Hello,
I don’t know why my page does not read the searchParams prop (link) from Next.js 13 in production. In dev it works as expected.
Site: https://inmogolfbonalba.netlify.app/en/propiedades?operacion=operacion-obra-nueva
Repo: inmosanity/page.tsx at a973eceeb57a591582d6ad1e99a5823726369871 · thewinger/inmosanity · GitHub
11:15:46 PM: build-image version: 4b067841aaa59ef71931d3505b98c2bc3e63f36f (focal)
11:15:46 PM: buildbot version: 4b067841aaa59ef71931d3505b98c2bc3e63f36f
11:15:47 PM: Fetching cached dependencies
11:15:47 PM: Starting to download cache of 1.4GB
11:16:00 PM: Finished downloading cache in 13.426s
11:16:00 PM: Starting to extract cache
11:16:07 PM: Finished extracting cache in 6.899s
11:16:07 PM: Finished fetching cache in 20.47s
11:16:07 PM: Starting to prepare the repo for build
11:16:07 PM: Preparing Git Reference refs/heads/netlify
11:16:08 PM: Parsing package.json dependencies
11:16:09 PM: Different build command detected, going to use the one specified in the Netlify configuration file: 'next build' versus 'yarn build' in the Netlify UI
11:16:09 PM: Starting to install dependencies
11:16:09 PM: Python version set to 3.8
11:16:09 PM: Attempting Ruby version 2.7.2, read from environment
11:16:10 PM: Using Ruby version 2.7.2
11:16:10 PM: Started restoring cached go cache
11:16:10 PM: Finished restoring cached go cache
11:16:10 PM: go version go1.19.9 linux/amd64
11:16:11 PM: Using PHP version 8.0
11:16:12 PM: Started restoring cached Node.js version
11:16:12 PM: Finished restoring cached Node.js version
11:16:12 PM: v16.20.0 is already installed.
11:16:13 PM: Now using node v16.20.0 (npm v8.19.4)
11:16:13 PM: Enabling Node.js Corepack
11:16:13 PM: Started restoring cached build plugins
11:16:13 PM: Finished restoring cached build plugins
11:16:13 PM: Started restoring cached corepack dependencies
11:16:13 PM: Finished restoring cached corepack dependencies
11:16:13 PM: Started restoring cached yarn cache
11:16:18 PM: Finished restoring cached yarn cache
11:16:18 PM: No yarn workspaces detected
11:16:18 PM: Started restoring cached node modules
11:16:18 PM: Finished restoring cached node modules
11:16:18 PM: Installing npm packages using Yarn version 1.22.19
11:16:18 PM: yarn install v1.22.19
11:16:18 PM: [1/4] Resolving packages...
11:16:19 PM: success Already up-to-date.
11:16:19 PM: Done in 0.35s.
11:16:19 PM: npm packages installed using Yarn
11:16:19 PM: Install dependencies script success
11:16:19 PM: Starting build script
11:16:20 PM: Detected 1 framework(s)
11:16:20 PM: "next" at version "13.4.3"
11:16:20 PM: Section completed: initializing
11:16:21 PM:
11:16:21 PM: Netlify Build
11:16:21 PM: ────────────────────────────────────────────────────────────────
11:16:21 PM:
11:16:21 PM: ❯ Version
11:16:21 PM: @netlify/build 29.11.5
11:16:21 PM:
11:16:21 PM: ❯ Flags
11:16:21 PM: baseRelDir: true
11:16:21 PM: buildId: 6467e6fe0371f600087d3219
11:16:21 PM: deployId: 6467e6fe0371f600087d321b
11:16:21 PM:
11:16:21 PM: ❯ Current directory
11:16:21 PM: /opt/build/repo
11:16:21 PM:
11:16:21 PM: ❯ Config file
11:16:21 PM: /opt/build/repo/netlify.toml
11:16:21 PM:
11:16:21 PM: ❯ Context
11:16:21 PM: production
11:16:21 PM:
11:16:21 PM: ❯ Using Next.js Runtime - v4.37.1
11:16:22 PM:
11:16:22 PM: @netlify/plugin-nextjs (onPreBuild event)
11:16:22 PM: ────────────────────────────────────────────────────────────────
11:16:22 PM:
11:16:22 PM: Next.js cache restored.
11:16:22 PM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
11:16:22 PM:
11:16:22 PM: (@netlify/plugin-nextjs onPreBuild completed in 191ms)
11:16:22 PM:
11:16:22 PM: build.command from netlify.toml
11:16:22 PM:
11:16:22 PM: $ next build
11:16:23 PM: - info Creating an optimized production build...
11:16:36 PM: - info Compiled successfully
11:16:36 PM: - info Linting and checking validity of types...
11:16:39 PM: - info Collecting page data...
11:16:41 PM: - info Generating static pages (0/69)
11:16:41 PM: - warn Entire page /[lang]/[slug] deopted into client-side rendering. https://nextjs.org/docs/messages/deopted-into-client-rendering /[lang]/[slug]
11:16:45 PM: - info Generating static pages (17/69)
11:16:52 PM: - info Generating static pages (34/69)
11:16:59 PM: - info Generating static pages (51/69)
11:17:07 PM: - info Generating static pages (69/69)
11:17:08 PM: - info Finalizing page optimization...
11:17:08 PM: Route (app) Size First Load JS
11:17:08 PM: ┌ ● /[lang] 0 B 0 B
11:17:08 PM: ├ ├ /es
11:17:08 PM: ├ └ /en
11:17:08 PM: ├ ● /[lang]/[slug] 0 B 0 B
11:17:08 PM: ├ ├ /es/aviso-legal
11:17:08 PM: ├ └ /en/aviso-legal
11:17:08 PM: ├ ● /[lang]/propiedad/[slug] 0 B 0 B
11:17:08 PM: ├ ├ /es/propiedad/a296
11:17:08 PM: ├ ├ /es/propiedad/v021
11:17:08 PM: ├ ├ /es/propiedad/v115
11:17:08 PM: ├ └ [+59 more paths]
11:17:08 PM: ├ λ /[lang]/propiedades 0 B 0 B
11:17:08 PM: ├ ○ /favicon.ico 0 B 0 B
11:17:08 PM: └ λ /studio/[[...index]] 683 kB 766 kB
11:17:08 PM: + First Load JS shared by all 77.6 kB
11:17:08 PM: ├ chunks/139-126e8c3a93459eca.js 24.8 kB
11:17:08 PM: ├ chunks/2443530c-26bd1c2cb2f545c8.js 50.5 kB
11:17:08 PM: ├ chunks/main-app-ce2a9403e91a0ee1.js 224 B
11:17:08 PM: └ chunks/webpack-1e1a7a27d9f48035.js 2.05 kB
11:17:08 PM: Route (pages) Size First Load JS
11:17:08 PM: ─ ○ /404 180 B 84.4 kB
11:17:08 PM: + First Load JS shared by all 84.2 kB
11:17:08 PM: ├ chunks/main-2259c120b86064d8.js 81.9 kB
11:17:08 PM: ├ chunks/pages/_app-dec1a83570915fb0.js 195 B
11:17:08 PM: λ (Server) server-side renders at runtime (uses getInitialProps or getServerSideProps)
11:17:08 PM: ○ (Static) automatically rendered as static HTML (uses no initial props)
11:17:08 PM: ● (SSG) automatically generated as static HTML + JSON (uses getStaticProps)
11:17:08 PM:
11:17:08 PM: (build.command completed in 45.3s)
11:17:08 PM:
11:17:08 PM: @netlify/plugin-nextjs (onBuild event)
11:17:08 PM: ────────────────────────────────────────────────────────────────
11:17:08 PM:
11:17:08 PM: Patching /opt/build/repo/node_modules/next/dist/server/base-server.js
11:17:08 PM: Done
11:17:08 PM: Patching /opt/build/repo/node_modules/next/dist/server/next-server.js
11:17:08 PM: Done
11:17:08 PM: Moving static page files to serve from CDN...
11:17:08 PM: Moved 132 files
11:17:08 PM: Using Netlify Edge Functions for image format detection. Set env var "NEXT_DISABLE_EDGE_IMAGES=true" to disable.
11:17:08 PM: ✨ Deploying middleware and functions to Netlify Edge Functions ✨
11:17:08 PM: This feature is in beta. Please share your feedback here: https://ntl.fyi/next-netlify-edge
11:17:08 PM: Netlify configuration property "redirects" value changed to [
11:17:08 PM: {
11:17:08 PM: from: '/',
11:17:08 PM: query: {},
11:17:08 PM: to: '/en',
11:17:08 PM: status: 301,
11:17:08 PM: force: false,
11:17:08 PM: conditions: { Language: [Array] },
11:17:08 PM: headers: {}
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: to: '/es',
11:17:08 PM: },
11:17:08 PM: { from: '/_next/static/*', to: '/static/:splat', status: 200 },
11:17:08 PM: {
11:17:08 PM: from: '/_next/image*',
11:17:08 PM: query: { url: ':url', w: ':width', q: ':quality' },
11:17:08 PM: to: '/_ipx/w_:width,q_:quality/:url',
11:17:08 PM: },
11:17:08 PM: { from: '/_ipx/*', to: '/.netlify/builders/_ipx', status: 200 },
11:17:08 PM: { from: '/cache/*', to: '/404.html', status: 404, force: true },
11:17:08 PM: { from: '/server/*', to: '/404.html', status: 404, force: true },
11:17:08 PM: { from: '/serverless/*', to: '/404.html', status: 404, force: true },
11:17:08 PM: { from: '/trace', to: '/404.html', status: 404, force: true },
11:17:08 PM: { from: '/traces', to: '/404.html', status: 404, force: true },
11:17:08 PM: {
11:17:08 PM: from: '/routes-manifest.json',
11:17:08 PM: to: '/404.html',
11:17:08 PM: status: 404,
11:17:08 PM: force: true
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/build-manifest.json',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/prerender-manifest.json',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/react-loadable-manifest.json',
11:17:08 PM: },
11:17:08 PM: { from: '/BUILD_ID', to: '/404.html', status: 404, force: true },
11:17:08 PM: {
11:17:08 PM: from: '/api/*',
11:17:08 PM: to: '/.netlify/functions/___netlify-handler',
11:17:08 PM: status: 200
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/Inter-Bold.woff',
11:17:08 PM: to: '/Inter-Bold.woff',
11:17:08 PM: conditions: { Cookie: [Array] },
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/Logo_Inmogolf.png',
11:17:08 PM: to: '/Logo_Inmogolf.png',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/Logo_Inmogolf.psd',
11:17:08 PM: to: '/Logo_Inmogolf.psd',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/background.png',
11:17:08 PM: to: '/background.png',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/break_iterator.wasm',
11:17:08 PM: to: '/break_iterator.wasm',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/es.svg',
11:17:08 PM: to: '/es.svg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/favicon.ico',
11:17:08 PM: to: '/favicon.ico',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/footer_border.svg',
11:17:08 PM: to: '/footer_border.svg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/hero-golf.jpg',
11:17:08 PM: to: '/hero-golf.jpg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/hero-golfball.jpeg',
11:17:08 PM: to: '/hero-golfball.jpeg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/uk.svg',
11:17:08 PM: to: '/uk.svg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/static/media/Logo_Inmogolf.64178fb3.png',
11:17:08 PM: to: '/static/media/Logo_Inmogolf.64178fb3.png',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/static/media/es.b645a4a2.svg',
11:17:08 PM: to: '/static/media/es.b645a4a2.svg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/static/media/uk.e38acaa1.svg',
11:17:08 PM: to: '/static/media/uk.e38acaa1.svg',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/*',
11:17:08 PM: status: 200,
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/_next/data/oFBEil6d_LEdz5rQojbf7/studio.json',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/_next/data/oFBEil6d_LEdz5rQojbf7/studio/*',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/studio',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/studio/*',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang.rsc',
11:17:08 PM: to: '/.netlify/builders/___netlify-odb-handler',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang/propiedad/:slug.rsc',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang/propiedad/:slug',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/_next/data/oFBEil6d_LEdz5rQojbf7/:lang/propiedades.json',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang/propiedades',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang/:slug.rsc',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: from: '/:lang/:slug',
11:17:08 PM: },
11:17:08 PM: {
11:17:08 PM: }
11:17:08 PM: ].
11:17:08 PM:
11:17:08 PM: (@netlify/plugin-nextjs onBuild completed in 92ms)
11:17:08 PM:
11:17:08 PM: Functions bundling
11:17:08 PM:
11:17:08 PM: Packaging Functions from .netlify/functions-internal directory:
11:17:08 PM: - ___netlify-handler/___netlify-handler.js
11:17:08 PM: - ___netlify-odb-handler/___netlify-odb-handler.js
11:17:08 PM: - _ipx/_ipx.js
11:17:08 PM:
11:17:38 PM:
11:17:38 PM: (Functions bundling completed in 30.1s)
11:17:38 PM:
11:17:38 PM: Edge Functions bundling
11:17:38 PM: ────────────────────────────────────────────────────────────────
11:17:38 PM:
11:17:38 PM: Packaging Edge Functions from .netlify/edge-functions directory:
11:17:38 PM: - ipx
11:17:38 PM: - rsc-data
11:17:39 PM:
11:17:39 PM: (Edge Functions bundling completed in 854ms)
11:17:39 PM:
11:17:39 PM: @netlify/plugin-nextjs (onPostBuild event)
11:17:39 PM: ────────────────────────────────────────────────────────────────
11:17:39 PM:
11:17:39 PM: Next.js cache saved.
11:17:39 PM: 🧪 Thank you for testing "appDir" support on Netlify. For known issues and to give feedback, visit https://ntl.fyi/next-13-feedback
11:17:39 PM:
11:17:39 PM: (@netlify/plugin-nextjs onPostBuild completed in 361ms)
11:17:39 PM:
11:17:39 PM: Deploy site
11:17:39 PM:
11:17:39 PM: Starting to deploy site from '.next'
11:17:40 PM: Calculating files to upload
11:17:40 PM: 159 new files to upload
11:17:40 PM: 3 new functions to upload
11:17:49 PM: Section completed: deploying
11:17:49 PM: Site deploy was successfully initiated
11:17:49 PM:
11:17:49 PM: (Deploy site completed in 9.4s)
11:17:49 PM: Starting post processing
11:17:49 PM:
11:17:49 PM: Netlify Build Complete
11:17:49 PM: ────────────────────────────────────────────────────────────────
11:17:49 PM:
11:17:49 PM: Skipping HTML post processing
11:17:49 PM: (Netlify Build completed in 1m 27.8s)
11:17:49 PM: Post processing - header rules
11:17:49 PM: Post processing - redirect rules
11:17:49 PM: Caching artifacts
11:17:49 PM: Started saving node modules
11:17:49 PM: Finished saving node modules
11:17:49 PM: Post processing done
11:17:49 PM: Started saving build plugins
11:17:49 PM: Finished saving build plugins
11:17:49 PM: Started saving corepack cache
11:17:50 PM: Section completed: postprocessing
11:17:49 PM: Finished saving corepack cache
11:17:49 PM: Started saving yarn cache
11:17:50 PM: Site is live ✨
11:17:53 PM: Finished saving yarn cache
11:17:53 PM: Started saving pip cache
11:17:53 PM: Finished saving pip cache
11:17:53 PM: Started saving emacs cask dependencies
11:17:53 PM: Finished saving emacs cask dependencies
11:17:53 PM: Started saving maven dependencies
11:17:53 PM: Finished saving maven dependencies
11:17:53 PM: Started saving boot dependencies
11:17:53 PM: Finished saving boot dependencies
11:17:53 PM: Started saving rust rustup cache
11:17:53 PM: Finished saving rust rustup cache
11:17:53 PM: Started saving go dependencies
11:17:53 PM: Finished saving go dependencies
11:17:53 PM: Build script success
11:17:53 PM: Section completed: building
11:17:59 PM: Uploading Cache of size 1.4GB
11:18:08 PM: Section completed: cleanup
11:18:08 PM: Finished processing build request in 2m21.927s
