Hi,
I tried to deploy my app thousands time however always getting same error:
6:12:21 PM: $ npm run build
6:12:21 PM: > project@0.1.0 build
6:12:21 PM: > next build
6:12:22 PM:
No build cache found. Please configure build caching for faster rebuilds. Read more: No Cache Detected | Next.js
6:12:22 PM: ▲ Next.js 14.1.0
6:12:22 PM: Creating an optimized production build …
6:12:31 PM: ✓ Compiled successfully
6:12:31 PM: Skipping linting
6:12:31 PM: Checking validity of types …
6:12:34 PM: Failed to compile.
6:12:34 PM:
6:12:34 PM: ./components/ui/calendar.tsx:5:27
6:12:34 PM: Type error: Cannot find module ‘react-day-picker’ or its corresponding type declarations.
6:12:34 PM: 3 | import * as React from ‘react’;
6:12:34 PM: 4 | import { ChevronLeft, ChevronRight } from ‘lucide-react’;
6:12:34 PM: > 5 | import { DayPicker } from ‘react-day-picker’;
6:12:34 PM: | ^
6:12:34 PM: 6 |
6:12:34 PM: 7 | import { cn } from ‘@/lib/utils’;
6:12:34 PM: 8 | import { buttonVariants } from ‘@/components/ui/button’;
6:12:34 PM:
6:12:34 PM: “build.command” failed
6:12:34 PM: ────────────────────────────────────────────────────────────────
6:12:34 PM:
6:12:34 PM: Error message
6:12:34 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
6:12:34 PM:
6:12:34 PM: Error location
6:12:34 PM: In Build command from Netlify app:
6:12:34 PM: npm run build
6:12:34 PM:
6:12:34 PM: Resolved config
6:12:34 PM: build:
6:12:34 PM: command: npm run build
6:12:34 PM: commandOrigin: ui
6:12:34 PM: publish: /opt/build/repo/public
6:12:34 PM: publishOrigin: ui
6:12:34 PM: plugins:
6:12:34 PM: - inputs: {}
6:12:34 PM: origin: ui
6:12:34 PM: package: ‘@netlify/plugin-nextjs’
6:12:35 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
6:12:35 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
6:12:35 PM: Failing build: Failed to build site
6:12:35 PM: Finished processing build request in 37.708s
anyone can help me?
