Caching problem? sh: 1: next: not found
It looks like there’s a problem with the caching mechanism in my builds as every build I run fails with the same error.
However when I click retry deploy → clear cache and deploy site it works 100%.
I do not use the essential nextjs plugin as the readme suggests not using it with next export.
here’s the first half of the deploy log of buildID: 62405aaf65b32000095db49e
2:38:07 PM: Build ready to start
2:38:11 PM: build-image version: 01acd77a1510fdb8f4fc9a04f21fc94be8fc1167 (xenial)
2:38:11 PM: build-image tag: v3.11.0
2:38:11 PM: buildbot version: 43c70c62bfed821cfaaabbb50f00238dd4bdd2d6
2:38:11 PM: Fetching cached dependencies
2:38:11 PM: Starting to download cache of 124.0MB
2:38:12 PM: Finished downloading cache in 1.359007023s
2:38:12 PM: Starting to extract cache
2:38:16 PM: Finished extracting cache in 3.933286473s
2:38:16 PM: Finished fetching cache in 5.310982201s
2:38:16 PM: Starting to prepare the repo for build
2:38:17 PM: Preparing Git Reference refs/heads/master
2:38:18 PM: Parsing package.json dependencies
2:38:19 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: 'apps/web' versus '/apps/web' in the Netlify UI
2:38:19 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'apps/web/out' versus 'out' in the Netlify UI
2:38:19 PM: Different functions path detected, going to use the one specified in the Netlify configuration file: 'apps/web/functions' versus 'functions' in the Netlify UI
2:38:19 PM: Different build command detected, going to use the one specified in the Netlify configuration file: 'CI= npm run build && npm run export' versus 'next build' in the Netlify UI
2:38:20 PM: Starting build script
2:38:20 PM: Installing dependencies
2:38:20 PM: Python version set to 2.7
2:38:21 PM: Started restoring cached node version
2:38:23 PM: Finished restoring cached node version
2:38:24 PM: v16.14.2 is already installed.
2:38:25 PM: npm WARN ignoring workspace config at /opt/build/repo/apps/web/.npmrc
2:38:25 PM: npm WARN config This command does not support workspaces.
2:38:25 PM: Now using node v16.14.2 (npm v8.5.0)
2:38:25 PM: Started restoring cached build plugins
2:38:25 PM: Finished restoring cached build plugins
2:38:26 PM: Attempting ruby version 2.7.2, read from environment
2:38:28 PM: Using ruby version 2.7.2
2:38:28 PM: Using PHP version 5.6
2:38:28 PM: Started restoring cached node modules
2:38:28 PM: Finished restoring cached node modules
2:38:29 PM: npm WARN ignoring workspace config at /opt/build/repo/apps/web/.npmrc
2:38:29 PM: npm ERR! code ENOWORKSPACES
2:38:29 PM: npm ERR! This command does not support workspaces.
2:38:29 PM: npm ERR! A complete log of this run can be found in:
2:38:29 PM: npm ERR!     /opt/buildhome/.npm/_logs/2022-03-27T12_38_29_141Z-debug-0.log
2:38:29 PM: Started restoring cached go cache
2:38:29 PM: Finished restoring cached go cache
2:38:29 PM: go version go1.14.4 linux/amd64
2:38:29 PM: Installing missing commands
2:38:29 PM: Verify run directory
2:38:31 PM: ​
2:38:31 PM: ────────────────────────────────────────────────────────────────
2:38:31 PM:   Netlify Build
2:38:31 PM: ​
2:38:31 PM: ❯ Version
2:38:31 PM:   @netlify/build 26.5.1
2:38:31 PM: ​
2:38:31 PM: ❯ Flags
2:38:31 PM:   baseRelDir: true
2:38:31 PM:   buildId: 62405aaf65b32000095db49c
2:38:31 PM:   deployId: 62405aaf65b32000095db49e
2:38:31 PM: ​
2:38:31 PM: ❯ Current directory
2:38:31 PM:   /opt/build/repo/apps/web
2:38:31 PM: ​
2:38:31 PM: ❯ Config file
2:38:31 PM:   /opt/build/repo/apps/web/netlify.toml
2:38:31 PM: ​
2:38:31 PM: ❯ Context
2:38:31 PM:   production
2:38:31 PM: ​
2:38:31 PM: ❯ Loading plugins
2:38:31 PM:    - @sentry/netlify-build-plugin@1.1.1 from netlify.toml
2:38:33 PM: ​
2:38:33 PM: ────────────────────────────────────────────────────────────────
2:38:33 PM:   1. build.command from netlify.toml
2:38:33 PM: ​
2:38:33 PM: $ CI= npm run build && npm run export
2:38:34 PM: npm WARN ignoring workspace config at /opt/build/repo/apps/web/.npmrc
2:38:34 PM: > web@0.1.0 build
2:38:34 PM: > next build
2:38:34 PM: sh: 1: next: not found
2:38:34 PM: npm ERR! Lifecycle script `build` failed with error:
2:38:34 PM: npm ERR! Error: command failed
2:38:34 PM: npm ERR!   in workspace: web@0.1.0
2:38:34 PM: npm ERR!   at location: /opt/build/repo/apps/web
2:38:34 PM: ​
2:38:34 PM: ────────────────────────────────────────────────────────────────
2:38:34 PM:   "build.command" failed
2:38:34 PM: ​
2:38:34 PM:   Error message
2:38:34 PM:   Command failed with exit code 1: CI= npm run build && npm run export (https://ntl.fyi/exit-code-1)
2:38:34 PM: ​
2:38:34 PM:   Error location
2:38:34 PM:   In build.command from netlify.toml:
2:38:34 PM:   CI= npm run build && npm run export
Here’s my netlify.toml
[build]
    functions = "functions"
    command = "CI= npm run build && npm run export"
    publish = "out"
[build.environment]
    NETLIFY_NEXT_PLUGIN_SKIP = "true"
    NODE_VERSION = "16"
[[redirects]]
    from = "/api/*"
    to = "/.netlify/functions/:splat"
    status = 200
[functions]
  node_bundler = "esbuild"
  directory = "functions/"
  external_node_modules = ["firebase-admin", "node-fetch", "cookie", "discord.js", "axios"]
  [functions."triggerAutomations"]
    schedule = "@hourly"
[[plugins]]
  package = "@sentry/netlify-build-plugin"
  [plugins.inputs]
    sentryOrg = "org"
    sentryProject = "project"
Hey @p.aarseth,
Sorry for the silence on this one. We actually worked on this and downloaded your build cache to inspect. What’s weird is, for some reason, node_modules folder turns out to be empty in your cache even though we log that the dependencies were saved in cache. So here’s what’s happening:
  1. We store the dependencies in cache and save the SHA of your package.json too.
  2. In the next build, we try to fetch cache. That works and we compare the SHA of the package.json. It’s same if you don’t make any changes to it.
  3. If SHA is same, we assume that node_modules don’t need to be installed again as they would be present in your cache.
That’s where the problem is occuring. The modules are simply missing for some unknown reason. We’ve already filed an escalation for the engineers to look at this and we would revert once we hear back.
That’s alright, a couple of days ago it randomly started working again :man_shrugging:t3:. I haven’t changed anything in my setup, so the bug is likely still there.
Hey there, @p.aarseth :wave:
Thanks for those details. As Hrishikesh mentioned, we have an issue filed with the appropriate engineering team. We don’t have a timeline on the fix, but we will follow up here once we do!
