heartfelt-puffpuff-e7ac35.netlify.app
BUILD LOGS:
4:54:34 AM:
4:54:34 AM: ❯ Version
4:54:34 AM: @netlify/build 29.12.1
4:54:34 AM:
4:54:34 AM: ❯ Flags
4:54:34 AM: baseRelDir: true
4:54:34 AM: buildId: 6487a91332e59c2e2f73f7b3
4:54:34 AM: deployId: 6487a91332e59c2e2f73f7b5
4:54:34 AM:
4:54:34 AM: ❯ Current directory
4:54:34 AM: /opt/build/repo
4:54:34 AM:
4:54:34 AM: ❯ Config file
4:54:34 AM: No config file was defined: using default values.
4:54:34 AM:
4:54:34 AM: ❯ Context
4:54:34 AM: production
4:54:34 AM:
4:54:34 AM: Build command from Netlify app
4:54:34 AM: ────────────────────────────────────────────────────────────────
4:54:34 AM:
4:54:34 AM: $ npm run build
4:54:35 AM: > portfolio@0.1.0 build
4:54:35 AM: > react-scripts build
4:54:36 AM: Creating an optimized production build…
4:55:09 AM:
4:55:09 AM: Treating warnings as errors because process.env.CI = true.
4:55:09 AM: Most CI servers set it automatically.
4:55:09 AM:
4:55:09 AM: Failed to compile.
4:55:09 AM:
4:55:09 AM: src/components/About/Techstack.js
4:55:09 AM: Line 14:3: ‘SiRedis’ is defined but never used no-unused-vars
4:55:09 AM: Line 16:3: ‘SiNextdotjs’ is defined but never used no-unused-vars
4:55:09 AM: Line 17:3: ‘SiSolidity’ is defined but never used no-unused-vars
4:55:09 AM: Line 20:10: ‘MdFavorite’ is defined but never used no-unused-vars
4:55:09 AM: Line 21:10: ‘HiOutlineThumbUp’ is defined but never used no-unused-vars
4:55:09 AM: src/components/About/Toolstack.js
4:55:09 AM: Line 6:3: ‘SiSlack’ is defined but never used no-unused-vars
4:55:09 AM: Line 7:3: ‘SiVercel’ is defined but never used no-unused-vars
4:55:09 AM: src/components/Footer.js
4:55:09 AM: Line 5:3: ‘AiOutlineTwitter’ is defined but never used no-unused-vars
4:55:09 AM: src/components/Home/Home2.js
4:55:09 AM: Line 7:3: ‘AiOutlineTwitter’ is defined but never used no-unused-vars
4:55:09 AM: src/components/Navbar.js
4:55:09 AM: Line 6:8: ‘Button’ is defined but never used no-unused-vars
4:55:09 AM: Line 8:10: ‘CgGitFork’ is defined but never used no-unused-vars
4:55:09 AM: Line 9:10: ‘ImBlog’ is defined but never used no-unused-vars
4:55:09 AM: Line 11:3: ‘AiFillStar’ is defined but never used no-unused-vars
4:55:09 AM: src/components/Projects/Projects.js
4:55:09 AM: Line 6:8: ‘emotion’ is defined but never used no-unused-vars
4:55:09 AM:
4:55:09 AM: “build.command” failed
4:55:09 AM: ────────────────────────────────────────────────────────────────
4:55:09 AM:
4:55:09 AM: Error message
4:55:09 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
4:55:09 AM:
4:55:09 AM: Error location
4:55:09 AM: In Build command from Netlify app:
4:55:09 AM: npm run build
4:55:09 AM:
4:55:09 AM: Resolved config
4:55:09 AM: build:
4:55:09 AM: command: npm run build
4:55:09 AM: commandOrigin: ui
4:55:09 AM: publish: /opt/build/repo/build
4:55:11 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
4:55:09 AM: publishOrigin: ui
4:55:10 AM: Caching artifacts
4:55:10 AM: Started saving node modules
4:55:10 AM: Finished saving node modules
4:55:10 AM: Started saving build plugins
4:55:10 AM: Finished saving build plugins
4:55:10 AM: Started saving corepack cache
4:55:10 AM: Finished saving corepack cache
4:55:10 AM: Started saving pip cache
4:55:10 AM: Finished saving pip cache
4:55:10 AM: Started saving emacs cask dependencies
4:55:10 AM: Finished saving emacs cask dependencies
4:55:10 AM: Started saving maven dependencies
4:55:10 AM: Finished saving maven dependencies
4:55:10 AM: Started saving boot dependencies
4:55:10 AM: Finished saving boot dependencies
4:55:10 AM: Started saving rust rustup cache
4:55:10 AM: Finished saving rust rustup cache
4:55:10 AM: Started saving go dependencies
4:55:10 AM: Finished saving go dependencies
4:55:11 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
4:55:11 AM: Failing build: Failed to build site
4:55:11 AM: Finished processing build request in 1m6.562s
@ishan Your build is throwing warnings, the default behaviour is that warnings cause the build to fail.
If you do not want this, and want to leave your warnings unfixed, you need to set CI to false.
This can be most easily done by changing your build command from npm run build to CI= npm run build.
You can see that it actually tells you about it in the log:
Hi @nathanmartin . Thanks for your reply. The issue is now resolved!
