forEach is not a function, and iβm not front-end dev enough to know how to fix this so any help is appreciated!
- Local NextJS build is ok
- Netlify build and deploy is ok
- Netlify CMS fails build on Save Draft
Netlify deloy log failure message
12:03:32 PM: > Build error occurred
12:03:32 PM: TypeError: data.tags.forEach is not a function
12:03:32 PM: at /opt/build/repo/.next/server/pages/tags/[tag].js:39:23
12:03:32 PM: at Array.forEach (<anonymous>)
12:03:32 PM: at getAllTags (/opt/build/repo/.next/server/pages/tags/[tag].js:35:11)
12:03:32 PM: at async getStaticPaths (/opt/build/repo/.next/server/pages/tags/[tag].js:95:18)
12:03:32 PM: at async buildStaticPaths (/opt/build/repo/node_modules/next/dist/build/utils.js:490:31)
12:03:32 PM: at async /opt/build/repo/node_modules/next/dist/build/utils.js:632:119
12:03:32 PM: at async Span.traceAsyncFn (/opt/build/repo/node_modules/next/dist/trace/trace.js:79:20) {
12:03:32 PM: type: 'TypeError'
12:03:32 PM: }
12:03:32 PM: β
12:03:32 PM: build.command failed
12:03:32 PM: βββββββββββββββ
12:03:32 PM: β
12:03:32 PM: Error message
12:03:32 PM: Command failed with exit code 1: npm run build (https://ntl.fyi/exit-code-1)
12:03:32 PM: β
12:03:32 PM: Error location
12:03:32 PM: In Build command from Netlify app:
12:03:32 PM: npm run build
12:03:32 PM: β
12:03:32 PM: Resolved config
12:03:32 PM: build:
12:03:32 PM: command: npm run build
12:03:32 PM: commandOrigin: ui
12:03:32 PM: environment:
12:03:32 PM: - NEXT_PRIVATE_TARGET
12:03:32 PM: publish: /opt/build/repo/.next
12:03:32 PM: publishOrigin: ui
12:03:32 PM: plugins:
12:03:32 PM: - inputs: {}
12:03:32 PM: origin: ui
12:03:32 PM: package: '@netlify/plugin-nextjs'
12:03:33 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:03:33 PM: Failing build: Failed to build site
12:03:33 PM: Finished processing build request in 37.363s
This is my tags.js source
import fs from 'fs'
import matter from 'gray-matter'
import path from 'path'
import { getFiles } from './mdx'
import kebabCase from './utils/kebabCase'
const root = process.cwd()
export async function getAllTags(type) {
const files = await getFiles(type)
let tagCount = {}
// Iterate through each post, putting all found tags into `tags`
files.forEach((file) => {
const source = fs.readFileSync(path.join(root, 'data', type, file), 'utf8')
const { data } = matter(source)
if (data.tags && data.draft !== true) {
data.tags.forEach((tag) => {
const formattedTag = kebabCase(tag)
if (formattedTag in tagCount) {
tagCount[formattedTag] += 1
} else {
tagCount[formattedTag] = 1
return tagCount
