I’m having this issue today only even though it’s been successfully publishing for weeks
4:00:43 AM: Build ready to start
4:00:45 AM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
4:00:45 AM: build-image tag: v3.4.1
4:00:45 AM: buildbot version: fcbc7a79f7372e5995cf02954ef19fc48d20c871
4:00:45 AM: Fetching cached dependencies
4:00:45 AM: Starting to download cache of 162.5MB
4:00:46 AM: Finished downloading cache in 807.972955ms
4:00:46 AM: Starting to extract cache
4:00:55 AM: Finished extracting cache in 9.655315758s
4:00:55 AM: Finished fetching cache in 10.509259179s
4:00:55 AM: Starting to prepare the repo for build
4:00:56 AM: Preparing Git Reference refs/heads/master
4:00:57 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘public’ versus ‘public/’ in the Netlify UI
4:00:58 AM: Starting build script
4:00:58 AM: Installing dependencies
4:00:58 AM: Python version set to 2.7
4:00:58 AM: Started restoring cached node version
4:01:01 AM: Finished restoring cached node version
4:01:16 AM: Version ‘12.18.0’ not found - try nvm ls-remote to browse available versions.
4:01:16 AM: Failed to install node version ‘12.18.0’
4:01:16 AM: Error running command: Build script returned non-zero exit code: 1
4:01:16 AM: Failing build: Failed to build site
4:01:16 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
4:01:17 AM: Finished processing build request in 31.825620662s
