I have a react front-end and a node.js back-end which seem to build successfully, but then the build bot times out.
Site:
https://sharp-roentgen-464a66.netlify.app/
Build Settings:
Build Log:
3:20:45 PM: Build ready to start
3:20:47 PM: build-image version: 3031d4c9e432fd7016f6279fc9ad706f9205d845
3:20:47 PM: build-image tag: v3.3.17
3:20:47 PM: buildbot version: 1f35b3abd6e2bf5230d8edf68072840fdec1513f
3:20:47 PM: Fetching cached dependencies
3:20:47 PM: Failed to fetch cache, continuing with build
3:20:47 PM: Starting to prepare the repo for build
3:20:47 PM: No cached dependencies found. Cloning fresh repo
3:20:47 PM: git clone https://github.com/ryanxgraham/itg
3:20:48 PM: Preparing Git Reference refs/heads/master
3:20:52 PM: Starting build script
3:20:52 PM: Installing dependencies
3:20:52 PM: Python version set to 2.7
3:20:53 PM: Downloading and installing node v14.2.0...
3:20:53 PM: Downloading https://nodejs.org/dist/v14.2.0/node-v14.2.0-linux-x64.tar.xz...
3:20:54 PM: Computing checksum with sha256sum
3:20:54 PM: Checksums matched!
3:20:58 PM: Now using node v14.2.0 (npm v6.14.4)
3:20:58 PM: Started restoring cached build plugins
3:20:58 PM: Finished restoring cached build plugins
3:20:58 PM: Attempting ruby version 2.7.1, read from environment
3:21:00 PM: Using ruby version 2.7.1
3:21:00 PM: Using PHP version 5.6
3:21:00 PM: 5.2 is already installed.
3:21:00 PM: Using Swift version 5.2
3:21:00 PM: Started restoring cached node modules
3:21:00 PM: Finished restoring cached node modules
3:21:00 PM: Installing NPM modules using NPM version 6.14.4
3:21:06 PM: npm notice created a lockfile as package-lock.json. You should commit this file.
3:21:06 PM: added 54 packages from 44 contributors and audited 54 packages in 5.028s
3:21:06 PM: 3 packages are looking for funding
3:21:06 PM: run `npm fund` for details
3:21:06 PM: found 0 vulnerabilities
3:21:06 PM: NPM modules installed
3:21:07 PM: Started restoring cached go cache
3:21:07 PM: Finished restoring cached go cache
3:21:07 PM: go version go1.14.4 linux/amd64
3:21:07 PM: Installing missing commands
3:21:07 PM: Verify run directory
3:21:08 PM:
3:21:08 PM: ┌─────────────────────────────┐
3:21:08 PM: │ Netlify Build │
3:21:08 PM: └─────────────────────────────┘
3:21:08 PM:
3:21:08 PM: ❯ Version
3:21:08 PM: @netlify/build 2.0.10
3:21:08 PM:
3:21:08 PM: ❯ Flags
3:21:08 PM: deployId: 5ef3afe9a9fa060007fbd4e6
3:21:08 PM: mode: buildbot
3:21:08 PM:
3:21:08 PM: ❯ Current directory
3:21:08 PM: /opt/build/repo
3:21:08 PM:
3:21:08 PM: ❯ Config file
3:21:08 PM: No config file was defined: using default values.
3:21:08 PM:
3:21:08 PM: ❯ Context
3:21:08 PM: production
3:21:08 PM:
3:21:08 PM: ┌────────────────────────────────┐
3:21:08 PM: │ 1. Build command from settings │
3:21:08 PM: └────────────────────────────────┘
3:21:08 PM:
3:21:08 PM: $ npm run prod
3:21:08 PM: > itg@0.1.0 prod /opt/build/repo
3:21:08 PM: > concurrently "npm install" "npm run backendBuild" "npm run frontendBuild"
3:21:09 PM: [1]
3:21:09 PM: [1] > itg@0.1.0 backendBuild /opt/build/repo
3:21:09 PM: [1] > cd backend && npm install && npm run build
3:21:09 PM: [1]
3:21:09 PM: [2]
3:21:09 PM: [2] > itg@0.1.0 frontendBuild /opt/build/repo
3:21:09 PM: [2] > cd frontend && npm install && npm run build
3:21:09 PM: [2]
3:21:11 PM: [0] audited 54 packages in 1.41s
3:21:11 PM: [0]
3:21:11 PM: [0] 3 packages are looking for funding
3:21:11 PM: [0] run `npm fund` for details
3:21:11 PM: [0]
3:21:11 PM: [0] found 0 vulnerabilities
3:21:11 PM: [0]
3:21:11 PM: [0] npm install exited with code 0
3:21:17 PM: [2] npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
3:21:17 PM: [2] npm WARN deprecated @types/testing-library__dom@7.5.0: This is a stub types definition. testing-library__dom provides its own type definitions, so you do not need this installed.
3:21:18 PM: [2] npm WARN deprecated rollup-plugin-babel@4.4.0: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-babel.
3:21:19 PM: [1] npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
3:21:20 PM: [1] npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
3:21:20 PM: [1] npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
3:21:20 PM: [1] npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
3:21:23 PM: [2] npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
3:21:24 PM: [2] npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
3:21:29 PM: [2] npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
3:21:30 PM: [2] npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
3:21:33 PM: [1]
3:21:33 PM: [1] > nodemon@2.0.4 postinstall /opt/build/repo/backend/node_modules/nodemon
3:21:33 PM: [1] > node bin/postinstall || exit 0
3:21:33 PM: [1]
3:21:33 PM: [1] Love nodemon? You can now support the project via the open collective:
3:21:33 PM: [1] > https://opencollective.com/nodemon/donate
3:21:33 PM: [1]
3:21:34 PM: [1] npm notice created a lockfile as package-lock.json. You should commit this file.
3:21:34 PM: [1] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
3:21:34 PM: [1] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:21:34 PM: [1] npm WARN notsup Unsupported engine for watchpack-chokidar2@2.0.0: wanted: {"node":"<8.10.0"} (current: {"node":"14.2.0","npm":"6.14.4"})
3:21:34 PM: [1] npm WARN notsup Not compatible with your version of node/npm: watchpack-chokidar2@2.0.0
3:21:34 PM: [1] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/watchpack-chokidar2/node_modules/chokidar/node_modules/fsevents):
3:21:34 PM: [1] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:21:34 PM: [1] npm WARN The package webpack is included as both a dev and production dependency.
3:21:34 PM: [1]
3:21:34 PM: [1] added 517 packages from 261 contributors and audited 569 packages in 23.34s
3:21:34 PM: [1]
3:21:34 PM: [1] 13 packages are looking for funding
3:21:34 PM: [1] run `npm fund` for details
3:21:34 PM: [1]
3:21:34 PM: [1] found 0 vulnerabilities
3:21:34 PM: [1]
3:21:35 PM: [1]
3:21:35 PM: [1] > nodetest1@0.0.0 build /opt/build/repo/backend
3:21:35 PM: [1] > webpack --config webpack.config.js
3:21:35 PM: [1]
3:21:35 PM: [1] One CLI for webpack must be installed. These are recommended choices, delivered as separate packages:
3:21:35 PM: [1] - webpack-cli (https://github.com/webpack/webpack-cli)
3:21:35 PM: [1] The original webpack full-featured CLI.
3:21:35 PM: [1] We will use "npm" to install the CLI via "npm install -D".
3:21:36 PM: [1] Do you want to install 'webpack-cli' (yes/no): npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
3:21:38 PM: [2] npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
3:22:14 PM: [2]
3:22:14 PM: [2] > core-js@2.6.11 postinstall /opt/build/repo/frontend/node_modules/babel-runtime/node_modules/core-js
3:22:14 PM: [2] > node -e "try{require('./postinstall')}catch(e){}"
3:22:14 PM: [2]
3:22:14 PM: [2] Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
3:22:14 PM: [2]
3:22:14 PM: [2] The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
3:22:14 PM: [2] > https://opencollective.com/core-js
3:22:14 PM: [2] > https://www.patreon.com/zloirock
3:22:14 PM: [2]
3:22:14 PM: [2] Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
3:22:14 PM: [2]
3:22:14 PM: [2]
3:22:14 PM: [2] > core-js@3.6.5 postinstall /opt/build/repo/frontend/node_modules/core-js
3:22:14 PM: [2]
3:22:14 PM: [2]
3:22:14 PM: [2] > core-js-pure@3.6.5 postinstall /opt/build/repo/frontend/node_modules/core-js-pure
3:22:14 PM: [2]
3:22:14 PM: [2]
3:22:14 PM: [2] > ejs@2.7.4 postinstall /opt/build/repo/frontend/node_modules/ejs
3:22:14 PM: [2] > node ./postinstall.js
3:22:14 PM: [2]
3:22:14 PM: [2] Thank you for installing EJS: built with the Jake JavaScript build tool (https://jakejs.com/)
3:22:14 PM: [2]
3:22:15 PM: [2]
3:22:15 PM: [2] > nodemon@2.0.4 postinstall /opt/build/repo/frontend/node_modules/nodemon
3:22:15 PM: [2] > node bin/postinstall || exit 0
3:22:15 PM: [2]
3:22:17 PM: [2] npm notice created a lockfile as package-lock.json. You should commit this file.
3:22:17 PM: [2] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
3:22:17 PM: [2] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:22:17 PM: [2] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/react-scripts/node_modules/fsevents):
3:22:17 PM: [2] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:22:17 PM: [2] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/jest-haste-map/node_modules/fsevents):
3:22:17 PM: [2] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:22:17 PM: [2] npm WARN notsup Unsupported engine for watchpack-chokidar2@2.0.0: wanted: {"node":"<8.10.0"} (current: {"node":"14.2.0","npm":"6.14.4"})
3:22:17 PM: [2] npm WARN notsup Not compatible with your version of node/npm: watchpack-chokidar2@2.0.0
3:22:17 PM: [2] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/watchpack-chokidar2/node_modules/chokidar/node_modules/fsevents):
3:22:17 PM: [2] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/webpack-dev-server/node_modules/chokidar/node_modules/fsevents):
3:22:17 PM: [2] npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
3:22:17 PM: [2]
3:22:17 PM: [2] added 1788 packages from 832 contributors and audited 1794 packages in 66.272s
3:22:18 PM: [2]
3:22:18 PM: [2] 70 packages are looking for funding
3:22:18 PM: [2] run `npm fund` for details
3:22:18 PM: [2]
3:22:18 PM: [2] found 1 low severity vulnerability
3:22:18 PM: [2] run `npm audit fix` to fix them, or `npm audit` for details
3:22:18 PM: [2]
3:22:18 PM: [2] > itg-frontend@0.1.0 build /opt/build/repo/frontend
3:22:18 PM: [2] > react-scripts build
3:22:18 PM: [2]
3:22:20 PM: [2] Creating an optimized production build...
3:22:49 PM: [2] Compiled with warnings.
3:22:49 PM: [2]
3:22:49 PM: [2] ./src/components/SimfileResults.js
3:22:49 PM: [2] Line 1:17: 'Component' is defined but never used no-unused-vars
3:22:49 PM: [2] Line 10:8: 'List' is defined but never used no-unused-vars
3:22:49 PM: [2] Line 29:5: String prototype is read only, properties should not be added no-extend-native
3:22:49 PM: [2]
3:22:49 PM: [2] ./src/reducers/simfileResults.js
3:22:49 PM: [2] Line 3:10: 'DEFAULT_QUERY_FILTER' is defined but never used no-unused-vars
3:22:49 PM: [2] Line 4:8: 'state' is defined but never used no-unused-vars
3:22:49 PM: [2]
3:22:49 PM: [2] ./src/components/QueryFilters.js
3:22:49 PM: [2] Line 6:10: 'queryFilterPropType' is defined but never used no-unused-vars
3:22:49 PM: [2] Line 8:10: 'Grid' is defined but never used no-unused-vars
3:22:49 PM: [2]
3:22:49 PM: [2] ./src/App.js
3:22:49 PM: [2] Line 8:8: 'Divider' is defined but never used no-unused-vars
3:22:49 PM: [2]
3:22:49 PM: [2] Search for the keywords to learn more about each warning.
3:22:49 PM: [2] To ignore, add // eslint-disable-next-line to the line before.
3:22:49 PM: [2]
3:22:49 PM: [2] File sizes after gzip:
3:22:49 PM: [2]
3:22:49 PM: [2] 105.02 KB build/static/js/2.0bcbe328.chunk.js
3:22:49 PM: [2] 2.52 KB build/static/js/main.542635e8.chunk.js
3:22:49 PM: [2] 962 B build/static/css/main.6ad3e531.chunk.css
3:22:49 PM: [2] 778 B build/static/js/runtime-main.241974cf.js
3:22:49 PM: [2]
3:22:49 PM: [2] The project was built assuming it is hosted at /.
3:22:49 PM: [2] You can control this with the homepage field in your package.json.
3:22:49 PM: [2]
3:22:49 PM: [2] The build folder is ready to be deployed.
3:22:49 PM: [2] You may serve it with a static server:
3:22:49 PM: [2]
3:22:49 PM: [2] npm install -g serve
3:22:49 PM: [2] serve -s build
3:22:49 PM: [2]
3:22:49 PM: [2] Find out more about deployment here:
3:22:49 PM: [2]
3:22:49 PM: [2] bit.ly/CRA-deploy
3:22:49 PM: [2]
3:22:49 PM: [2] npm run frontendBuild exited with code 0
3:50:45 PM: Build exceeded maximum allowed runtime
