Build from Nuxt 3. This works fine in local dev but not in production with Netlify.
site name = https://spoondog1.netlify.app/
log
8:37:40 PM: build-image version: 6724b7f630462a3bda7629c0c4b9c485399606e3 (noble)
8:37:40 PM: buildbot version: 6724b7f630462a3bda7629c0c4b9c485399606e3
8:37:40 PM: Fetching cached dependencies
8:37:40 PM: Starting to download cache of 523.0MB
8:37:42 PM: Finished downloading cache in 2.708s
8:37:42 PM: Starting to extract cache
8:37:50 PM: Finished extracting cache in 8.118s
8:37:51 PM: Finished fetching cache in 10.951s
8:37:51 PM: Starting to prepare the repo for build
8:37:51 PM: Preparing Git Reference refs/heads/master
8:37:56 PM: Starting to install dependencies
8:37:56 PM: Started restoring cached mise cache
8:37:58 PM: Finished restoring cached mise cache
8:38:00 PM: Python version set to 3.13.1
8:38:00 PM: Ruby version set to 2.7.2
8:38:00 PM: Go version set to 1.19
8:38:02 PM: Using PHP version 8.3
8:38:03 PM: Started restoring cached Node.js version
8:38:16 PM: Finished restoring cached Node.js version
8:38:17 PM: v18.20.6 is already installed.
8:38:17 PM: Now using node v18.20.6 (npm v10.8.2)
8:38:17 PM: Enabling Node.js Corepack
8:38:17 PM: Started restoring cached build plugins
8:38:17 PM: Finished restoring cached build plugins
8:38:17 PM: Started restoring cached corepack dependencies
8:38:17 PM: Finished restoring cached corepack dependencies
8:38:17 PM: No npm workspaces detected
8:38:17 PM: Started restoring cached node modules
8:38:17 PM: Finished restoring cached node modules
8:38:17 PM: Installing npm packages using npm version 10.8.2
8:38:18 PM: > postinstall
8:38:18 PM: > nuxt prepare
8:38:20 PM: [info] [nuxt:tailwindcss] Using default Tailwind CSS file
8:38:20 PM: [success] Types generated in .nuxt
8:38:20 PM: up to date, audited 777 packages in 4s
8:38:20 PM: 142 packages are looking for funding
8:38:20 PM: run npm fund for details
8:38:21 PM: 3 moderate severity vulnerabilities
8:38:21 PM: To address all issues, run:
8:38:21 PM: npm audit fix
8:38:21 PM: Run npm audit for details.
8:38:21 PM: npm packages installed
8:38:21 PM: Successfully installed dependencies
8:38:21 PM: Starting build script
8:38:22 PM: Detected 1 framework(s)
8:38:22 PM: “nuxt” at version “3.14.1592”
8:38:22 PM: Section completed: initializing
8:38:23 PM:
8:38:23 PM: Netlify Build
8:38:23 PM: ────────────────────────────────────────────────────────────────
8:38:23 PM:
8:38:23 PM: ❯ Version
8:38:23 PM: @netlify/build 29.58.7
8:38:23 PM:
8:38:23 PM: ❯ Flags
8:38:23 PM: accountId: 5ea865e9a812c5ee5f6b94e8
8:38:23 PM: baseRelDir: true
8:38:23 PM: buildId: 67985f022b55690008df8f54
8:38:23 PM: deployId: 67985f022b55690008df8f56
8:38:23 PM:
8:38:23 PM: ❯ Current directory
8:38:23 PM: /opt/build/repo
8:38:23 PM:
8:38:23 PM: ❯ Config file
8:38:23 PM: No config file was defined: using default values.
8:38:23 PM:
8:38:23 PM: ❯ Context
8:38:23 PM: production
8:38:23 PM:
8:38:23 PM: Build command from Netlify app
8:38:23 PM:
8:38:23 PM: $ npm run build
8:38:23 PM: > build
8:38:23 PM: > nuxt build
8:38:23 PM: [log] Nuxt 3.14.1592 with Nitro 2.10.4
8:38:24 PM: [info] [nuxt:tailwindcss] Using default Tailwind CSS file
8:38:28 PM: [info] Building client…
8:38:28 PM: [info] vite v5.4.11 building for production…
8:38:28 PM: [info] transforming…
8:38:31 PM: [info] ✓ 247 modules transformed.
8:38:31 PM: [info] rendering chunks…
8:38:31 PM: [info] computing gzip size…
8:38:31 PM: [info] .nuxt/dist/client/manifest.json 6.09 kB │ gzip: 0.92 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/error-500.D6506J9O.css 1.88 kB │ gzip: 0.72 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/error-404.CoZKRZXM.css 3.56 kB │ gzip: 1.10 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/D9NqpCXp.js 0.08 kB │ gzip: 0.10 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/BjtlJphd.js 0.11 kB │ gzip: 0.13 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/DOyfU2Nh.js 0.15 kB │ gzip: 0.14 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/BkvQJAQ2.js 0.29 kB │ gzip: 0.24 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/CZbcM7XG.js 0.38 kB │ gzip: 0.26 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/CIW9t6mo.js 0.63 kB │ gzip: 0.43 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/C07-RB6O.js 0.68 kB │ gzip: 0.46 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/-5NCR7vS.js 0.96 kB │ gzip: 0.54 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/DGbytaXN.js 1.13 kB │ gzip: 0.67 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/C8VnLpLj.js 1.65 kB │ gzip: 0.82 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/DBWdO0Ve.js 1.94 kB │ gzip: 0.94 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/mATisk3V.js 2.23 kB │ gzip: 1.18 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/BbzxWaIy.js 2.38 kB │ gzip: 1.08 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/S_GBAO7H.js 2.47 kB │ gzip: 1.29 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/B7TfInFX.js 2.57 kB │ gzip: 0.98 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/DyP9Z1Lt.js 2.77 kB │ gzip: 1.02 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/C8yPB7tN.js 2.95 kB │ gzip: 1.13 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/BsyvXpbl.js 3.41 kB │ gzip: 1.54 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/BoKt4OYa.js 3.78 kB │ gzip: 1.71 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/ptRO3GDS.js 5.46 kB │ gzip: 1.50 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/D-no9nQU.js 5.61 kB │ gzip: 2.19 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/Bv2Sx9oe.js 6.04 kB │ gzip: 1.81 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/6Oel1ieb.js 13.39 kB │ gzip: 5.46 kB
8:38:31 PM: [info] .nuxt/dist/client/_nuxt/DGxBlohD.js 283.63 kB │ gzip: 95.76 kB
8:38:31 PM: [info] ✓ built in 3.09s
8:38:31 PM: [success] Client built in 3102ms
8:38:31 PM: [info] Building server…
8:38:31 PM: [info] vite v5.4.11 building SSR bundle for production…
8:38:31 PM: [info] transforming…
8:38:32 PM: [info] ✓ 101 modules transformed.
8:38:32 PM: [info] rendering chunks…
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/entry-styles.CFp_6I-K.mjs 0.08 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/newNav-styles.D89c9XqF.mjs 0.08 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-404-styles.DRLC0U6S.mjs 0.08 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-500-styles.DqmriZ_b.mjs 0.08 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/newNav-styles.BwEKMaMK.mjs 0.15 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-404-styles.BcoFjqgl.mjs 0.15 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-500-styles.DPP87-Dp.mjs 0.15 kB
8:38:32 PM: [info] .nuxt/dist/server/styles.mjs 1.06 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/newNav-styles-1.mjs-DeLSb0Dw.js 0.20 kB │ map: 0.11 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/useSupabaseClient-DykwVqLQ.js 0.22 kB │ map: 0.41 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/auth-BoVcqNpM.js 0.59 kB │ map: 0.42 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/custom-CuEFzY0q.js 0.93 kB │ map: 0.32 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/index-BabADJUJ.js 0.98 kB │ map: 6.88 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/default ver1-Dhq31_dJ.js 1.62 kB │ map: 0.91 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/default-DZk-EFA-.js 1.68 kB │ map: 0.99 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-500-styles-1.mjs-DiWYPNRc.js 2.10 kB │ map: 0.12 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/tableReports-BQtR7FBs.js 2.30 kB │ map: 0.16 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/addtReport-6KGe-5Ny.js 2.82 kB │ map: 4.20 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/sorry-B4-nFoJJ.js 3.04 kB │ map: 1.94 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/login-CfsIRaPS.js 3.21 kB │ map: 4.29 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/search-CvGzq5aF.js 3.42 kB │ map: 3.21 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/logout-nesy1vEx.js 3.56 kB │ map: 2.62 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-404-styles-1.mjs-D8Sw_W7I.js 3.80 kB │ map: 0.12 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/casinosList-ClXiON-t.js 4.25 kB │ map: 3.17 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/newNav-DIitpBpn.js 4.45 kB │ map: 4.14 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-500-BvA52b9J.js 4.63 kB │ map: 5.35 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/searchchoose-tiYd1gFW.js 5.41 kB │ map: 4.20 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/error-404-CziwfTnz.js 5.52 kB │ map: 7.10 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/tableChoose-CTV34RvS.js 5.92 kB │ map: 4.40 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/register-DO2oht7l.js 6.06 kB │ map: 6.15 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/index-DZIAYvPS.js 7.14 kB │ map: 10.22 kB
8:38:32 PM: [info] .nuxt/dist/server/_nuxt/fetch-SDTQ1-6y.js 8.81 kB │ map: 19.88 kB
8:38:32 PM: [info] .nuxt/dist/server/nuxt/nuxt-link-C7UjBX0B.js 10.25 kB │ map: 21.69 kB
8:38:32 PM: [info] .nuxt/dist/server/nuxt/entry-styles-1.mjs-Bxo5iz6B.js 37.82 kB │ map: 0.11 kB
8:38:32 PM: [info] .nuxt/dist/server/server.mjs 50.43 kB │ map: 120.44 kB
8:38:32 PM: [info] ✓ built in 1.34s
8:38:32 PM: [success] Server built in 1346ms
8:38:32 PM: [success] [nitro] Generated public dist
8:38:32 PM: [info] [nitro] Building Nuxt Nitro server (preset: netlify, compatibility date: 2024-11-01)
8:38:35 PM: [success] [nitro] Nuxt Nitro server built
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks//error-500.mjs (4.77 kB) (2.02 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks//error-500.mjs.map (193 B) (157 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/addtReport-6KGe-5Ny.mjs (2.8 kB) (968 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/addtReport-6KGe-5Ny.mjs.map (308 B) (200 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/auth-BoVcqNpM.mjs (667 B) (328 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/auth-BoVcqNpM.mjs.map (301 B) (203 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/casinosList-ClXiON-t.mjs (4.31 kB) (1.75 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/casinosList-ClXiON-t.mjs.map (423 B) (237 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/client.manifest.mjs (8.2 kB) (1.01 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/client.manifest.mjs.map (7.36 kB) (629 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/custom-CuEFzY0q.mjs (1.01 kB) (484 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/custom-CuEFzY0q.mjs.map (227 B) (159 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/default ver1-Dhq31_dJ.mjs (1.7 kB) (799 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/default ver1-Dhq31_dJ.mjs.map (479 B) (226 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/default-DZk-EFA-.mjs (1.76 kB) (831 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/default-DZk-EFA-.mjs.map (524 B) (244 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/entry-styles.CFp_6I-K.mjs (37.9 kB) (7.13 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/entry-styles.CFp_6I-K.mjs.map (210 B) (164 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-CziwfTnz.mjs (5.6 kB) (2.24 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-CziwfTnz.mjs.map (199 B) (165 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles-1.mjs-D8Sw_W7I.mjs (3.79 kB) (1.22 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles-1.mjs-D8Sw_W7I.mjs.map (122 B) (125 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles.BcoFjqgl.mjs (373 B) (209 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles.BcoFjqgl.mjs.map (241 B) (178 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles.DRLC0U6S.mjs (315 B) (205 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-404-styles.DRLC0U6S.mjs.map (219 B) (169 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-BvA52b9J.mjs (4.71 kB) (1.94 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-BvA52b9J.mjs.map (199 B) (167 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles-1.mjs-DiWYPNRc.mjs (2.09 kB) (836 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles-1.mjs-DiWYPNRc.mjs.map (122 B) (124 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles.DPP87-Dp.mjs (371 B) (210 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles.DPP87-Dp.mjs.map (241 B) (179 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles.DqmriZ_b.mjs (315 B) (204 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/error-500-styles.DqmriZ_b.mjs.map (219 B) (165 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/fetch-SDTQ1-6y.mjs (8.66 kB) (2.52 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/fetch-SDTQ1-6y.mjs.map (278 B) (191 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/index-BabADJUJ.mjs (978 B) (455 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/index-BabADJUJ.mjs.map (256 B) (180 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/index-DZIAYvPS.mjs (7.22 kB) (2.02 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/index-DZIAYvPS.mjs.map (856 B) (320 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/login-CfsIRaPS.mjs (3.29 kB) (1.24 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/login-CfsIRaPS.mjs.map (646 B) (276 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/logout-nesy1vEx.mjs (3.64 kB) (1.29 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/logout-nesy1vEx.mjs.map (364 B) (195 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-DIitpBpn.mjs (4.45 kB) (1.21 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-DIitpBpn.mjs.map (3.35 kB) (764 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles-1.mjs-DeLSb0Dw.mjs (198 B) (151 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles-1.mjs-DeLSb0Dw.mjs.map (119 B) (121 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles.BwEKMaMK.mjs (357 B) (206 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles.BwEKMaMK.mjs.map (235 B) (177 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles.D89c9XqF.mjs (301 B) (202 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/newNav-styles.D89c9XqF.mjs.map (213 B) (166 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/nuxt-link-C7UjBX0B.mjs (10.4 kB) (2.77 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/nuxt-link-C7UjBX0B.mjs.map (276 B) (186 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/register-DO2oht7l.mjs (6.14 kB) (1.52 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/register-DO2oht7l.mjs.map (774 B) (289 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/search-CvGzq5aF.mjs (3.48 kB) (1.55 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/search-CvGzq5aF.mjs.map (633 B) (305 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/searchchoose-tiYd1gFW.mjs (5.49 kB) (1.57 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/searchchoose-tiYd1gFW.mjs.map (2.29 kB) (570 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/server.mjs (50.4 kB) (12.8 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/server.mjs.map (3.58 kB) (878 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/sorry-B4-nFoJJ.mjs (3.12 kB) (1.23 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/sorry-B4-nFoJJ.mjs.map (1.47 kB) (504 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/styles.mjs (1.08 kB) (380 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/styles.mjs.map (702 B) (248 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/tableChoose-CTV34RvS.mjs (6 kB) (1.67 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/tableChoose-CTV34RvS.mjs.map (2.61 kB) (615 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/tableReports-BQtR7FBs.mjs (2.38 kB) (933 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/tableReports-BQtR7FBs.mjs.map (171 B) (117 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/useSupabaseClient-DykwVqLQ.mjs (218 B) (170 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/build/useSupabaseClient-DykwVqLQ.mjs.map (231 B) (185 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/nitro/nitro.mjs (166 kB) (40.1 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/nitro/nitro.mjs.map (3.2 kB) (764 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/casinos.mjs (472 B) (278 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/casinos.mjs.map (402 B) (206 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/query.mjs (887 B) (355 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/query.mjs.map (712 B) (253 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/t_Reports.mjs (1.62 kB) (672 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/api/t_Reports.mjs.map (1.36 kB) (555 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/renderer.mjs (13.2 kB) (4.24 kB gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/routes/renderer.mjs.map (368 B) (214 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/virtual/_virtual_spa-template.mjs (94 B) (100 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/chunks/virtual/_virtual_spa-template.mjs.map (112 B) (111 B gzip)
8:38:35 PM: ├─ .netlify/functions-internal/server/main.mjs (267 B) (182 B gzip)
8:38:35 PM: └─ .netlify/functions-internal/server/package.json (1.04 kB) (465 B gzip)
8:38:35 PM: Σ Total size: 3.1 MB (787 kB gzip)
8:38:35 PM:
8:38:35 PM: (build.command completed in 12s)
8:38:35 PM:
8:38:35 PM: Functions bundling
8:38:35 PM: ────────────────────────────────────────────────────────────────
8:38:35 PM:
8:38:35 PM: Packaging Functions from .netlify/functions-internal directory:
8:38:35 PM: - server/server.mjs
8:38:35 PM:
8:38:38 PM:
8:38:38 PM: (Functions bundling completed in 2.6s)
8:38:38 PM:
8:38:38 PM: Deploy site
8:38:38 PM: ────────────────────────────────────────────────────────────────
8:38:38 PM:
8:38:38 PM: Starting to deploy site from ‘dist’
8:38:38 PM: Calculating files to upload
8:38:38 PM: 2 new file(s) to upload
8:38:38 PM: 1 new function(s) to upload
8:38:45 PM: Starting post processing
8:38:45 PM: Skipping form detection
8:38:45 PM: Post processing - header rules
8:38:45 PM: Post processing - redirect rules
8:38:45 PM: Post processing done
8:38:45 PM: Section completed: postprocessing
8:38:45 PM: Section completed: deploying
8:38:45 PM: Site deploy was successfully initiated
8:38:45 PM:
8:38:45 PM: (Deploy site completed in 7.7s)
8:38:45 PM:
8:38:45 PM: Netlify Build Complete
8:38:45 PM: ────────────────────────────────────────────────────────────────
8:38:45 PM:
8:38:45 PM: (Netlify Build completed in 22.5s)
8:38:46 PM: Site is live ![]()
8:38:46 PM: Caching artifacts
8:38:46 PM: Started saving node modules
8:38:46 PM: Finished saving node modules
8:38:46 PM: Started saving build plugins
8:38:46 PM: Finished saving build plugins
8:38:46 PM: Started saving mise cache
8:38:46 PM: Finished saving mise cache
8:38:46 PM: Started saving corepack cache
8:38:46 PM: Finished saving corepack cache
8:38:46 PM: Started saving emacs cask dependencies
8:38:46 PM: Finished saving emacs cask dependencies
8:38:46 PM: Started saving maven dependencies
8:38:46 PM: Finished saving maven dependencies
8:38:46 PM: Started saving boot dependencies
8:38:46 PM: Finished saving boot dependencies
8:38:46 PM: Started saving rust rustup cache
8:38:46 PM: Finished saving rust rustup cache
8:38:46 PM: Build script success
8:38:46 PM: Section completed: building
8:39:22 PM: Uploading Cache of size 523.1MB
8:39:23 PM: Section completed: cleanup
8:39:23 PM: Finished processing build request in 1m43.805s
