Hello. This is the website that I am having troubles with: [https://sad-murdock-40897c.netlify.app]
Let me give you a brief description of the problem.
I have deployed a Vue.js website from my github repository, master branch. Everything works fine, except the hamburger menu that I have implemented. The hamburger menu icon is a svg img that I have included in the vue component named TheHomePageHeader.vue and to witch I attached a v-on:click handler which is supposed to trigger an overlay menu to display.
On localhost, the hamburger menu works as expected, but on Netlify it doesn’t, despite redoplying the site multiple times, making sure that all the canges are commited to the remote branch from github repository. The hamburger menu icon appears, but when I click on it, nothing happens.
I placed a console.log() in the v-on:click handler function to see if clicking on the hamburger menu enters the handler function at least, and it actually doesn’t, since nothing is printed to the console. It seems that the function the I specified for v-on:click is not executed when required, even though, as I have mentioned, on localhost it works and the message printed to the console appears. I am totally cconfused why is this difference.
I would really appreciate some help, I think I do some tiny mistake that ruins my menu
UPDATE: I attached the v-on:click function to the logo of the page as well, just to test if the problem persists. Unfortunately, it persists. Again, although it works on localhost, on netlify build site it doesn’t print the console.log() and nor triggers the overlay menu
The code for the vue component where this issued occurs (TheHomePageHeader.vue) is:
<template>
<section id='wrapper-the-home-page-header'>
<div id="navigation-bar" class='main-section'>
<img src="../assets/images/logo.svg" alt="">
<nav>
<ul>
<li><a href="#home">Home</a></li>
<li><a href="#de-ce">De ce am nevoie?</a></li>
<li><a href="#ce-presupune">Ce presupune?</a></li>
<li><a href="#documente">Documente</a></li>
<li><a href="#faq">FAQ</a></li>
<li><a href="#contact">Contact</a></li>
</ul>
</nav>
<img src="../assets/images/hamburger-menu-icon.svg" alt="" v-on:click="onHamburgerMenuClick()">
</div>
</section>
<script lang='ts'>
import Vue from 'vue';
import { Component } from 'vue-property-decorator';
import ScrollIndicator from './ScrollIndicator.vue';
@Component({
components: {
ScrollIndicator
export default class TheHomePageHeader extends Vue {
onHamburgerMenuClick() {
console.log(`Opening hamburger menu ${this.$store.state.isOverlayMenuOpen}`);
document.body.scrollTop = 0;
document.documentElement.scrollTop = 0;
this.$store.commit("openOverlayMenu");
<style lang='scss' scoped>
#wrapper-the-home-page-header {
top: 0;
left: 0;
position: fixed;
width: 100%;
z-index: 90;
#navigation-bar {
display: flex;
align-items: center;
height: 10vh;
width: 100%;
background-color: $base-white;
> img {
&:first-of-type {
margin-left: 30vw;
height: 3.7vh;
@media all and (max-width: 1310px) {
margin-left: 0vw;
&:last-of-type{
width: 3rem;
margin-left: auto;
cursor: pointer;
@media all and (min-width: 1310px) {
display: none;
@media all and (max-width: 650px) {
width: 1.9rem;
> h1 {
margin-left: auto;
> nav {
display: none;
margin-left: auto;
> ul {
list-style: none;
display: flex;
> li {
margin-left: 3.5vw;
> a {
text-decoration: none;
color: $base-dark-gray;
font-size: 0.88rem;
