9:29:27 PM: build-image version: 50f2c07b4ff67fac131b5b345ef7efb7e0ab9dac (focal)
9:29:27 PM: buildbot version: c9f4d14116ab42444eec6254675aa913b9cd89ec
9:29:27 PM: Fetching cached dependencies
9:29:27 PM: Failed to fetch cache, continuing with build
9:29:27 PM: Starting to prepare the repo for build
9:29:28 PM: No cached dependencies found. Cloning fresh repo
9:29:28 PM: git clone --filter=blob:none git@github.com:slashplusdash/SolanaDapp-project
9:29:28 PM: Preparing Git Reference refs/heads/cli-start
9:29:30 PM: Starting to install dependencies
9:29:30 PM: Python version set to 3.8
9:29:30 PM: Attempting Ruby version 2.7.2, read from environment
9:29:31 PM: Using Ruby version 2.7.2
9:29:31 PM: Started restoring cached go cache
9:29:31 PM: Finished restoring cached go cache
9:29:31 PM: go version go1.19.13 linux/amd64
9:29:31 PM: Using PHP version 8.0
9:29:32 PM: v18.18.2 is already installed.
9:29:33 PM: Now using node v18.18.2 (npm v9.8.1)
9:29:33 PM: Enabling Node.js Corepack
9:29:33 PM: Started restoring cached build plugins
9:29:33 PM: Finished restoring cached build plugins
9:29:33 PM: Started restoring cached corepack dependencies
9:29:33 PM: Finished restoring cached corepack dependencies
9:29:33 PM: Started restoring cached yarn cache
9:29:33 PM: Finished restoring cached yarn cache
9:29:33 PM: No yarn workspaces detected
9:29:33 PM: Started restoring cached node modules
9:29:33 PM: Finished restoring cached node modules
9:29:33 PM: Installing npm packages using Yarn version 1.22.19
9:29:34 PM: yarn install v1.22.19
9:29:34 PM: [1/4] Resolving packages…
9:29:34 PM: [2/4] Fetching packages…
9:29:36 PM: [3/4] Linking dependencies…
9:29:36 PM: warning " > ts-mocha@8.0.0" has incorrect peer dependency “mocha@^3.X.X || ^4.X.X || ^5.X.X || ^6.X.X || ^7.X.X || ^8.X.X”.
9:29:36 PM: [4/4] Building fresh packages…
9:29:37 PM: Done in 3.38s.
9:29:37 PM: npm packages installed using Yarn
9:29:38 PM: Successfully installed dependencies
9:29:38 PM: Starting build script
9:29:38 PM: Detected 0 framework(s)
9:29:38 PM: Section completed: initializing
9:29:40 PM:
9:29:40 PM: Netlify Build
9:29:40 PM: ────────────────────────────────────────────────────────────────
9:29:40 PM:
9:29:40 PM: ❯ Version
9:29:40 PM: @netlify/build 29.24.3
9:29:40 PM:
9:29:40 PM: ❯ Flags
9:29:40 PM: baseRelDir: true
9:29:40 PM: buildId: 654252902056c30008dd83d4
9:29:40 PM: deployId: 654252902056c30008dd83d6
9:29:40 PM:
9:29:40 PM: ❯ Current directory
9:29:40 PM: /opt/build/repo
9:29:40 PM:
9:29:40 PM: ❯ Config file
9:29:40 PM: /opt/build/repo/netlify.toml
9:29:40 PM:
9:29:40 PM: ❯ Context
9:29:40 PM: production
9:29:40 PM:
9:29:40 PM: ❯ Installing plugins
9:29:40 PM: - @netlify/plugin-nextjs@4.41.1
9:29:49 PM:
9:29:49 PM: ❯ Using Next.js Runtime - v4.41.1
9:29:50 PM:
9:29:50 PM: @netlify/plugin-nextjs (onPreBuild event)
9:29:50 PM: ────────────────────────────────────────────────────────────────
9:29:50 PM:
9:29:50 PM: No Next.js cache to restore.
9:29:50 PM: Netlify configuration property “build.environment.NEXT_PRIVATE_TARGET” value changed.
9:29:51 PM:
9:29:51 PM: (@netlify/plugin-nextjs onPreBuild completed in 55ms)
9:29:51 PM:
9:29:51 PM: build.command from netlify.toml
9:29:51 PM: ────────────────────────────────────────────────────────────────
9:29:51 PM:
9:29:51 PM: $ yarn run build
9:29:51 PM: yarn run v1.22.19
9:29:51 PM: $ yarn build
9:29:52 PM: $ yarn build
9:29:53 PM: $ yarn build
9:29:54 PM: $ yarn build
9:29:55 PM: $ yarn build
9:29:56 PM: $ yarn build
9:29:57 PM: $ yarn build
9:29:58 PM: $ yarn build
9:29:59 PM: $ yarn build
9:30:00 PM: $ yarn build
9:30:01 PM: $ yarn build
9:30:02 PM: $ yarn build
9:30:03 PM: $ yarn build
9:30:04 PM: $ yarn build
9:30:05 PM: $ yarn build
9:30:06 PM: $ yarn build
9:30:07 PM: $ yarn build
9:30:08 PM: $ yarn build
9:30:09 PM: $ yarn build
9:30:10 PM: $ yarn build
9:30:11 PM: $ yarn build
9:30:12 PM: $ yarn build
9:30:13 PM: $ yarn build
9:30:14 PM: $ yarn build
9:30:15 PM: $ yarn build
9:30:16 PM: $ yarn build
9:30:18 PM: /opt/build-bin/build: line 132: 3834 Killed FORCE_COLOR=1 “$netlify_build_node_bin” “$netlify_build_bin” --cwd=“$repository_root” --repositoryRoot=“$repository_root” --packagePath=“$package_path” --config=“$configuration_file_path” --branch=“$branch” --siteId=“$site_id” --defaultConfig=“$default_config” --baseRelDir=“$base_rel_dir” --context=“$context” --node-path=“$user_node_path” --cachedConfigPath=“$cached_netlify_build_config_file” --api-host=“$netlify_endpoint” --token=“$netlify_token” --build-id=“$BUILD_ID” --deploy-id=“$DEPLOY_ID” --mode=“buildbot” --telemetry=“$build_telemetry” --send-status --save-config --statsd.host=“$HOST_NODE_IP” --statsd.port=“$STATSD_PORT” --tracing.enabled=“$tracing_enabled” --tracing.sampleRate=“$tracing_sample_rate” --tracing.host=“$HOST_NODE_IP” --tracing.traceId=“$trace_id” --tracing.parentSpanId=“$parent_span_id” --tracing.traceFlags=“$trace_flags” --tracing.baggageFilePath=“$tracing_baggage_file_path” --functions-dist-dir=“$functions_dist_dir” --edge-functions-dist-dir=“$edge_functions_dist_dir” --cache-dir=“$cache_dir” --buildbot-server-socket=“$buildbot_server_socket” --framework=“$framework” --feature-flags=“$feature_flags” --testOpts.silentLingeringProcesses=“$SILENT_LINGERING_PROCESSES” --system-log-file=“$system_log_file” --explicit-secret-keys=“$explicit_secret_keys”
9:30:19 PM: $ yarn build
9:30:20 PM: $ yarn build
9:30:40 PM: Build exceeded memory limits
HELP ME
