Hello,
I am developing on marcoarman-it-prod.netlify.app
and the SSL certificate is not installed there. My settings for the domain marcoarman.it
are how I would like them to be (so no www appears in the browser bar when clicking the url)
But this setup with my DNS records does not work. So to have a functioning website with SSL certificate installed I am trying to copy the setup I have on a different website https://gifted-visvesvaraya-91ac20.netlify.app/
. To copy that setup I need to set www.marcoarman.it
as Primary domain but when I click on the right option the UI tells me “We’re provisioning a certificate for your site, you cannot change custom domains until that process completes”.
It has been like this some for some days. I have run out of ideas about what to do. Is it a bug in Netlify or something wrong in my work?
Thanks!
PS: it would be better to have my website setup with the primary domain as it is in the picture, but I won’t protest if that’s not taken into consideration on this forum because it’s just that my DNS records are wrong
