt/build/repo
5:48:50 PM: β
5:48:50 PM: β― Config file
5:48:50 PM: No config file was defined: using default values.
5:48:50 PM: β
5:48:50 PM: β― Context
5:48:50 PM: production
5:48:50 PM: β
5:48:50 PM: 1. Build command from Netlify app
5:48:50 PM: β
5:48:50 PM: $ gatsby build
5:48:51 PM: warning
5:48:51 PM: Replace Autoprefixer browsers option to Browserslist config.
5:48:51 PM: Use browserslist key in package.json or .browserslistrc file.
5:48:51 PM:
5:48:51 PM: Using browsers option can cause errors. Browserslist config
5:48:51 PM: can be used for Babel, Autoprefixer, postcss-normalize and other tools.
5:48:51 PM:
5:48:51 PM: If you really need to use option, rename it to overrideBrowserslist.
5:48:51 PM:
5:48:51 PM: Learn more at:
5:48:51 PM: https://github.com/browserslist/browserslist#readme
5:48:51 PM: https://twitter.com/browserslist
5:48:51 PM:
5:48:51 PM:
5:48:51 PM: success open and validate gatsby-configs - 0.221s
5:48:52 PM: success load plugins - 0.487s
5:48:52 PM: success onPreInit - 0.001s
5:48:52 PM: success delete html and css files from previous builds - 0.008s
5:48:52 PM: success initialize cache - 0.004s
5:48:52 PM: success copy gatsby files - 0.016s
5:48:52 PM: success onPreBootstrap - 0.007s
5:48:52 PM: success createSchemaCustomization - 0.003s
5:48:52 PM:
5:48:52 PM: =START PLUGIN=====================================
5:48:52 PM: Site URL: https://admin.esterad.net
5:48:52 PM: Site hosted on Wordpress.com: false
5:48:52 PM: Using ACF: true
5:48:52 PM: Auth: false
5:48:52 PM: Verbose output: true
5:48:52 PM: Mama Route URL: https://admin.esterad.net/index.php/wp-json
5:48:52 PM:
5:48:52 PM: Detected ACF to REST namespace: acf/v2.
5:48:52 PM: Route discovered : /
5:48:52 PM: Excluded route: blacklisted
5:48:52 PM: Route discovered : /oembed/1.0
5:48:52 PM: Route discovered : /oembed/1.0/embed
5:48:52 PM: Route discovered : /oembed/1.0/proxy
5:48:52 PM: Route discovered : /contact-form-7/v1
5:48:52 PM: Excluded route: not whitelisted
5:48:52 PM: Route discovered : /contact-form-7/v1/contact-forms
5:48:52 PM: Route discovered : /contact-form-7/v1/contact-forms/(?P<id>\d+)
5:48:52 PM: Invalid route: detail route
5:48:52 PM: Route discovered : /contact-form-7/v1/contact-forms/(?P<id>\d+)/feedback
5:48:52 PM: Route discovered : /contact-form-7/v1/contact-forms/(?P<id>\d+)/refill
5:48:52 PM: Route discovered : /menus/v1
5:48:52 PM: Route discovered : /menus/v1/menus
5:48:52 PM: Valid route found. Will try to fetch.
5:48:52 PM: Route discovered : /menus/v1/menus/(?P<id>[a-zA-Z0-9_-]+)
5:48:52 PM: Route discovered : /menus/v1/locations/(?P<id>[a-zA-Z0-9_-]+)
5:48:52 PM: Route discovered : /acf/v2
5:48:52 PM: Route discovered : /acf/v2/post/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/page/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/blocks/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/user/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/comment/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/term/(?P<taxonomy>[\w\-\_]+)/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/options/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /acf/v2/media/(?P<id>[\d]+)/?(?P<field>[\w\-\_]+)?
5:48:52 PM: Route discovered : /wpgmza/v1
5:48:52 PM: Route discovered : /wpgmza/v1/maps(\/\d+)?
5:48:52 PM: Route discovered : /wpgmza/v1/markers/\d+
5:48:52 PM: Route discovered : /wpgmza/v1/markers/base64[A-Za-z0-9+\- ]+(={0,3})?(\/[A-Za-z0-9+\- ]+(={0,3})?)?
5:48:52 PM: Route discovered : /wpgmza/v1/markers(\/\d+)?
5:48:52 PM: Route discovered : /wpgmza/v1/datatables
5:48:52 PM: Route discovered : /wpgmza/v1/datatables/base64[A-Za-z0-9+\- ]+(={0,3})?(\/[A-Za-z0-9+\- ]+(={0,3})?)?
5:48:52 PM: Route discovered : /wpgmza/v1/geocode-cache
5:48:52 PM: Route discovered : /wpgmza/v1/geocode-cache/base64[A-Za-z0-9+\- ]+(={0,3})?(\/[A-Za-z0-9+\- ]+(={0,3})?)?
5:48:52 PM: Route discovered : /wpgmza/v1/decompress
5:48:52 PM: Route discovered : /wpgmza/v1/decompress/base64[A-Za-z0-9+\- ]+(={0,3})?(\/[A-Za-z0-9+\- ]+(={0,3})?)?
5:48:52 PM: Route discovered : /wp/v2
5:48:52 PM: Route discovered : /wp/v2/posts
5:48:52 PM: Route discovered : /wp/v2/posts/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/posts/(?P<parent>[\d]+)/revisions
5:48:52 PM: Route discovered : /wp/v2/posts/(?P<parent>[\d]+)/revisions/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/posts/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/posts/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/pages
5:48:52 PM: Route discovered : /wp/v2/pages/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/pages/(?P<parent>[\d]+)/revisions
5:48:52 PM: Route discovered : /wp/v2/pages/(?P<parent>[\d]+)/revisions/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/pages/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/pages/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/media
5:48:52 PM: Route discovered : /wp/v2/media/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/media/(?P<id>[\d]+)/post-process
5:48:52 PM: Route discovered : /wp/v2/blocks
5:48:52 PM: Route discovered : /wp/v2/blocks/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/blocks/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/blocks/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/slider_directors
5:48:52 PM: Route discovered : /wp/v2/slider_directors/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/slider_directors/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/slider_directors/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/slider_managers
5:48:52 PM: Route discovered : /wp/v2/slider_managers/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/slider_managers/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/slider_managers/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/assets
5:48:52 PM: Route discovered : /wp/v2/assets/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/assets/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/assets/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/reports
5:48:52 PM: Route discovered : /wp/v2/reports/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/reports/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/reports/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/press_releases
5:48:52 PM: Route discovered : /wp/v2/press_releases/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/press_releases/(?P<id>[\d]+)/autosaves
5:48:52 PM: Route discovered : /wp/v2/press_releases/(?P<parent>[\d]+)/autosaves/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/types
5:48:52 PM: Route discovered : /wp/v2/types/(?P<type>[\w-]+)
5:48:52 PM: Route discovered : /wp/v2/statuses
5:48:52 PM: Route discovered : /wp/v2/statuses/(?P<status>[\w-]+)
5:48:52 PM: Route discovered : /wp/v2/taxonomies
5:48:52 PM: Route discovered : /wp/v2/taxonomies/(?P<taxonomy>[\w-]+)
5:48:52 PM: Route discovered : /wp/v2/categories
5:48:52 PM: Route discovered : /wp/v2/categories/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/tags
5:48:52 PM: Route discovered : /wp/v2/tags/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/users
5:48:52 PM: Route discovered : /wp/v2/users/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/users/me
5:48:52 PM: Route discovered : /wp/v2/comments
5:48:52 PM: Route discovered : /wp/v2/comments/(?P<id>[\d]+)
5:48:52 PM: Route discovered : /wp/v2/search
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>gutenberg-wpgmza/block)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/archives)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/block)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/calendar)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/categories)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/latest-comments)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/latest-posts)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/rss)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/search)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/shortcode)
5:48:52 PM: Route discovered : /wp/v2/block-renderer/(?P<name>core/tag-cloud)
5:48:52 PM: Route discovered : /wp/v2/settings
5:48:52 PM: Route discovered : /wp/v2/themes
5:48:52 PM:
5:48:52 PM: Fetching the JSON data from 9 valid API Routes...
5:48:52 PM:
5:48:52 PM: === [ Fetching wordpress__acf_options ] === https://admin.esterad.net/index.php/wp-json/acf/v2/options/
5:48:53 PM: -> wordpress__acf_options fetched : 1
5:48:53 PM: Fetching the wordpress__acf_options took: 561.442ms
5:48:53 PM: β
5:48:53 PM: === [ Fetching wordpress__menus_menus ] === https://admin.esterad.net/index.php/wp-json/menus/v1/menus
5:48:53 PM: === [ Fetching wordpress__menus_menus_items ] === https://admin.esterad.net/index.php/wp-json/menus/v1/menus/9
5:48:54 PM: -> wordpress__menus_menus_items fetched : 1
5:48:54 PM: Fetching the wordpress__menus_menus_items took: 477.685ms
5:48:54 PM: === [ Fetching wordpress__menus_menus_items ] === https://admin.esterad.net/index.php/wp-json/menus/v1/menus/10
5:48:54 PM: Fetching the wordpress__menus_menus_items took: 589.608ms
5:48:54 PM: -> wordpress__menus_menus fetched : 2
5:48:54 PM: Fetching the wordpress__menus_menus took: 1713.995ms
5:48:54 PM: β
5:48:54 PM: === [ Fetching wordpress__POST ] === https://admin.esterad.net/index.php/wp-json/wp/v2/posts
5:48:55 PM: -> wordpress__POST fetched : 48
5:48:55 PM: Fetching the wordpress__POST took: 968.891ms
5:48:55 PM: β
5:48:55 PM: === [ Fetching wordpress__PAGE ] === https://admin.esterad.net/index.php/wp-json/wp/v2/pages
5:48:57 PM: -> wordpress__PAGE fetched : 20
5:48:57 PM: Fetching the wordpress__PAGE took: 1572.257ms
5:48:57 PM: β
5:48:57 PM: === [ Fetching wordpress__wp_slider_directors ] === https://admin.esterad.net/index.php/wp-json/wp/v2/slider_directors
5:48:58 PM: -> wordpress__wp_slider_directors fetched : 16
5:48:58 PM: Fetching the wordpress__wp_slider_directors took: 627.214ms
5:48:58 PM: β
5:48:58 PM: === [ Fetching wordpress__wp_slider_managers ] === https://admin.esterad.net/index.php/wp-json/wp/v2/slider_managers
5:48:58 PM: -> wordpress__wp_slider_managers fetched : 12
5:48:58 PM: Fetching the wordpress__wp_slider_managers took: 524.894ms
5:48:58 PM: β
5:48:58 PM: === [ Fetching wordpress__wp_assets ] === https://admin.esterad.net/index.php/wp-json/wp/v2/assets
5:48:59 PM: -> wordpress__wp_assets fetched : 3
5:48:59 PM: Fetching the wordpress__wp_assets took: 465.099ms
5:48:59 PM: β
5:48:59 PM: === [ Fetching wordpress__wp_reports ] === https://admin.esterad.net/index.php/wp-json/wp/v2/reports
5:48:59 PM:
5:48:59 PM: Total entities : 118
5:48:59 PM: Pages to be requested : 2
5:49:00 PM: -> wordpress__wp_reports fetched : 118
5:49:00 PM: Fetching the wordpress__wp_reports took: 1296.515ms
5:49:00 PM: β
5:49:00 PM: === [ Fetching wordpress__wp_press_releases ] === https://admin.esterad.net/index.php/wp-json/wp/v2/press_releases
5:49:00 PM: -> wordpress__wp_press_releases fetched : 53
5:49:00 PM: Fetching the wordpress__wp_press_releases took: 571.655ms
5:49:00 PM: β
5:49:00 PM: =END PLUGIN=====================================: 8891.486ms
5:49:01 PM: success source and transform nodes - 9.093s
5:49:02 PM: warning There are conflicting field types in your data.
5:49:02 PM: If you have explicitly defined a type for those fields, you can safely ignore this warning message.
5:49:02 PM: Otherwise, Gatsby will omit those fields from the GraphQL schema.
5:49:02 PM: If you know all field types in advance, the best strategy is to explicitly define them with the `createTypes` action, and skip inference with the `@dontInfer` directive.
5:49:02 PM: See https://www.gatsbyjs.org/docs/actions/#createTypes
5:49:02 PM: wordpress__wp_slider_managers.acf.director_image:
5:49:02 PM: - type: boolean
5:49:02 PM: value: false
5:49:02 PM: - type: object
5:49:02 PM: value: { wordpress_id: 304, title: 'Hanan-Abdulghani', filename: 'Hanan-Abdulghani-scaled.jpg', filesize: 193788, url: 'https://admin.esterad.net/wp-content/uploads/2020/03/Hanan-Abdulghani-scaled.jpg', link: 'https://admin.esterad.net/index.php/about-us-main-section/hanan-abdulghani/', alt: '', author: '1', description: '', caption: '', name: 'hanan-abdulghani', status: 'inherit', uploaded_to: 50, date: '2020-03-27 16:10:49', modified: '2020-03-27 16:10:49', menu_order: 0, mime_type: 'image/jpeg', type: 'image', subtype: 'jpeg', icon: 'https://admin.esterad.net/wp-includes/images/media/default.png', width: 2560, height: 1707, sizes: [Object] }
5:49:02 PM: success building schema - 1.337s
5:49:02 PM: success createPages - 0.080s
5:49:02 PM: success createPagesStatefully - 0.099s
5:49:02 PM: success onPreExtractQueries - 0.000s
5:49:02 PM: success update schema - 0.029s
5:49:03 PM: error There was an error in your GraphQL query:
5:49:03 PM: Cannot query field "director_image" on type "wordpress__wp_slider_managersAcf".
5:49:03 PM: If you don't expect "director_image" to exist on the type "wordpress__wp_slider_managersAcf" it is most likely a typo.However, if you expect "director_image" to exist there are a couple of solutions to common problems:
5:49:03 PM: - If you added a new data source and/or changed something inside gatsby-node.js/gatsby-config.js, please try a restart of your development server
5:49:03 PM: - The field might be accessible in another subfield, please try your query in GraphiQL and use the GraphiQL explorer to see which fields you can query and what shape they have
5:49:03 PM: - You want to optionally use your field "director_image" and right now it is not used anywhere. Therefore Gatsby can't infer the type and add it to the GraphQL schema. A quick fix is to add a least one entry with that field ("dummy content")
5:49:03 PM: It is recommended to explicitly type your GraphQL schema if you want to use optional fields. This way you don't have to add the mentioned "dummy content". Visit our docs to learn how you can define the schema for "wordpress__wp_slider_managersAcf":https://www.gatsbyjs.org/docs/schema-customization/#creating-type-definitions
5:49:03 PM: failed extract queries from components - 0.568s
5:49:03 PM: β
5:49:03 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
5:49:03 PM: "build.command" failed
5:49:03 PM: β
5:49:03 PM: Error message
5:49:03 PM: Command failed with exit code 1: gatsby build (https://ntl.fyi/exit-code-1)
5:49:03 PM: β
5:49:03 PM: Error location
5:49:03 PM: In Build command from Netlify app:
5:49:03 PM: gatsby build
5:49:03 PM: β
5:49:03 PM: Resolved config
5:49:03 PM: build:
5:49:03 PM: command: gatsby build
5:49:03 PM: commandOrigin: ui
5:49:03 PM: environment:
5:49:03 PM: - INCOMING_HOOK_BODY
5:49:03 PM: - INCOMING_HOOK_TITLE
5:49:03 PM: - INCOMING_HOOK_URL
5:49:03 PM: publish: /opt/build/repo/public
5:49:03 PM: publishOrigin: ui
5:49:03 PM: Caching artifacts
5:49:03 PM: Started saving node modules
5:49:03 PM: Finished saving node modules
5:49:03 PM: Started saving build plugins
5:49:03 PM: Finished saving build plugins
5:49:03 PM: Started saving yarn cache
5:49:06 PM: Finished saving yarn cache
5:49:06 PM: Started saving pip cache
5:49:06 PM: Finished saving pip cache
5:49:06 PM: Started saving emacs cask dependencies
5:49:06 PM: Finished saving emacs cask dependencies
5:49:06 PM: Started saving maven dependencies
5:49:06 PM: Finished saving maven dependencies
5:49:06 PM: Started saving boot dependencies
5:49:06 PM: Finished saving boot dependencies
5:49:06 PM: Started saving rust rustup cache
5:49:06 PM: Finished saving rust rustup cache
5:49:06 PM: Started saving go dependencies
5:49:07 PM: Finished saving go dependencies
5:49:07 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
5:49:07 PM: Creating deploy upload records
5:49:07 PM: Failing build: Failed to build site
5:49:07 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
5:49:07 PM: Finished processing build request in 44.119687174s
