Hello, I am encountering this build error when I deploy my next js site :
11:28:14 AM: info - Generating static pages (19/19)
11:28:14 AM: > Build error occurred
11:28:14 AM: Error: Export encountered errors on following paths:
11:28:14 AM: /
11:28:14 AM: at /opt/build/repo/node_modules/next/dist/export/index.js:404:19
11:28:14 AM: at runMicrotasks ()
11:28:14 AM: at processTicksAndRejections (node:internal/process/task_queues:96:5)
11:28:14 AM: at async Span.traceAsyncFn (/opt/build/repo/node_modules/next/dist/trace/trace.js:79:20)
11:28:14 AM: at async /opt/build/repo/node_modules/next/dist/build/index.js:1229:21
11:28:14 AM: at async /opt/build/repo/node_modules/next/dist/build/index.js:1091:17
11:28:14 AM: at async Object.build [as default] (/opt/build/repo/node_modules/next/dist/build/index.js:65:29)
11:28:14 AM:
11:28:14 AM: ────────────────────────────────────────────────────────────────
11:28:14 AM: “build.command” failed
11:28:14 AM:
11:28:14 AM: Error message
11:28:14 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
11:28:14 AM:
11:28:14 AM: Error location
11:28:14 AM: In Build command from Netlify app:
11:28:14 AM: npm run build
11:28:14 AM:
11:28:14 AM: Resolved config
11:28:14 AM: build:
11:28:14 AM: command: npm run build
11:28:14 AM: commandOrigin: ui
11:28:14 AM: environment:
11:28:14 AM: - NEXT_PRIVATE_TARGET
11:28:14 AM: publish: /opt/build/repo/.next
11:28:14 AM: publishOrigin: ui
11:28:14 AM: plugins:
11:28:14 AM: - inputs: {}
11:28:14 AM: origin: ui
11:28:14 AM: package: ‘@netlify/plugin-nextjs’
11:28:15 AM: Caching artifacts
11:28:15 AM: Started saving node modules
11:28:15 AM: Finished saving node modules
11:28:15 AM: Started saving build plugins
11:28:15 AM: Finished saving build plugins
11:28:15 AM: Started saving pip cache
11:28:15 AM: Finished saving pip cache
11:28:15 AM: Started saving emacs cask dependencies
11:28:15 AM: Finished saving emacs cask dependencies
11:28:15 AM: Started saving maven dependencies
11:28:15 AM: Finished saving maven dependencies
11:28:15 AM: Started saving boot dependencies
11:28:15 AM: Finished saving boot dependencies
11:28:15 AM: Started saving rust rustup cache
11:28:15 AM: Finished saving rust rustup cache
11:28:15 AM: Started saving go dependencies
11:28:15 AM: Finished saving go dependencies
11:28:15 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
11:28:16 AM: Creating deploy upload records
11:28:16 AM: Failing build: Failed to build site
11:28:16 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
11:28:16 AM: Finished processing build request in 59.324348411s
I have no idea on how to fix this error. Do you have any suggestion ?
Thanks
