Build fails due to missing module (SVG)
Hi, I have simple static site built with Gridsome and Forestry, which I can build locally without any errors but as soon as I trigger a deployment on Netlify, the build breaks due to missing webpack module. It seems like Netlify has a problem with how I import SVG icons (?) but I really have no idea how I can fix it.
My Icon.vue component:
computed: {
    iconCode() {
      // this.icon is a string, which is passed in as prop
      return require(`~/assets/icons/${this.icon}.svg`)?.default?.id;
My webpack config:
chainWebpack: (config) => {
      config.node.set('__dirname', true);
      const svgRule = config.module.rule("svg");
      svgRule.uses.clear();
      svgRule
        .use("svg-sprite-loader")
        .loader("svg-sprite-loader")
        .end()
        .use("svgo-loader")
        .loader("svgo-loader")
        .options({
          plugins: [
            { removeNonInheritableGroupAttrs: true },
            { collapseGroups: true },
            { convertColors: { currentColor: true } },
The entire log:
8:30:23 PM: build-image version: 09c2cdcdf242cf2f57c9ee0fcad9d298fad9ad41
8:30:23 PM: build-image tag: v3.5.0
8:30:23 PM: buildbot version: df708c2c221a3345a3fb36b8609ebca30cb2f6c5
8:30:23 PM: Building without cache
8:30:23 PM: Starting to prepare the repo for build
8:30:23 PM: No cached dependencies found. Cloning fresh repo
8:30:23 PM: git clone https://github.com/kwiat1990/marketingowy-wir-forestry
8:30:24 PM: Preparing Git Reference refs/heads/master
8:30:26 PM: Starting build script
8:30:26 PM: Installing dependencies
8:30:26 PM: Python version set to 2.7
8:30:27 PM: v12.18.0 is already installed.
8:30:28 PM: Now using node v12.18.0 (npm v6.14.4)
8:30:28 PM: Started restoring cached build plugins
8:30:28 PM: Finished restoring cached build plugins
8:30:28 PM: Attempting ruby version 2.7.1, read from environment
8:30:30 PM: Using ruby version 2.7.1
8:30:30 PM: Using PHP version 5.6
8:30:30 PM: Started restoring cached node modules
8:30:30 PM: Finished restoring cached node modules
8:30:30 PM: Installing NPM modules using NPM version 6.14.4
8:31:02 PM: > sharp@0.25.4 install /opt/build/repo/node_modules/sharp
8:31:02 PM: > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
8:31:03 PM: info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.9.1/libvips-8.9.1-linux-x64.tar.gz
8:31:05 PM: > node-sass@5.0.0 install /opt/build/repo/node_modules/node-sass
8:31:05 PM: > node scripts/install.js
8:31:06 PM: Downloading binary from https://github.com/sass/node-sass/releases/download/v5.0.0/linux-x64-72_binding.node
8:31:07 PM: Download complete
8:31:07 PM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
8:31:07 PM: Caching binary to /opt/buildhome/.npm/node-sass/5.0.0/linux-x64-72_binding.node
8:31:07 PM: > core-js@3.7.0 postinstall /opt/build/repo/node_modules/core-js
8:31:07 PM: > node -e "try{require('./postinstall')}catch(e){}"
8:31:08 PM: > cwebp-bin@5.1.0 postinstall /opt/build/repo/node_modules/cwebp-bin
8:31:08 PM: > node lib/install.js
8:31:08 PM:   ✔ cwebp pre-build test passed successfully
8:31:08 PM: > mozjpeg@6.0.1 postinstall /opt/build/repo/node_modules/mozjpeg
8:31:09 PM:   ✔ mozjpeg pre-build test passed successfully
8:31:09 PM: > pngquant-bin@5.0.2 postinstall /opt/build/repo/node_modules/pngquant-bin
8:31:09 PM: > node lib/install.js
8:31:09 PM:   ✔ pngquant pre-build test passed successfully
8:31:09 PM: > node-sass@5.0.0 postinstall /opt/build/repo/node_modules/node-sass
8:31:09 PM: > node scripts/build.js
8:31:09 PM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
8:31:09 PM: Testing binary
8:31:10 PM: Binary is fine
8:31:11 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/watchpack/node_modules/fsevents):
8:31:11 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
8:31:11 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/fsevents):
8:31:11 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
8:31:11 PM: added 1678 packages from 825 contributors and audited 1682 packages in 40.067s
8:31:13 PM: 68 packages are looking for funding
8:31:13 PM:   run `npm fund` for details
8:31:13 PM: found 0 vulnerabilities
8:31:13 PM: NPM modules installed
8:31:13 PM: Started restoring cached go cache
8:31:13 PM: Finished restoring cached go cache
8:31:13 PM: go version go1.14.4 linux/amd64
8:31:13 PM: Installing missing commands
8:31:13 PM: Verify run directory
8:31:15 PM: ​
8:31:15 PM: ┌─────────────────────────────┐
8:31:15 PM: │        Netlify Build        │
8:31:15 PM: └─────────────────────────────┘
8:31:15 PM: ​
8:31:15 PM: ❯ Version
8:31:15 PM:   @netlify/build 5.2.1
8:31:15 PM: ​
8:31:15 PM: ❯ Flags
8:31:15 PM:   deployId: 5fb181caa30abc5f3e54ada6
8:31:15 PM:   mode: buildbot
8:31:15 PM: ​
8:31:15 PM: ❯ Current directory
8:31:15 PM:   /opt/build/repo
8:31:15 PM: ​
8:31:15 PM: ❯ Config file
8:31:15 PM:   No config file was defined: using default values.
8:31:15 PM: ​
8:31:15 PM: ❯ Context
8:31:15 PM:   production
8:31:15 PM: ​
8:31:15 PM: ┌───────────────────────────────────┐
8:31:15 PM: │ 1. Build command from Netlify app │
8:31:15 PM: └───────────────────────────────────┘
8:31:15 PM: ​
8:31:15 PM: $ gridsome  build
8:31:15 PM: Gridsome v0.7.22
8:31:16 PM: Initializing plugins...
8:31:16 PM: Load sources - 0s
8:31:16 PM: Create GraphQL schema - 0.03s
8:31:16 PM: Create pages and templates - 0.04s
8:31:16 PM: Generate temporary code - 0.03s
8:31:16 PM: Bootstrap finish - 1.23s
8:31:16 PM: Compiling assets...
8:31:22 PM: warn - Tailwind is not purging unused styles because no template paths have been provided.
8:31:22 PM: warn - If you have manually configured PurgeCSS outside of Tailwind or are deliberately not removing unused styles, set `purge: false` in your Tailwind config file to silence this warning.
8:31:22 PM: warn - https://tailwindcss.com/docs/controlling-file-size/#removing-unused-css
8:31:39 PM: Compile assets - 22.49s
8:31:39 PM: Execute GraphQL (2 queries) - 0s
8:31:39 PM: Could not generate HTML for "/404/":
8:31:39 PM: Error: Cannot find module './search.svg'
8:31:39 PM:     at webpackContextResolve (webpack:/src/assets/icons sync ^\.\/.*\.svg$:10:0)
8:31:39 PM:     at webpackContext (webpack:/src/assets/icons sync ^\.\/.*\.svg$:5:0)
8:31:39 PM:     at a.iconCode (src/components/Icon.vue:21:21)
8:31:39 PM:     at a.iconCode (/opt/build/repo/node_modules/vue/dist/vue.runtime.common.prod.js:6:29698)
8:31:39 PM:     at a.Iconvue_type_template_id_0d15cfea_scoped_true_render (src/components/Icon.vue?c1ee:3:204)
8:31:39 PM:     at a.t._render (/opt/build/repo/node_modules/vue/dist/vue.runtime.common.prod.js:6:35273)
8:31:39 PM:     at /opt/build/repo/node_modules/vue-server-renderer/build.prod.js:1:70575
8:31:39 PM:     at Yi (/opt/build/repo/node_modules/vue-server-renderer/build.prod.js:1:67139)
8:31:39 PM:     at io (/opt/build/repo/node_modules/vue-server-renderer/build.prod.js:1:70551)
8:31:39 PM:     at ro (/opt/build/repo/node_modules/vue-server-renderer/build.prod.js:1:70182)
8:31:40 PM: ​
8:31:40 PM: ┌─────────────────────────────┐
8:31:40 PM: │   "build.command" failed    │
8:31:40 PM: └─────────────────────────────┘
8:31:40 PM: ​
8:31:40 PM:   Error message
8:31:40 PM:   Command failed with exit code 1: gridsome  build
8:31:40 PM: ​
8:31:40 PM:   Error location
8:31:40 PM:   In Build command from Netlify app:
8:31:40 PM:   gridsome  build
8:31:40 PM: ​
8:31:40 PM:   Resolved config
8:31:40 PM:   build:
8:31:40 PM:     command: gridsome  build
8:31:40 PM:     commandOrigin: ui
8:31:40 PM:     publish: /opt/build/repo/dist
8:31:40 PM: Caching artifacts
8:31:40 PM: Started saving node modules
8:31:40 PM: Finished saving node modules
8:31:40 PM: Started saving build plugins
8:31:40 PM: Finished saving build plugins
8:31:40 PM: Started saving pip cache
8:31:40 PM: Finished saving pip cache
8:31:40 PM: Started saving emacs cask dependencies
8:31:40 PM: Finished saving emacs cask dependencies
8:31:40 PM: Started saving maven dependencies
8:31:40 PM: Finished saving maven dependencies
8:31:40 PM: Started saving boot dependencies
8:31:40 PM: Finished saving boot dependencies
8:31:40 PM: Started saving go dependencies
8:31:40 PM: Finished saving go dependencies
8:31:43 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:31:43 PM: Failing build: Failed to build site
8:31:43 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
8:31:43 PM: Finished processing build request in 1m20.11044481s```
Hiya @kwiat1990 and sorry to be slow to get back to you!
While our main site build debugging advice is around syncing versions of node/packages and making sure you build with a clean repo, and can be found here:
I wonder based on that error message - are you sure that the file is in ./ during build? Might be worth trying out our “run the build environment locally” to see if you can detect the problem in a local shell that you can examine rather than diagnosing only from the failure logs:
Let me know if that helps!
