Build failing with Rollup Error - Command failed with exit code 1 - Could not resolve `.x/y/z/component`
Hello Friendly Forum Fiends :wave:
I hope someone might be able to help a Netlify-Newbie :innocent:
I am trying to follow community guidelines best I can, please correct me if I have done something incorrectly.
Brief Description of the project
So I have built this relatively simple e-commerce portfolio project and I cannot seem to get it to deploy/build through Netlify.
This is React project built with Vite ,
using FireBase for user Authentication and FireStore for very basic database.
using Stripe API - I have created the necessary Environment Variables, added through the app.Netlify web page (using .env when running locally)
Details are as follows:
Netlify site name:
https://candid-rabanadas-90d3ef.netlify.app/
GitHub Repo: (main branch)
https://github.com/DevonGifford/Ecommerce_Showcase
Things I have tried:
  • I have tried the following build commands: (clearing cache each time)
  1. CI= npm run build
  2. npm run build
  3. vite build
  • Initially I had naming convention issues and after checking the forum and fixing, I am now getting stuck again
Finally, the app is working when I run locally on my machine with both
  1. npm run dev
  2. netlify dev
Also tried to host/deploy directly from the CLI tool however facing the same error of not being able to resolve this same component.
Build settings screenshot
Please see below the FULL build log
> 12:36:56 AM: build-image version: 3b96229e32b19cdf63f20dc1fc9331cd240c2d01 (focal)
> 12:36:56 AM: buildbot version: 3b96229e32b19cdf63f20dc1fc9331cd240c2d01
> 12:36:56 AM: Building without cache
> 12:36:56 AM: Starting to prepare the repo for build
> 12:36:56 AM: No cached dependencies found. Cloning fresh repo
> 12:36:56 AM: git clone --filter=blob:none https://github.com/DevonGifford/Ecommerce_Showcase
> 12:36:57 AM: Preparing Git Reference refs/heads/main
> 12:36:58 AM: Starting to install dependencies
> 12:36:58 AM: Python version set to 3.8
> 12:36:59 AM: Attempting Ruby version 2.7.2, read from environment
> 12:36:59 AM: Using Ruby version 2.7.2
> 12:37:00 AM: Started restoring cached go cache
> 12:37:00 AM: Finished restoring cached go cache
> 12:37:00 AM: go version go1.19.10 linux/amd64
> 12:37:00 AM: Using PHP version 8.0
> 12:37:01 AM: v18.16.0 is already installed.
> 12:37:01 AM: Now using node v18.16.0 (npm v9.5.1)
> 12:37:01 AM: Enabling Node.js Corepack
> 12:37:01 AM: Started restoring cached build plugins
> 12:37:01 AM: Finished restoring cached build plugins
> 12:37:01 AM: Started restoring cached corepack dependencies
> 12:37:01 AM: Finished restoring cached corepack dependencies
> 12:37:01 AM: No npm workspaces detected
> 12:37:01 AM: Started restoring cached node modules
> 12:37:01 AM: Finished restoring cached node modules
> 12:37:02 AM: Installing npm packages using npm version 9.5.1
> 12:37:08 AM: added 428 packages, and audited 429 packages in 6s
> 12:37:08 AM: 105 packages are looking for funding
> 12:37:08 AM:   run `npm fund` for details
> 12:37:08 AM: found 0 vulnerabilities
> 12:37:08 AM: npm packages installed
> 12:37:09 AM: Install dependencies script success
> 12:37:09 AM: Starting build script
> 12:37:09 AM: Detected 1 framework(s)
> 12:37:09 AM: vite at version 4.3.9
> 12:37:09 AM: Section completed: initializing
> 12:37:11 AM: ​
> 12:37:11 AM: Netlify Build
> 12:37:11 AM: ────────────────────────────────────────────────────────────────
> 12:37:11 AM: ​
> 12:37:11 AM: ❯ Version
> 12:37:11 AM:   @netlify/build 29.12.1
> 12:37:11 AM: ​
> 12:37:11 AM: ❯ Flags
> 12:37:11 AM:   baseRelDir: true
> 12:37:11 AM:   buildId: 6488ef865718442e1f45fd50
> 12:37:11 AM:   deployId: 6488ef865718442e1f45fd52
> 12:37:11 AM: ​
> 12:37:11 AM: ❯ Current directory
> 12:37:11 AM:   /opt/build/repo
> 12:37:11 AM: ​
> 12:37:11 AM: ❯ Config file
> 12:37:11 AM:   No config file was defined: using default values.
> 12:37:11 AM: ​
> 12:37:11 AM: ❯ Context
> 12:37:11 AM:   production
> 12:37:11 AM: ​
> 12:37:11 AM: Build command from Netlify app
> 12:37:11 AM: ​
> 12:37:11 AM: $ vite build
> 12:37:11 AM: vite v4.3.9 building for production...
> 12:37:11 AM: transforming...
> 12:37:13 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
> 12:37:12 AM: βœ“ 78 modules transformed.
> 12:37:12 AM: βœ“ built in 680ms
> 12:37:12 AM: Could not resolve ../../components/front-splash/front-splash.component from src/routes/home/home.component.jsx
> 12:37:12 AM: file: /opt/build/repo/src/routes/home/home.component.jsx
> 12:37:12 AM: error during build:
> 12:37:12 AM: RollupError: Could not resolve ../../components/front-splash/front-splash.component from src/routes/home/home.component.jsx
> 12:37:12 AM:     at error (file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:2124:30)
> 12:37:12 AM:     at ModuleLoader.handleInvalidResolvedId (file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:23990:24)
> 12:37:12 AM:     at file:///opt/build/repo/node_modules/rollup/dist/es/shared/node-entry.js:23952:26
> 12:37:12 AM: ​
> 12:37:12 AM: build.command failed
> 12:37:12 AM: ────────────────────────────────────────────────────────────────
> 12:37:12 AM: ​
> 12:37:12 AM:   Error message
> 12:37:12 AM:   Command failed with exit code 1: vite build (https://ntl.fyi/exit-code-1)
> 12:37:12 AM: ​
> 12:37:12 AM:   Error location
> 12:37:12 AM:   In Build command from Netlify app:
> 12:37:12 AM:   vite build
> 12:37:12 AM: ​
> 12:37:12 AM:   Resolved config
> 12:37:12 AM:   build:
> 12:37:12 AM:     command: vite build
> 12:37:12 AM:     commandOrigin: ui
> 12:37:12 AM:     environment:
> 12:37:12 AM:       - VITE_REACT_APP_STRIPE_PUBLISHABE_KEY
> 12:37:12 AM:       - VITE_STRIPE_SECRET_KEY
> 12:37:12 AM:     publish: /opt/build/repo/dist
> 12:37:12 AM:     publishOrigin: ui
> 12:37:12 AM:   functionsDirectory: /opt/build/repo/netlify/functions
> 12:37:12 AM: Caching artifacts
> 12:37:12 AM: Started saving node modules
> 12:37:12 AM: Finished saving node modules
> 12:37:12 AM: Started saving build plugins
> 12:37:12 AM: Finished saving build plugins
> 12:37:12 AM: Started saving corepack cache
> 12:37:12 AM: Finished saving corepack cache
> 12:37:12 AM: Started saving pip cache
> 12:37:12 AM: Finished saving pip cache
> 12:37:12 AM: Started saving emacs cask dependencies
> 12:37:12 AM: Finished saving emacs cask dependencies
> 12:37:12 AM: Started saving maven dependencies
> 12:37:12 AM: Finished saving maven dependencies
> 12:37:12 AM: Started saving boot dependencies
> 12:37:12 AM: Finished saving boot dependencies
> 12:37:12 AM: Started saving rust rustup cache
> 12:37:12 AM: Finished saving rust rustup cache
> 12:37:12 AM: Started saving go dependencies
> 12:37:12 AM: Finished saving go dependencies
> 12:37:13 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
> 12:37:13 AM: Failing build: Failed to build site
> 12:37:13 AM: Finished processing build request in 17.404s
Thank you in advance for anyone who takes the time to point me in the right direction :heart:
@DevonGifford This is likely caused by case sensitivity.
The key part of the error is:
If you open the src/routes/home/home.component.jsx file you see:
So you’re telling it to load:
../../components/footer/footer.component
Except there is no components folder, your folder is Components:
Make sure to be consistent with your use of uppercase/lowercase or use only lowercase for your own sanity.
Thank you for your time Nathan, I truly appreciate you! :pray:
You are correct this was the issue.
I thought I had solved this however when I changed the capitalization of some of the directories names, git didn’t seem to pick up on the directory/folder name changes - more quirks I am learning about in case preserving and case insensitivity.
Thank you for catching that one for me!
For anyone else who comes across this
I found the following git command helpful in solving this issue:
git config core.ignorecase false
However, there are a few caveats with this command:
  • This can cause some issues and strange behaviours and therefore is not encouraged by the git-config manual. However as a temporary solution to the above issue, it works fine, just revert back to true.
  • Secondly, beware this will give duplicated files/folders when pushing files/folders with same name but different capitalization in case insensitive OS - like Windows
I solved this issue by simply deleting the old directories in github and then just updated my local repository using:
git fetch origin master
git reset --hard FETCH_HEAD
Thank you once again @nathanmartin
Hi @DevonGifford i’m glad you found a solution! This is awesome and thanks for sharing your detailed solution with the community. (:
