JavaScript Bundle Issues - Netlify Build Breaking Several Hours after Deployment completes
Hi @sid.m, just redeployed the site with a clear cache and it looks like many elements of the site are missing: https://zendine.co, for example no navigation, many images are not loading, no CSS applied to some typography, etc.
Site ID: bf6e14e2-e3b9-498b-a46b-747fb82ad597
Thank you
I am having same issue too.
The site works fine in my local environment, but this morning I deployed it after making a small update to my next.js project.
Afterwards I am experiencing Intermittent 404 Errors and Inconsistent Page Loads
site: https://ualgo.trade/
Hi, we are also having this issue on all our sites built using NextJS ISR - example:
JS bundle does not load and page does not hydrate, menu doesnā€™t work, images donā€™t load etc - customers are complaining. Any clues on what to do to resolve the issue?
Iā€™ve been having this same issue for a week now, but in the last 24h it seems like it has gotten way worse. 50% of our Next.js site deploys are facing this issue.
Iā€™m having the same issue too, for all my deploys :cry:
Couldnā€™t find a work aroundā€¦
Iā€™m having the same issue. Iā€™ve redeployā€™d the site many times and cleared the cache but the issue comes back after 1-2 hours
Yes, we have been experiencing the same since last week. We ran a re-deploy today after above updates from @sid.m but the site has deteriorated even furtherā€¦ none of the pages are rendering properly now, even immediately after build completes.
We have got the same problem from last week, and today it has gotten way worse too. We use v4 next js builder and itā€™s help for us, last 2 hours all pages works without 404 error. Pin an older version of Next.js Runtime to your site
Itā€™s hard to say now if it was the v4 runtime downgrade that fixed it, or if Netlify has deployed a temporary fix in the last ~2 hours.
Hi all - weā€™ve mitigated the issue causing these 404s but in order to clear the outdated cache youā€™ll need to manually purge the cache for the site using the purge API to do so: Caching | Netlify Docs
If youā€™ve done so and are still experiencing issues, please let me know!
Seems to have resolved now after another purge, I will let you know if we run into any further issues over the next few hours
@zendine great to hear, please keep us updated if you see issues arise!
Ok thank you! Appreciate your help resolving this
Weā€™re experiencing a similar issue on our static webpages - js bundle files fail to load resulting in no css being applied to the page
for example, once this webpage is reloaded:
@vegclubmagazine Thanks for providing that information. Did you purge the cache for the site?
I only recently did. Seems to be working now though unsure if that will hold true in the next couple of hours.
I was previously manually clearing the cache and re-deploying to clear the error and that worked for 2 hours until the error reappeared
@vegclubmagazine Please let us know if this issue reappears in the next couple of hours!
The error just occurred again
Same for me, occured again.
@vegclubmagazine It doesnā€™t look like the function you deployed has been called at all - Iā€™d recommend either scheduling that function or making a call to the API directly as laid out here: Caching | Netlify Docs
