SSL provisioning stuck for 8+ days on custom domain popuptech.com.br
Hi Netlify team,
My custom domain popuptech.com.br has been added to Netlify since Aug 21.
DNS is configured correctly:
  • A popuptech.com.br → 75.2.60.5 / 99.83.229.22
  • CNAME www.popuptech.com.br → splendid-lebkuchen-59d65e.netlify.app
DNS has been propagated for over 8 days.
However, Let’s Encrypt SSL provisioning is stuck and my site still shows a certificate mismatch (*.netlify.app).
Could you please reset the SSL provisioning for popuptech.com.br?
Thanks in advance!
Please remove the A record pointing to 99.83.229.22, as it’s incorrect. Once that change propagates, we’ll provision the SSL certificate.
Thank you so much for your help! The issue is now resolved and everything is working perfectly.
Really appreciate your support .
