Netlify Site Name:
brandinglabs.netlify.app
Custom Domain:
brandinglabs.ca
Error Message:
“We could not provision a Let’s Encrypt certificate for your custom domain.”
Steps Taken:
- DNS Configuration Verified:
• A Record for brandinglabs.ca points to 75.2.60.5 (Netlify load balancer IP).
• CNAME for www.brandinglabs.ca points to brandinglabs.netlify.app.
• No AAAA records are present.
• DNSSEC is not enabled (confirmed with registrar).
- Tools Used for Verification:
• DNSChecker.org: Confirms A and CNAME records are propagated globally.
• Let’s Debug: Reports no issues with DNS or SSL provisioning.
• Google DNS Cache Flush: Successfully flushed caches for brandinglabs.ca and www.brandinglabs.ca.
- Retries in Netlify:
• Used Verify DNS Configuration in Site Settings > Domain Management > HTTPS multiple times without success.
- Propagation Time:
• It has been over 48 hours since DNS changes were made.
Screenshots:
- Netlify HTTPS Settings:
- Netlify DNS Settings:
- DNS Verification via External Tools:
Screenshot of DNSChecker Results
Additional Notes:
• The domain uses Netlify DNS, and the nameservers (dns1.p04.nsone.net, etc.) are properly set at the registrar (Netfirms).
• All propagation tools and tests confirm the DNS setup is correct.
• Let’s Encrypt certificate provisioning has not completed despite multiple retries and no visible issues in DNS.
Request:
Could you please investigate why the SSL certificate isn’t being provisioned? If there’s an issue on Netlify’s end, I’d appreciate your guidance or assistance in resolving it.
