Build script returned non-zero exit code: 1
Please follow this:
I found its mostly because you are using old npm/yarn packages
two options to resolve
  1. update the packages
    or if you don’t want to update package version and break something
  2. deploy your locally build folder, so netlify does not get stuck at build stage.
    Build setting to bypass Netlify build process and deploy from github build directory.
Base directory
build
Build command
Not set
Publish directory
Not set
note: don’t gitignore the build directory
Just remember to run “npm run build” before you run git push origin master(or whatever you branch name is)
Hi @inventorDrizzt :wave:t6:, thank you for the feedback! This will help other users who encounter similar issues.
Thanks a lot @millymilly. Your solution worked for me. I installed React copyright with ```
npm install react-copyright-year --save
