Hi,
I’d like to trigger a branch deploy using a build hook with a trigger_branch
containing a /
but I haven’t been able to successfully run a build so far. I’m using curl and have tried several things like url encoding but it seems Netlify always already encodes the branch name but not decodes it so it never works. Could you advise on how to do this?
CURL command:
curl --location --request POST 'https://api.netlify.com/build_hooks/<hash>?trigger_branch=feature/test-ci&trigger_title=Branch%20test%20deploy'
Results in:
12:42:26 PM: git ref refs/heads/feature/test-ci does not exist or you do not have permission
12:42:26 PM: Failing build: Failed to prepare repo
12:42:26 PM: failed during stage 'preparing repo': git ref refs/heads/feature/test-ci does not exist
Any help is appreciated.
