Home
Support Forums
Sites will not deploy - authentication error?
I’m unable to deploy any site. Each site I create while logged in will only show “Manual deploys only” after connecting it to a Git repo several times. Deploying to Netlify from Github also returns an error, seen below.
I made this particular attempt using this repo: https://github.com/gatsbyjs/gatsby-starter-wordpress-blog
On a potentially related note, I could not use my Netlify account to sign up on the forum due to an “error during authorization”. I did not get more details than this.
Hey there, @dssutanto :wave:
Thanks for reaching out, and welcome to the Netlify Forums. Can you confirm that you have your Github account set up correctly? Are you using Github in a browser, or the github app?
I recommend starting by walking through our Docs and making sure you have the appropriate repository permissions set up.
Solved the issue by disabling my BitDefender antivirus. Making note of this here in case this helps anyone else.
