Home
Support Forums
Unclear monorepo build settings
My setup is monorepo with 2 different projects under landing-page and my-project folders as shown below:
  /landing-page
  /my-project
They both are build with mkdocs and should be located under the same domain e.g.
example.com/ (landing page + assets and etc.)
example.com/my-project (my project + assets and etc.)
What should be the netlify and mkdocs (does it matter?) configuration in order to achieve it? I feel like missing some general understanding about how it works under the hood.
from documentation:
base directory - directory to change to before starting a build
build command - cmd executed
publish directory - directory that contains the deploy-ready HTML files etc.
I’ve got a problem understanding where the generated static folder will appear in context with document root.
This might help:
