Hello,
I’m having an issue with a Vue.js SPA where I have a _redirects
file, under the public directory, with the following content:
/* /index.html 200
When I add a netlify.toml
to load a serverless function, the redirect doesn’t work anymore.
I tried to add the redirect in the TOML file like so:
[[redirects]]
from = "https://vue-and-supabase-boilerplate-demo.netlify.app"
to = "https://vue-and-supabase-boilerplate-demo.netlify.app/index.html"
status = 200
force = true
It didn’t work.
If I remove the TOML file, the redirect works again.
What’s the catch?
Thanks.
As I understand it the rule in the _redirects
file should be taking precedence, based on:
https://docs.netlify.com/routing/redirects/#rule-processing-order
The redirects engine will process the first matching rule it finds, reading from top to bottom. Rules in the _redirects
file are always processed first, followed by rules in the Netlify configuration file.
To make it clearer for yourself, if I were you I’d put all the rules in one or the other.
If you’re trying to write the same _redirects
rule in the netlify.toml
, it’d be:
[[redirects]]
from = "/*"
to = "/index.html"
status = 200
Which is shown in the documentation here if you click the netlify.toml file
tab:
https://docs.netlify.com/routing/redirects/rewrites-proxies/#history-pushstate-and-single-page-apps
For some reason, it doesn’t work. I removed the /public/_redirects
and add the redirect in the TOML file as described.
I see that there is a rule picked up, it doesn’t solve the pb of http 404.
What 404?
What URL are you having an issue with?
If the site is the one you originally linked, it seems to be working, e.g.
https://vue-and-supabase-boilerplate-demo.netlify.app/this/route/does/not/exist
You see that it is working because I’ve reverted back to using public/_redirects
solution.
When I had the netlify.toml and the rule defined into it (and deleted the _redirects
file of course), any URL, as well as the base URL https://vue-and-supabase-boilerplate-demo.netlify.app/
, didn’t work: I was getting the Netlify “Page doesn’t exist” page.
But, I’ve found the issue: I had this in the TOML file:
[build]
publish = "public"
The Vue app is published to dist
… So problem solved.
It was a relica from another of my apps I copied the TOML file from.
Your participation helped me see the issue
Makes sense, you were accidentally changing which files you were publishing.
I’d not have been able to get that from the minimal details provided.
