Your site at www.skymeshdynamics.com works fine over HTTPS, but when you add a trailing dot (www.skymeshdynamics.com.), you get an SSL error instead. You’re noting that this happens across all your Netlify domains and that the HTTP protocol should technically handle this edge case, and you’d like us to look into it.
Related topics
| Topic | Replies | Views | Activity | |
| Verifying domain (another site is using this domain) | 1 | 58 | January 22, 2025 | |
| No ssl certificate althoug dns already served through netlify | 5 | 1631 | December 15, 2021 | |
| SSL certificate stuck provisioning on kashcreative.co.nz (Netlify DNS) | 0 | 25 | June 12, 2026 | |
| Please remove wildcard SSL requirement for fluenceunited.com | 0 | 12 | July 15, 2026 | |
| I need an urgent help on fixing my ssl issue | 5 | 84 | January 12, 2025 |
