Maybe it’s smth with the versions,I don’t know.I removed FB totally for now and all started to work
Hello! I tried the solutions below to fix the issue, but the error still persists:
if (typeof global === undefined) {
globalThis.global = globalThis;
I also tested another approach found here: Netlify Answers:
npm run build && sed -i -e '1iglobalThis.global = globalThis\' ./node_modules/undici/lib/core/connect.js
Unfortunately, neither of these resolved the problem ![]()
3:45:17 PM: build-image version: c3449036692ceba113a2b71302d561bccc8b6156 (focal)
3:45:17 PM: buildbot version: 6e5dfadf0eec598d7c9db5c1e005bfa46b6682c0
3:45:17 PM: Fetching cached dependencies
3:45:17 PM: Starting to download cache of 251.0MB
3:45:19 PM: Finished downloading cache in 1.367s
3:45:19 PM: Starting to extract cache
3:45:22 PM: Finished extracting cache in 3.42s
3:45:22 PM: Finished fetching cache in 4.839s
3:45:22 PM: Starting to prepare the repo for build
3:45:23 PM: Preparing Git Reference pull/105/head
3:45:24 PM: Starting to install dependencies
3:45:25 PM: Started restoring cached mise cache
3:45:25 PM: Finished restoring cached mise cache
3:45:26 PM: mise python@3.13.1 install
3:45:26 PM: mise python@3.13.1 download cpython-3.13.1+20241219-x86_64-unknown-linux-gnu-install_only_stripped.tar.gz
3:45:26 PM: mise python@3.13.1 extract cpython-3.13.1+20241219-x86_64-unknown-linux-gnu-install_only_stripped.tar.gz
3:45:26 PM: mise python@3.13.1 python --version
3:45:26 PM: mise python@3.13.1 Python 3.13.1
3:45:26 PM: mise python@3.13.1 ✓ installed
3:45:26 PM: Python version set to 3.13
3:45:27 PM: Collecting pipenv
3:45:28 PM: Downloading pipenv-2024.4.0-py3-none-any.whl.metadata (19 kB)
3:45:28 PM: Collecting certifi (from pipenv)
3:45:28 PM: Downloading certifi-2024.12.14-py3-none-any.whl.metadata (2.3 kB)
3:45:28 PM: Collecting packaging>=22 (from pipenv)
3:45:28 PM: Downloading packaging-24.2-py3-none-any.whl.metadata (3.2 kB)
3:45:28 PM: Collecting setuptools>=67 (from pipenv)
3:45:28 PM: Downloading setuptools-75.6.0-py3-none-any.whl.metadata (6.7 kB)
3:45:28 PM: Collecting virtualenv>=20.24.2 (from pipenv)
3:45:28 PM: Downloading virtualenv-20.28.1-py3-none-any.whl.metadata (4.5 kB)
3:45:28 PM: Collecting distlib<1,>=0.3.7 (from virtualenv>=20.24.2->pipenv)
3:45:28 PM: Downloading distlib-0.3.9-py2.py3-none-any.whl.metadata (5.2 kB)
3:45:28 PM: Collecting filelock<4,>=3.12.2 (from virtualenv>=20.24.2->pipenv)
3:45:28 PM: Downloading filelock-3.16.1-py3-none-any.whl.metadata (2.9 kB)
3:45:28 PM: Collecting platformdirs<5,>=3.9.1 (from virtualenv>=20.24.2->pipenv)
3:45:28 PM: Downloading platformdirs-4.3.6-py3-none-any.whl.metadata (11 kB)
3:45:28 PM: Downloading pipenv-2024.4.0-py3-none-any.whl (3.0 MB)
3:45:28 PM: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.0/3.0 MB 56.1 MB/s eta 0:00:00
3:45:28 PM: Downloading packaging-24.2-py3-none-any.whl (65 kB)
3:45:28 PM: Downloading setuptools-75.6.0-py3-none-any.whl (1.2 MB)
3:45:28 PM: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 99.6 MB/s eta 0:00:00
3:45:28 PM: Downloading virtualenv-20.28.1-py3-none-any.whl (4.3 MB)
3:45:28 PM: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.3/4.3 MB 196.8 MB/s eta 0:00:00
3:45:28 PM: Downloading certifi-2024.12.14-py3-none-any.whl (164 kB)
3:45:28 PM: Downloading distlib-0.3.9-py2.py3-none-any.whl (468 kB)
3:45:28 PM: Downloading filelock-3.16.1-py3-none-any.whl (16 kB)
3:45:28 PM: Downloading platformdirs-4.3.6-py3-none-any.whl (18 kB)
3:45:28 PM: Installing collected packages: distlib, setuptools, platformdirs, packaging, filelock, certifi, virtualenv, pipenv
3:45:30 PM: Successfully installed certifi-2024.12.14 distlib-0.3.9 filelock-3.16.1 packaging-24.2 pipenv-2024.4.0 platformdirs-4.3.6 setuptools-75.6.0 virtualenv-20.28.1
3:45:31 PM: Attempting Ruby version 2.7.2, read from environment
3:45:31 PM: Using Ruby version 2.7.2
3:45:32 PM: Started restoring cached go cache
3:45:32 PM: Finished restoring cached go cache
3:45:33 PM: go version go1.19.13 linux/amd64
3:45:34 PM: Using PHP version 8.0
3:45:35 PM: Started restoring cached Node.js version
3:45:36 PM: Finished restoring cached Node.js version
3:45:37 PM: v20.18.1 is already installed.
3:45:37 PM: Now using node v20.18.1 (npm v10.8.2)
3:45:37 PM: Enabling Node.js Corepack
3:45:37 PM: Started restoring cached build plugins
3:45:37 PM: Finished restoring cached build plugins
3:45:37 PM: Started restoring cached corepack dependencies
3:45:37 PM: Finished restoring cached corepack dependencies
3:45:37 PM: No npm workspaces detected
3:45:37 PM: Started restoring cached node modules
3:45:37 PM: Finished restoring cached node modules
3:45:37 PM: Installing npm packages using npm version 10.8.2
3:45:37 PM: npm warn using --force Recommended protections disabled.
3:45:39 PM: added 4 packages, removed 9 packages, changed 2 packages, and audited 1054 packages in 1s
3:45:39 PM: 121 packages are looking for funding
3:45:39 PM: run `npm fund` for details
3:45:39 PM: found 0 vulnerabilities
3:45:39 PM: npm notice
3:45:39 PM: npm notice New major version of npm available! 10.8.2 -> 11.0.0
3:45:39 PM: npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.0.0
3:45:39 PM: npm notice To update run: npm install -g npm@11.0.0
3:45:39 PM: npm packages installed
3:45:39 PM: Successfully installed dependencies
3:45:39 PM: Starting build script
3:45:40 PM: Detected 1 framework(s)
3:45:40 PM: "angular" at version "17.3.9"
3:45:40 PM: Section completed: initializing
3:45:42 PM:
3:45:42 PM: Netlify Build
3:45:42 PM: ────────────────────────────────────────────────────────────────
3:45:42 PM:
3:45:42 PM: ❯ Version
3:45:42 PM: @netlify/build 29.58.1
3:45:42 PM:
3:45:42 PM: ❯ Flags
3:45:42 PM: accountId: 5f672f83d18439031d28980e
3:45:42 PM: baseRelDir: true
3:45:42 PM: buildId: 67793b4645c8510008042521
3:45:42 PM: deployId: 67793b4645c8510008042523
3:45:42 PM:
3:45:42 PM: ❯ Current directory
3:45:42 PM: /opt/build/repo
3:45:42 PM:
3:45:42 PM: ❯ Config file
3:45:42 PM: No config file was defined: using default values.
3:45:42 PM:
3:45:42 PM: ❯ Context
3:45:42 PM: deploy-preview
3:45:42 PM:
3:45:42 PM: ❯ Loading plugins
3:45:42 PM: - @netlify/angular-runtime@2.2.1 from Netlify app
3:45:43 PM:
3:45:43 PM: Build command from Netlify app
3:45:43 PM: ────────────────────────────────────────────────────────────────
3:45:43 PM:
3:45:43 PM: $ npm run build && sed -i -e '1iglobalThis.global = globalThis\' ./node_modules/undici/lib/core/connect.js
3:45:43 PM: > unity@0.0.0 build
3:45:43 PM: > ng build
3:45:44 PM: - Building...
3:46:09 PM: Browser bundles
3:46:09 PM: Initial chunk files | Names | Raw size | Estimated transfer size
3:46:09 PM: main-CTEC64GD.js | main | 1.02 MB | 231.18 kB
3:46:09 PM: chunk-CS37UGWO.js | - | 171.06 kB | 41.47 kB
3:46:09 PM: polyfills-EONH2QZO.js | polyfills | 33.73 kB | 11.05 kB
3:46:09 PM: styles-RY6KL75Y.css | styles | 7.95 kB | 2.43 kB
3:46:09 PM: | Initial total | 1.23 MB | 286.14 kB
3:46:09 PM: Lazy chunk files | Names | Raw size | Estimated transfer size
3:46:09 PM: chunk-V2GHIPMZ.js | index-esm | 29 bytes | 29 bytes
3:46:09 PM: Server bundles
3:46:09 PM: chunk-MGUAG26S.mjs | - | 1.49 MB |
3:46:09 PM: server.mjs | server | 1.06 MB |
3:46:09 PM: chunk-EAIOCKTR.mjs | - | 920.09 kB |
3:46:09 PM: chunk-JQHYCQA6.mjs | - | 523.65 kB |
3:46:09 PM: polyfills.server.mjs | polyfills.server | 231.49 kB |
3:46:09 PM: chunk-H6KHSOBK.mjs | - | 2.80 kB |
3:46:09 PM: chunk-W6O7R4GF.mjs | - | 2.25 kB |
3:46:09 PM: render-utils.server.mjs | render-utils.server | 252 bytes |
3:46:09 PM: main.server.mjs | main.server | 207 bytes |
3:46:09 PM: chunk-RH5DZPDL.mjs | xhr2 | 11.79 kB |
3:46:09 PM: chunk-T47DBX76.mjs | index | 121 bytes |
3:46:09 PM: Output location: /opt/build/repo/dist/Unity
3:46:09 PM: Application bundle generation complete. [25.070 seconds]
3:46:09 PM:
3:46:09 PM: (build.command completed in 25.8s)
3:46:09 PM: Writing Angular SSR Edge Function ...
3:46:09 PM:
3:46:09 PM: Edge Functions bundling
3:46:09 PM: ────────────────────────────────────────────────────────────────
3:46:09 PM:
3:46:09 PM: Packaging Edge Functions from .netlify/edge-functions directory:
3:46:09 PM: - angular-ssr
3:46:15 PM: TypeError: Cannot read properties of undefined (reading 'FinalizationRegistry')
3:46:15 PM: at file:///opt/build/repo/dist/Unity/server/chunk-EAIOCKTR.mjs:2:31273
3:46:15 PM: at file:///opt/build/repo/dist/Unity/server/chunk-H6KHSOBK.mjs:2:1052
3:46:15 PM: at file:///opt/build/repo/dist/Unity/server/chunk-EAIOCKTR.mjs:39:10354
3:46:15 PM: at file:///opt/build/repo/dist/Unity/server/chunk-EAIOCKTR.mjs:45:4461
3:46:15 PM: at file:///opt/build/repo/dist/Unity/server/chunk-EAIOCKTR.mjs:94:45
3:46:15 PM:
3:46:15 PM: Bundling of edge function failed
3:46:15 PM: ────────────────────────────────────────────────────────────────
3:46:15 PM:
3:46:15 PM: Error message
3:46:15 PM: Could not load edge function at '/opt/build/repo/.netlify/edge-functions/angular-ssr/angular-ssr.mjs'. More on the Edge Functions API at https://ntl.fyi/edge-api.
3:46:15 PM:
3:46:15 PM: Error location
3:46:15 PM: While bundling edge function
3:46:15 PM:
3:46:15 PM: Resolved config
3:46:15 PM: build:
3:46:15 PM: command: npm run build && sed -i -e '1iglobalThis.global = globalThis\' ./node_modules/undici/lib/core/connect.js
commandOrigin: ui
3:46:15 PM: environment:
3:46:15 PM: - CI
3:46:15 PM: - NPM_FLAGS
3:46:15 PM: - REVIEW_ID
3:46:15 PM: publish: /opt/build/repo/dist/Unity/browser
3:46:15 PM: publishOrigin: ui
3:46:15 PM: plugins:
3:46:15 PM: - inputs: {}
3:46:15 PM: origin: ui
3:46:15 PM: package: '@netlify/angular-runtime'
3:46:15 PM: redirects:
3:46:16 PM: - from: /*
status: 200
to: /index.html
3:46:16 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
3:46:16 PM: Failing build: Failed to build site
3:46:16 PM: Finished processing build request in 58.769s
3:46:16 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
Can you share your repo?
I’ve sent an invite to the repository for hrishikesh-k. Additionally, the changes related to SSR are in the branch.
I’ve asked the devs to take a look.
hey, there is any updates here ?
Hi, did the devs have a chance to look over the error ?
