SSL certificate stuck and won't provision for pazzoclips.com
Hi, I’m having an SSL certificate provisioning issue for pazzoclips.com.
The domain is using Netlify DNS and the DNS records appear to be resolving correctly. I also ran Let’s Debug and the checks passed.
The domain has been configured for more than 24 hours, but Netlify still will not provision the SSL certificate.
I have already retried DNS verification and checked the nameservers and DNS configuration several times.
Netlify site: glowing-starburst-fee97f
Domain: pazzoclips.com
Could someone from Netlify please check whether the certificate provisioning is stuck on the Netlify side or manually reset/retry the certificate issuance?
Title: SSL certificate stuck provisioning for pazzoclips.com — requesting manual backend reset
Hello Netlify Support,
I’m having an ongoing SSL/HTTPS certificate provisioning issue with my custom domain.
Netlify site: glowing-starburst-fee97f.netlify.app
Custom domains: pazzoclips.com and www.pazzoclips.com
DNS verification has passed successfully, and I also tested pazzoclips.com with Let’s Debug, which returned OK with no reported issues.
The SSL certificate still will not provision, and this has continued for more than 24 hours. I have already checked the DNS configuration and do not want to keep changing DNS records that are currently verifying correctly.
Could a Netlify staff member please check the backend certificate provisioning state/queue for this site and perform a manual reset or flush of the certificate state if necessary?
Thank you for your help.
