I am trying to publish my game, and i run it using npm run start. It said server started, but the link doesnt work and it still says building. this is the build log:
9:10:13 PM: build-image version: f0de447600c93198b2eef6ed4ec8e338d9c0582c (focal)
9:10:13 PM: buildbot version: f0de447600c93198b2eef6ed4ec8e338d9c0582c
9:10:13 PM: Building without cache
9:10:13 PM: Starting to prepare the repo for build
9:10:14 PM: No cached dependencies found. Cloning fresh repo
9:10:14 PM: git clone --filter=blob:none git@bitbucket.org:noodlesnomm/spicywars
9:10:15 PM: Preparing Git Reference refs/heads/master
9:10:15 PM: Parsing package.json dependencies
9:10:17 PM: Starting to install dependencies
9:10:17 PM: v16.20.0 is already installed.
9:10:18 PM: Now using node v16.20.0 (npm v8.19.4)
9:10:18 PM: Enabling Node.js Corepack
9:10:18 PM: Started restoring cached build plugins
9:10:18 PM: Finished restoring cached build plugins
9:10:18 PM: Started restoring cached corepack dependencies
9:10:18 PM: Finished restoring cached corepack dependencies
9:10:18 PM: No npm workspaces detected
9:10:18 PM: Started restoring cached node modules
9:10:18 PM: Finished restoring cached node modules
9:10:18 PM: Installing npm packages using npm version 8.19.4
9:10:30 PM: added 330 packages, and audited 331 packages in 12s
9:10:30 PM: 52 packages are looking for funding
9:10:30 PM: run npm fund for details
9:10:30 PM: found 0 vulnerabilities
9:10:30 PM: npm packages installed
9:10:30 PM: Attempting Ruby version 2.7.2, read from environment
9:10:31 PM: Using Ruby version 2.7.2
9:10:32 PM: Started restoring cached go cache
9:10:32 PM: Finished restoring cached go cache
9:10:32 PM: Installing Go version 1.19.5 (requested 1.19.5)
9:10:38 PM: go version go1.19.5 linux/amd64
9:10:38 PM: Using PHP version 8.0
9:10:39 PM: Python version set to 3.8
9:10:40 PM: Install dependencies script success
9:10:40 PM: Starting build script
9:10:40 PM: Using stage install dependencies
9:10:41 PM: Detected 0 framework(s)
9:10:41 PM: Section completed: initializing
9:10:42 PM:
9:10:42 PM: Netlify Build
9:10:42 PM: ────────────────────────────────────────────────────────────────
9:10:42 PM:
9:10:42 PM: ❯ Version
9:10:42 PM: @netlify/build 29.9.0
9:10:42 PM:
9:10:42 PM: ❯ Flags
9:10:42 PM: baseRelDir: true
9:10:42 PM: buildId: 642cd881b993e42e50da3b1f
9:10:42 PM: deployId: 642cd881b993e42e50da3b21
9:10:42 PM:
9:10:42 PM: ❯ Current directory
9:10:42 PM: /opt/build/repo
9:10:42 PM:
9:10:42 PM: ❯ Config file
9:10:42 PM: No config file was defined: using default values.
9:10:42 PM:
9:10:42 PM: ❯ Context
9:10:42 PM: production
9:10:42 PM:
9:10:42 PM: 1. Build command from Netlify app
9:10:42 PM:
9:10:42 PM: $ npm install --include=dev && npm run start && npm run prod
9:10:43 PM: up to date, audited 331 packages in 520ms
9:10:43 PM: 52 packages are looking for funding
9:10:43 PM: run npm fund for details
9:10:43 PM: found 0 vulnerabilities
9:10:43 PM: > waterwar.io@1.0.0 start
9:10:43 PM: > node index.js --unhandled-rejections=strict
9:10:43 PM: server started
