Hi,
My site is unreachable from Egypt on multiple devices and networks,
but works fine everywhere else.
Site: artandmoreeg.com
Netlify subdomain: artandmore-eg.netlify.app
What I have verified:
- DNS propagation: 100% resolved worldwide (checked on dnschecker.org,
zero failures on the map) - SSL/TLS: active, Let’s Encrypt, issued Sep 11
- Domain management: artandmoreeg.com set as Primary domain,
both apex and www show “Netlify DNS” with green checkmarks - downforeveryoneorjustme.com reports “It’s up”
What happens from Egypt:
- Tested on 3 different phones, on both WiFi and mobile data
- Error: ERR_CONNECTION_ABORTED
- The .netlify.app subdomain also fails the same way
Since the connection is aborted rather than refused or timing out,
it looks like the request reaches your edge but the connection drops.
Could you check whether there is a routing or edge issue affecting
Egyptian ISPs?
Thank you.
