Hello,
This is the second (MERN) ReactJs project that I am trying to deploy. The first one worked like a charm but I’m having issues with the second one. I’m getting a “Failed during stage ‘building site’: Deploy directory ‘build’ does not exist”. I added a netlify.toml file that has:
[[redirects]]
from = "/*"
to = "/index.html"
status = 200
[build]
command = "npm run-script build"
build = "build"
Netlify site name: blissful-fermi-fe94ed
Here is my deploy log:
7:18:26 PM: Build ready to start
7:18:28 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
7:18:28 PM: build-image tag: v3.4.1
7:18:28 PM: buildbot version: fcbc7a79f7372e5995cf02954ef19fc48d20c871
7:18:28 PM: Fetching cached dependencies
7:18:28 PM: Failed to fetch cache, continuing with build
7:18:28 PM: Starting to prepare the repo for build
7:18:29 PM: No cached dependencies found. Cloning fresh repo
7:18:29 PM: git clone GitHub - denzgrant/React-Google-Books
7:18:30 PM: Preparing Git Reference refs/heads/master
7:18:31 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘build’ versus ‘build/’ in the Netlify UI
7:18:31 PM: Different build command detected, going to use the one specified in the Netlify configuration file: ‘npm run-script build’ versus ‘npm run build’ in the Netlify UI
7:18:31 PM: Starting build script
7:18:31 PM: Installing dependencies
7:18:31 PM: Python version set to 2.7
7:18:33 PM: v12.18.0 is already installed.
7:18:33 PM: Now using node v12.18.0 (npm v6.14.4)
7:18:33 PM: Started restoring cached build plugins
7:18:33 PM: Finished restoring cached build plugins
7:18:33 PM: Attempting ruby version 2.7.1, read from environment
7:18:35 PM: Using ruby version 2.7.1
7:18:35 PM: Using PHP version 5.6
7:18:35 PM: 5.2 is already installed.
7:18:35 PM: Using Swift version 5.2
7:18:35 PM: Started restoring cached node modules
7:18:35 PM: Finished restoring cached node modules
7:18:35 PM: Installing NPM modules using NPM version 6.14.4
7:18:44 PM: > node-sass@4.14.1 install /opt/build/repo/node_modules/node-sass
7:18:44 PM: > node scripts/install.js
7:18:44 PM: Downloading binary from https://github.com/sass/node-sass/releases/download/v4.14.1/linux-x64-72_binding.node
7:18:47 PM: Download complete
7:18:47 PM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
7:18:47 PM: Caching binary to /opt/buildhome/.npm/node-sass/4.14.1/linux-x64-72_binding.node
7:18:47 PM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
7:18:47 PM: > node -e “try{require(‘./postinstall’)}catch(e){}”
7:18:47 PM: > node-sass@4.14.1 postinstall /opt/build/repo/node_modules/node-sass
7:18:47 PM: > node scripts/build.js
7:18:48 PM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
7:18:48 PM: Testing binary
7:18:48 PM: Binary is fine
7:18:48 PM: > nodemon@1.19.4 postinstall /opt/build/repo/node_modules/nodemon
7:18:48 PM: > node bin/postinstall || exit 0
7:18:48 PM: Love nodemon? You can now support the project via the open collective:
7:18:48 PM: > Contribute to nodemon - Open Collective
7:18:48 PM: > mern@1.0.0 install /opt/build/repo
7:18:48 PM: > cd client && npm install
7:19:20 PM: > core-js@2.6.11 postinstall /opt/build/repo/client/node_modules/core-js
7:19:20 PM: > node -e “try{require(‘./postinstall’)}catch(e){}”
7:19:22 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/watchpack/node_modules/fsevents):
7:19:22 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
7:19:22 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
7:19:22 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
7:19:22 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/chokidar/node_modules/fsevents):
7:19:22 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
7:19:22 PM: added 1910 packages from 687 contributors and audited 1980 packages in 34.058s
7:19:24 PM: 33 packages are looking for funding
7:19:24 PM: run npm fund for details
7:19:24 PM: found 91 vulnerabilities (82 low, 2 moderate, 7 high)
7:19:24 PM: run npm audit fix to fix them, or npm audit for details
7:19:24 PM: npm WARN mern@1.0.0 No description
7:19:24 PM: npm WARN mern@1.0.0 No repository field.
7:19:24 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
7:19:24 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
7:19:24 PM: added 513 packages from 286 contributors and audited 516 packages in 48.079s
7:19:24 PM: 7 packages are looking for funding
7:19:24 PM: found 2 vulnerabilities (1 low, 1 high)
7:19:24 PM: NPM modules installed
7:19:25 PM: Started restoring cached go cache
7:19:25 PM: Finished restoring cached go cache
7:19:25 PM: go version go1.14.4 linux/amd64
7:19:25 PM: Installing missing commands
7:19:25 PM: Verify run directory
7:19:26 PM:
7:19:26 PM: ┌─────────────────────────────┐
7:19:26 PM: │ Netlify Build │
7:19:26 PM: └─────────────────────────────┘
7:19:26 PM:
7:19:26 PM: ❯ Version
7:19:26 PM: @netlify/build 3.3.0
7:19:26 PM:
7:19:26 PM: ❯ Flags
7:19:26 PM: deployId: 5f45c6728106ae0007b06f62
7:19:26 PM: mode: buildbot
7:19:26 PM:
7:19:26 PM: ❯ Current directory
7:19:26 PM: /opt/build/repo
7:19:26 PM:
7:19:26 PM: ❯ Config file
7:19:26 PM: /opt/build/repo/netlify.toml
7:19:26 PM:
7:19:26 PM: ❯ Context
7:19:26 PM: production
7:19:26 PM:
7:19:26 PM: ┌────────────────────────────────────┐
7:19:26 PM: │ 1. build.command from netlify.toml │
7:19:26 PM: └────────────────────────────────────┘
7:19:26 PM:
7:19:26 PM: $ npm run-script build
7:19:26 PM: > mern@1.0.0 build /opt/build/repo
7:19:26 PM: > cd client && npm run build
7:19:26 PM: > mern@0.1.0 build /opt/build/repo/client
7:19:26 PM: > react-scripts build
7:19:28 PM: Creating an optimized production build…
7:19:40 PM: Compiled successfully.
7:19:40 PM:
7:19:40 PM: File sizes after gzip:
7:19:40 PM: 51.77 KB build/static/js/2.2dde2e74.chunk.js
7:19:40 PM: 2.42 KB (+19 B) build/static/js/main.25370fb4.chunk.js
7:19:40 PM: 763 B build/static/js/runtime~main.d653cc00.js
7:19:40 PM: 344 B build/static/css/main.1930c81d.chunk.css
7:19:40 PM: The project was built assuming it is hosted at ./.
7:19:40 PM: You can control this with the homepage field in your package.json.
7:19:40 PM: The build folder is ready to be deployed.
7:19:40 PM: Find out more about deployment here:
7:19:40 PM: create-react-app/README.md at main · facebook/create-react-app · GitHub
7:19:40 PM:
7:19:40 PM: (build.command completed in 14s)
7:19:40 PM:
7:19:40 PM: ┌─────────────────────────────┐
7:19:40 PM: │ Netlify Build Complete │
7:19:40 PM: └─────────────────────────────┘
7:19:40 PM:
7:19:40 PM: (Netlify Build completed in 14s)
7:19:40 PM: Caching artifacts
7:19:40 PM: Started saving node modules
7:19:40 PM: Finished saving node modules
7:19:40 PM: Started saving build plugins
7:19:40 PM: Finished saving build plugins
7:19:40 PM: Started saving pip cache
7:19:40 PM: Finished saving pip cache
7:19:40 PM: Started saving emacs cask dependencies
7:19:40 PM: Finished saving emacs cask dependencies
7:19:40 PM: Started saving maven dependencies
7:19:40 PM: Finished saving maven dependencies
7:19:40 PM: Started saving boot dependencies
7:19:40 PM: Finished saving boot dependencies
7:19:40 PM: Started saving go dependencies
7:19:40 PM: Finished saving go dependencies
7:19:44 PM: Build script success
7:19:44 PM: Failing build: Failed to build site
7:19:44 PM: Failed during stage ‘building site’: Deploy directory ‘build’ does not exist
7:19:44 PM: Finished processing build request in 1m15.352025027s
