hey there,
I can see this in your build error:
12:43:46 PM: [2/4] Fetching packages...
12:43:46 PM: info There appears to be trouble with your network connection. Retrying...
12:43:49 PM: info There appears to be trouble with your network connection. Retrying...
12:43:53 PM: info There appears to be trouble with your network connection. Retrying...
12:43:56 PM: info There appears to be trouble with your network connection. Retrying...
12:43:59 PM: error An unexpected error occurred: "https://icsrepo.churchofjesuschrist.org/artifactory/api/npm/npm-ics/babel-plugin-extract-import-names/-/babel-plugin-extract-import-names-1.6.1.tgz: getaddrinfo ENOTFOUND icsrepo.churchofjesuschrist.org icsrepo.churchofjesuschrist.org:443".
If you feel sure that the URL for the repo is correct, it may indeed have been a network connection error. I’d empty the deploy cache and try a redeploy in that case.
But it may also be worth rechecking the URL for that package - are you sure that’s correct?
This Common Issue contains a ton of useful debugging tips that is maybe also helpful.
If you are still having problems, please provide as much information as you can on what you have already tried, what your build settings are, your package.json
, etc. Thanks!
