Hello,
I’m working on a project using Next.js v15.2.4 and React v18.3.1, and I’m trying to deploy it to Netlify as a statically prerendered site.
The project is structured as a monorepo, and the frontend app is located in the /apps/storefront subdirectory (where ‘apps‘ is a child of the root directory). For deployment, I’ve created a netlify.toml file inside /apps/storefront with the following configuration:
[build]
publish = ".next"
command = "npm run build"
[[plugins]]
package = "@netlify/plugin-nextjs"
I’m using @netlify/plugin-nextjs version 5.13.1.
To deploy the site, I used the Netlify CLI:
Logged in via
netlify login -
Linked the
/apps/storefront/directory to my Netlify project using the appropriateprojectId -
Ran
netlify deploy --prod
Command output logs:
Netlify Build
❯ Version
@netlify/build 35.1.6
❯ Flags
accountId: 6888df82601fb91956133181
packagePath: apps\storefront
❯ Current directory
C:\Users\a.cominelli\Desktop\Blue Reply\ecomm-playground\apps\storefront
❯ Config file
C:\Users\a.cominelli\Desktop\Blue Reply\ecomm-playground\apps\storefront\netlify.toml
❯ Context
production
❯ Using Next.js Runtime - v5.13.1
build.command from netlify.toml
$ npm run build
> storefront@1.0.0 build
> next build
▲ Next.js 15.2.4
- Environments: .env.production
Creating an optimized production build ...
✓ Compiled successfully
./app/[locale]/(checkout)/cart/page.tsx
37:6 Warning: React Hook useEffect has a missing dependency: 'fetchCart'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./app/[locale]/(checkout)/checkout/greetings/page.tsx
33:6 Warning: React Hook useEffect has missing dependencies: 'cartStore' and 'checkoutStore'. Either include them or remove the dependency array. react-hooks/exhaustive-deps
43:6 Warning: React Hook useEffect has a missing dependency: 'getOrder'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./app/[locale]/(checkout)/checkout/page.tsx
54:6 Warning: React Hook useEffect has a missing dependency: 'fetchCart'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
81:6 Warning: React Hook useEffect has a missing dependency: 'checkoutStore'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
85:6 Warning: React Hook useEffect has missing dependencies: 'cart' and 'navigateCheckoutSection'. Either include them or remove the dependency array. react-hooks/exhaustive-deps
./app/[locale]/(rest)/my-account/AddressItem.tsx
26:16 Warning: Function 'AddressItem' has a complexity of 20. Maximum allowed is 8. complexity
./app/[locale]/(rest)/my-account/page.tsx
35:16 Warning: Function 'MyAccountPage' has too many lines (414). Maximum allowed is 150. max-lines-per-function
88:6 Warning: React Hook useEffect has a missing dependency: 'getOrders'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
111:6 Warning: React Hook useEffect has a missing dependency: 'setNotification'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
160:28 Warning: Arrow function has too many lines (223). Maximum allowed is 150. max-lines-per-function
255:14 Warning: Do not nest ternary expressions. no-nested-ternary
341:59 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
355:59 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
368:59 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
./app/[locale]/(rest)/my-account/ShippingInfoTab.tsx
45:27 Warning: Assignments to the 'initialLoadingState' variable from inside React Hook useEffect will be lost after each render. To preserve the value over time, store it in a useRef Hook and keep the mutable value in the '.current' property. Otherwise, you can move this variable directly inside useEffect. react-hooks/exhaustive-deps
118:26 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
154:20 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
./app/[locale]/providers.tsx
8:14 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/cms/CmsBodyRenderer/CmsBodyRenderer.tsx
15:12 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
17:20 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
22:27 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/cms/LivePreview/PagePreviewRenderer.tsx
15:19 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
19:27 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
36:70 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
49:6 Warning: React Hook useCallback has a missing dependency: 'query'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
82:40 Warning: Identifier 'content_type_id' is not in camel case. camelcase
86:30 Warning: Identifier 'content_type_id' is not in camel case. camelcase
./components/cms/LivePreview/PreviewLayerComponent.tsx
11:12 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
20:17 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
37:42 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
38:48 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
49:25 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/cms/NotFound/NotFound.tsx
50:6 Warning: React Hook useEffect has a missing dependency: 'fetchHeaderContent'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./components/cms/Placeholders/PlpPlaceholder.tsx
6:16 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/cms/ProductCarousel/mock.ts
1:27 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/cms/PromoTopBar/PromoBar.tsx
43:6 Warning: React Hook useCallback has missing dependencies: 'locale' and 'variantParam'. Either include them or remove the dependency array. react-hooks/exhaustive-deps
59:6 Warning: React Hook useEffect has a missing dependency: 'fetchFreshContent'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./components/cms/RenderComponent.tsx
41:21 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
56:26 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/external/Analytics.tsx
9:31 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/layout/NavBarTop/NavBarTop.tsx
27:3 Warning: Arrow function has a complexity of 11. Maximum allowed is 8. complexity
./components/layout/NavBarTop/SearchBar.tsx
37:45 Warning: Arrow function has too many lines (199). Maximum allowed is 150. max-lines-per-function
37:45 Warning: Arrow function has a complexity of 16. Maximum allowed is 8. complexity
136:6 Warning: React Hook useEffect has missing dependencies: 'fetchSearchSuggestion' and 'timeoutSearch'. Either include them or remove the dependency array. react-hooks/exhaustive-deps
./components/layout/NavBarTop/SubMenuDesktop.tsx
29:6 Warning: React Hook useEffect has a missing dependency: 'cleanSubLabels'. Either include it or remove the dependency array. If 'cleanSubLabels' changes too often, find the parent component that defines it and wrap that definition in useCallback. react-hooks/exhaustive-deps
88:32 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
89:33 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
./components/layout/NavBarTop/SubMenuMobile.tsx
12:57 Warning: Arrow function has a complexity of 11. Maximum allowed is 8. complexity
./components/layout/types.ts
34:18 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/pages/Content/ContentPage.tsx
85:18 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Atoms/Button/DSButton.tsx
21:18 Warning: Arrow function has a complexity of 14. Maximum allowed is 8. complexity
./components/ui/Atoms/Container/DSContainer.tsx
21:36 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Atoms/Divider/DSDivider.tsx
22:9 Warning: Do not nest ternary expressions. no-nested-ternary
./components/ui/Atoms/Form/DSForm.tsx
9:20 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
9:29 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Atoms/Icons/CountryIcon.tsx
1:20 Warning: Arrow function has too many lines (204). Maximum allowed is 150. max-lines-per-function
./components/ui/Atoms/Image/DSImage.tsx
20:7 Warning: Using `<img>` could result in slower LCP and higher bandwidth. Consider using `<Image />` from `next/image` to automatically optimize images. This may incur additional usage or cost from your provider. See: https://nextjs.org/docs/messages/no-img-element @next/next/no-img-element
./components/ui/Atoms/Input/DSInput.tsx
34:17 Warning: Arrow function has a complexity of 14. Maximum allowed is 8. complexity
./components/ui/Atoms/Loader/DsLoader.tsx
131:13 Warning: Do not nest ternary expressions. no-nested-ternary
./components/ui/Atoms/Select/DsSelect.tsx
33:18 Warning: Arrow function has a complexity of 10. Maximum allowed is 8. complexity
./components/ui/Atoms/Table/DSTable.tsx
38:61 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Atoms/Toggle/DsToggle.tsx
65:18 Warning: Arrow function has a complexity of 13. Maximum allowed is 8. complexity
103:5 Warning: Do not nest ternary expressions. no-nested-ternary
./components/ui/Gallery/PreviewColumn.tsx
30:13 Warning: Using `<img>` could result in slower LCP and higher bandwidth. Consider using `<Image />` from `next/image` to automatically optimize images. This may incur additional usage or cost from your provider. See: https://nextjs.org/docs/messages/no-img-element @next/next/no-img-element
./components/ui/Molecules/Cart/Cart.tsx
34:6 Warning: React Hook useEffect has a missing dependency: 'fetchCart'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./components/ui/Molecules/Checkout/Delivery/DeliverySection.tsx
16:16 Warning: Function 'DeliverySection' has a complexity of 11. Maximum allowed is 8. complexity
82:6 Warning: React Hook useEffect has a missing dependency: 'getShippingMethods'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
89:8 Warning: Do not nest ternary expressions. no-nested-ternary
./components/ui/Molecules/Checkout/Delivery/PickUpSlot.tsx
13:11 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
19:12 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
20:19 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
25:12 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
28:12 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
28:43 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
31:12 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
31:43 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
31:68 Warning: Identifier 'PickUpPoint_Info' is not in camel case. camelcase
./components/ui/Molecules/Checkout/Payment/PaymentSection.tsx
66:6 Warning: React Hook useEffect has a missing dependency: 'getPaymentMethods'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./components/ui/Molecules/Checkout/Shipping/ShippingSection.tsx
54:6 Warning: React Hook useEffect has a missing dependency: 'getShippingMethods'. Either include it or remove the dependency array. react-hooks/exhaustive-deps
./components/ui/Molecules/Scrollable/helper.ts
229:37 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Molecules/Scrollable/Scrollable.tsx
18:37 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
83:55 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
84:26 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Notification/utils.ts
26:12 Warning: Forbidden non-null assertion. @typescript-eslint/no-non-null-assertion
./components/ui/OrderCard/OrderCard.tsx
33:15 Warning: Using `<img>` could result in slower LCP and higher bandwidth. Consider using `<Image />` from `next/image` to automatically optimize images. This may incur additional usage or cost from your provider. See: https://nextjs.org/docs/messages/no-img-element @next/next/no-img-element
./components/ui/Plp/pageManager.ts
20:33 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
40:21 Warning: Arrow function has a complexity of 10. Maximum allowed is 8. complexity
95:37 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
101:21 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Plp/utils.ts
119:9 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
132:9 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Registration/OTPSection.tsx
13:26 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/ui/Registration/PasswordSection.tsx
17:26 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
./components/utils.ts
74:59 Warning: Unexpected any. Specify a different type. @typescript-eslint/no-explicit-any
info - Need to disable some ESLint rules? Learn more here: https://nextjs.org/docs/app/api-reference/config/eslint#disabling-rules
✓ Linting and checking validity of types
✓ Collecting page data
✓ Generating static pages (42/42)
✓ Collecting build traces
✓ Finalizing page optimization
Route (app) Size First Load JS Revalidate Expire
┌ ○ /_not-found 982 B 102 kB
├ ● /[locale] 302 B 454 kB
├ ├ /en-us
├ └ /it-it
├ ● /[locale]/[slug]/[[...params]] 308 B 454 kB
├ ├ /it-it/test-landing-clothing
├ └ /en-us/test-landing-clothing
├ ● /[locale]/cart 6.28 kB 150 kB
├ ├ /en-us/cart
├ └ /it-it/cart
├ ● /[locale]/category/[[...params]] 308 B 454 kB
├ ├ /en-us/category
├ ├ /en-us/category/test-landing-clothing
├ ├ /en-us/category/support
├ └ [+9 more paths]
├ ● /[locale]/checkout 14.1 kB 171 kB
├ ├ /en-us/checkout
├ └ /it-it/checkout
├ ● /[locale]/checkout/greetings 3.33 kB 137 kB
├ ├ /en-us/checkout/greetings
├ └ /it-it/checkout/greetings
├ ● /[locale]/compare 150 B 102 kB
├ ├ /en-us/compare
├ └ /it-it/compare
├ ● /[locale]/error 150 B 102 kB
├ ├ /en-us/error
├ └ /it-it/error
├ ● /[locale]/favourites 8.03 kB 146 kB
├ ├ /en-us/favourites
├ └ /it-it/favourites
├ ● /[locale]/login 8.95 kB 148 kB
├ ├ /en-us/login
├ └ /it-it/login
├ ● /[locale]/maintenance 278 B 102 kB
├ ├ /en-us/maintenance
├ └ /it-it/maintenance
├ ● /[locale]/my-account 11.6 kB 221 kB
├ ├ /en-us/my-account
├ └ /it-it/my-account
├ ● /[locale]/not-found 1.75 kB 455 kB
├ ├ /en-us/not-found
├ └ /it-it/not-found
├ ƒ /[locale]/product/[slug]/[[...params]] 302 B 454 kB
├ ƒ /[locale]/search/[[...params]] 1.31 kB 232 kB
├ ○ /robots.txt 0 B 0 B
└ ○ /sitemap.xml 150 B 102 kB 1h 1y
+ First Load JS shared by all 101 kB
├ chunks/8315-48676a6a61c28026.js 46 kB
├ chunks/87c73c54-ab30adfb0582e2c2.js 53.3 kB
└ other shared chunks (total) 2.17 kB
ƒ Middleware 74.4 kB
○ (Static) prerendered as static content
● (SSG) prerendered as static HTML (uses generateStaticParams)
ƒ (Dynamic) server-rendered on demand
(build.command completed in 2m 25s)
Functions bundling
Packaging Functions from apps\storefront\.netlify\functions-internal directory:
- ___netlify-server-handler\___netlify-server-handler.mjs
(Functions bundling completed in 19.3s)
Edge Functions bundling
Packaging Edge Functions from apps\storefront\.netlify\edge-functions directory:
- ___netlify-edge-handler-middleware
(Edge Functions bundling completed in 7.4s)
Deploying to Netlify
Deploy path: C:\Users\a.cominelli\Desktop\Blue Reply\ecomm-playground\apps\storefront\.next
Configuration path: C:\Users\a.cominelli\Desktop\Blue Reply\ecomm-playground\apps\storefront\netlify.toml
✔ Finished uploading blobs to deploy store
✔ No cached functions were found
✔ Finished hashing
✔ CDN requesting 6 files
✔ Finished uploading 9 assets
✔ Deploy is live!
Netlify Build Complete
(Netlify Build completed in 4m 22.1s)
🚀 Deploy complete
╭─────────────────────────────── ⬥ Production deploy is live ⬥ ────────────────────────────────╮
│ Deployed to production URL: https://ecommerce-accelerator.netlify.app │
│ Unique deploy URL: https://68c17e4535445f4cef16fbbd--ecommerce-accelerator.netlify.app │
Build logs: https://app.netlify.com/projects/ecommerce-accelerator/deploys/68c17e4535445f4cef16fbbd
Function logs: https://app.netlify.com/projects/ecommerce-accelerator/logs/functions
Edge function Logs: https://app.netlify.com/projects/ecommerce-accelerator/logs/edge-functions
The deployment completed successfully, and the site was made available at:
However, visiting this URL results in a 404 error.
Here are a few more technical details:
- My
next.config.jsincludes the following:
module.exports = {
reactStrictMode: true,
output: "standalone",
//... other configuration
I cannot change the
outputsetting from"standalone"to"export". -
I cannot change the app routing or architectural specification.
I’m also unable to share the source code publicly.
Could someone help me understand why I’m encountering this 404 issue despite a successful deployment? Are there additional configurations required for standalone output in a monorepo context when using Netlify?
Any guidance would be greatly appreciated.
Thank you in advance.
