Hey, I’m fairly new to Netlify, have uploaded a few real simple sites but am uploading an angular site
https://nerdyfroggames.netlify.app
and having some issues. Whenever I ran netlify build I got caught with an issue in my server.ts that it was missing something, so I followed the suggestions in the cli and now I’m getting
Cannot find module ‘@netlify/angular-runtime/common-engine’ or its corresponding type declarations.
The closest help I’ve found online is the angular-runtime dependency, but I get a laundrylist of errors when I try running that. Does anyone have experience with this issue? Thanks. (Also here’s the server.ts, I’m not sure what else would help)
import { APP_BASE_HREF } from '@angular/common';
import { CommonEngine, isMainModule } from '@angular/ssr/node';
import { render } from '@netlify/angular-runtime/common-engine';
import express from 'express';
import { dirname, join, resolve } from 'node:path';
import { fileURLToPath } from 'node:url';
import AppServerModule from './main.server';
const serverDistFolder = dirname(fileURLToPath(import.meta.url));
const browserDistFolder = resolve(serverDistFolder, '../browser');
const indexHtml = join(serverDistFolder, 'index.server.html');
const app = express();
const commonEngine = new CommonEngine();
export async function netlifyCommonEngineHandler(request: Request, context: any): Promise<Response> {
return await render(commonEngine)
* Example Express Rest API endpoints can be defined here.
* Uncomment and define endpoints as necessary.
* Example:
* ```ts
* app.get('/api/**', (req, res) => {
* // Handle API request
* Serve static files from /browser
app.get(
express.static(browserDistFolder, {
maxAge: '1y',
index: 'index.html'
* Handle all other requests by rendering the Angular application.
app.get('**', (req, res, next) => {
const { protocol, originalUrl, baseUrl, headers } = req;
commonEngine
.render({
bootstrap: AppServerModule,
documentFilePath: indexHtml,
url: `${protocol}://${headers.host}${originalUrl}`,
publicPath: browserDistFolder,
providers: [{ provide: APP_BASE_HREF, useValue: baseUrl }],
.then((html) => res.send(html))
.catch((err) => next(err));
* Start the server if this module is the main entry point.
* The server listens on the port defined by the `PORT` environment variable, or defaults to 4000.
if (isMainModule(import.meta.url)) {
const port = process.env['PORT'] || 4000;
app.listen(port, () => {
console.log(`Node Express server listening on http://localhost:${port}`);
