Whenever I finish my work with visual studio code, and i load It, It looks normal on my local host.
But when i deploy It to netlify, It appears zoomed in(larger) than how It looks. Please help me.
This is how It looks
This is how It looks from my computer
Without knowing what “normal” is when you see it locally, it is hard to say what looks different.
Does it look the same (when view from Netlify) in different browsers, or different? Is it possible you have zoomed your default browser to something other than 100%?
Okay so when I say normal I mean everything is showing, the full display shows from the picture to my words. Example, if i made the font size 25px, It appears 25px.
But when i deployed It to netlify, It don’t show the full screen. The words come out very larger than how i set It up, for example if i put the font size as 25px, on netlify the font size looks like 45px. The full image on my page comes out super. The words come out super large. And because everything is large not everything is fully displayed. Attached is a picture of how my work looks like on netlify. This is how my work looks on from netlify
Yes but the font size is how i wanted It to be. Which is why i said when i opened It from visual studio code It looked the way i wanted It to look like. Now when i downloaded It to netlify the sizes completely changed……
It is not possible to share files via the forums. If you can create a git repository I am happy to take a look.
Do note, that unless you have Asset Optimization enabled Netlify will not modify the HTML, JS, or CSS in a project. If this is enabled (which I don’t believe it is) you can try disabling it.
This is an example of what my work looks like. The right side is how my work looks like when i load It from visual studio code to see It. The left side is how my work looks like after i load It to netlify. Please help. I don’t know what the issue is and It keeps affecting my school grades because my work never comes out the way it’s supposed to do.
Look at how the heading looks very big and the words and the boxes, compared To how It was supposed to look like.
Hello thanks for spotting that out. But it’s the same way even when i open It in different browsers. Initially i thought It was from my computer. But when i submitted the project to class everybody saw the work zoomed in.
