Command failed with exit code 2: CI= yarn build (https://ntl.fyi/exit-code-2)
Hello,
I’m facing a build error when deploying my vite+react+ts frontend Rosko Suite.
7:02:37 PM: ​
7:02:37 PM: $ CI= yarn build
7:02:37 PM: yarn run v1.22.19
7:02:37 PM: $ tsc && vite build
7:02:39 PM: src/core/router/routes.ts(7,43): error TS2307: Cannot find module ‘…/…/presentation/app/login’ or its corresponding type declarations.
7:02:39 PM: src/core/router/routes.ts(27,3): error TS2322: Type ‘LazyExoticComponent<ComponentType>’ is not assignable to type ‘LazyExoticComponent<() => Element>’.
7:02:39 PM: Type ‘LazyExoticComponent<ComponentType>’ is not assignable to type ‘{ readonly _result: () => Element; }’.
7:02:39 PM: Types of property ‘_result’ are incompatible.
7:02:39 PM: Type ‘ComponentType’ is not assignable to type ‘() => Element’.
7:02:39 PM: Type ‘ComponentClass<any, any>’ is not assignable to type ‘() => Element’.
7:02:39 PM: Type ‘ComponentClass<any, any>’ provides no match for the signature ‘(): Element’.
7:02:39 PM: error Command failed with exit code 2. (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
7:02:39 PM: info Visit yarn run | Yarn for documentation about this command.
7:02:39 PM: ​
7:02:39 PM: build.command failed
7:02:39 PM: ────────────────────────────────────────────────────────────────
7:02:39 PM: ​
7:02:39 PM: Error message
7:02:39 PM: Command failed with exit code 2: CI= yarn build (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
7:02:39 PM: ​
7:02:39 PM: Error location
7:02:39 PM: In Build command from Netlify app:
7:02:39 PM: CI= yarn build
7:02:39 PM: ​
7:02:39 PM: Resolved config
7:02:39 PM: build:
7:02:39 PM: command: CI= yarn build
7:02:39 PM: commandOrigin: ui
7:02:39 PM: environment:
7:02:39 PM: - VITE_APP_BASE_URL
7:02:39 PM: - VITE_APP_IMG_PLACEHOLDER_URL
7:02:39 PM: publish: /opt/build/repo/dist
7:02:39 PM: publishOrigin: ui
7:02:40 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
7:02:40 PM: Failing build: Failed to build site
7:02:40 PM: Finished processing build request in 17.751s
everything work normally locally.
here is my architecture and routes page :
``import React, { useState } from ‘react’;
import { InputPasswordWithLabel, InputWithLabel } from ‘…/…/…/components/inputs’;
import { PrimaryButton } from ‘…/…/…/components/buttons’;
import { LoginEntity } from ‘…/…/…/core/entities/auth/authSlice.entity’;
import { getConnectedUser, newSession } from ‘…/…/…/core/services/modulesServices/auth.service’;
import { selectRootLoading } from ‘…/…/…/core/store/modules/rootSlice’;
import { useAppSelector } from ‘…/…/…/core/store/hooks’;
import { toast } from ‘react-toastify’;
import { setConnectedUser, setUserToken } from ‘…/…/…/core/store/modules/authSlice’;
import { store } from ‘…/…/…/core/store’;
const LoginPage = () => {
const loading = useAppSelector(selectRootLoading);
const [values, setValues] = useState({
email: ‘’,
password: ‘’,
const loginHandler = (e: React.FormEvent): void => {
e.preventDefault();
const data = { email: values.email, password: values.password };
newSession(data)
.then((res) => {
store.dispatch(setUserToken(res.data));
getConnectedUser(res.data.accessToken).then((response) => {
store.dispatch(setConnectedUser(response.data));
window.location.href = ‘/home’;
.catch((err) => {
toast.error(err.msg, {
position: ‘top-center’,
autoClose: 1000,
return (
	<div id='login'>
		<div className='main'>
			<div className='left'>
				<div className='left-main'>
					<div className='logo'>
						<h1>Rosko Suite</h1>
					</div>
					<div className='header'>
						<h2>Bienvenue</h2>
						<p>Veuillez entrer vos coordonées pour continuer</p>
					</div>
					<form className='form' onSubmit={loginHandler}>
						<InputWithLabel
							labelName='E-mail'
							inputType='email'
							inputValue={values.email}
							onChange={(e) => setValues({ ...values, email: e.target.value })}
							required={true}
							inputPlaceholder='Entrer votre E-mail'
						<InputPasswordWithLabel
							labelName='mot de passe'
							inputType='password'
							inputValue={values.password}
							inputPlaceholder='Entrer votre mot de passe'
							required={true}
							onChange={(e) => setValues({ ...values, password: e.target.value })}
						<div className='remember-me'>
							<input type='checkbox' />
							<span>Se souvenir de moi</span>
						</div>
						<PrimaryButton
							buttonClass='btn-primary'
							buttonValue='Connexion'
							buttonType='submit'
							loading={loading}
					</form>
				</div>
			</div>
			<div className='right'></div>
		</div>
	</div>
export default LoginPage;
Have you tried to run yarn build locally?
yes, its work well
Any chance you can share the repo so we can test on our end?
here’s it GitHub - roniceyemeli/rosko-frontend-dev
@roniceyemeli When I pull down your repository do a yarn install and yarn build I see the same error as on Netlify:
It will be due to case sensitivity as you have presentation/app/login specified, but the folder is presentation/app/Login.
Renaming that folder to login allows the build to work.
thanks,it’s working now.
