This is an advanced topic, that has a fairly simple solution if/when using Rust for our Netlify functions.
Using AWS Cargo Lambda
Netlify has a solution for compiling your functions during build using a cross compile target (x86_64-unknown-linux-musl) which is a minimal C library. This uses the cargo compiler by default for simplified cross-compilation. A really complete compiler is to use Zig which has many advantages, so AWS Lambda uses it in their cli tool to compile using cargo-zigbuild for compile of lambda functions in Rust.
Once you run into errors with linking due to cross-compile issues, you will need to consider this solution.
You can use cargo-zigbuild yourself, but cargo-lambda has some great features and will simplify the setup and will be maintained by the aws group. Remember cargo-lambda is using cargo-zigbuild under the hood, so you are just getting the added benefit and features. Also, I haven’t confirmed, but my binaries seemed to be smaller.
Requirements
- cargo-lambda (install with homebrew)
- Zig (of course)
- nasm (if required)
What I needed
- libpq (postgress client needed if using postgres in your lambda)
Building and placing your assets for deploy
Note: We need to make sure we setup our Netlify functions to use a Rust compatible runtime on AWS. Setup the environment variable in the netlify UI (app.netlify.com) to tell Netlify to use the correct runtime for the lambda: AWS_LAMBDA_JS_RUNTIME= provided.al2023 This is an OS-only runtime used for runtime interface to Rust.
We are going to compile our lambda using a script and it will create the .zip bundle for deploy
#!/bin/bash
# https://vaneyckt.io/posts/safer_bash_scripts_with_set_euxo_pipefail/
set -euxo pipefail
mkdir -p netlify/functions
# cargo lambda build --release --output-format Zip
cargo lambda build -p hello --release --output-format zip --include netlify-toolchain
# add copy commands as you add functions
cp target/lambda/hello/bootstrap.zip netlify/functions/hello.zip
The netlify-toolchain file might not be required, but I include it because Netlify includes it in theirs.
netlify-toolchain
{"runtime":"rs"}
This can all be done with cargo-zigbuld and zip the files yourself, but cargo-lambda makes it easier.
