Using esbuild with error in functions
I use functions when reported Error: Runtime exited with error: exit status 129, after debugging found that it is esbuild build method execution error, but did not give task error information, only a 129 error code, please ask me how should I operate to know the specific What should I do to know the exact error message?
I tried to switch to @netlify/esbuild package and the same error was reported
I used to have no problem using the same method, but recently the error occurred after updating the code, but the key is that there is no change in the implementation.
Recovery method: Open the console and slide down to see an /api/build request, which is the error occurred in this interface
Note: I run it correctly on local development and other servers
Can you share your repo or provide a minimal reproduction so we can check what could be happening here?
