Site works fine on local 3000, but when I deploy to Neflify it does not load the ‘cart’ page as it should. The page flashes on the screen for a second then disappears. Not sure if this is because I need _redirects folder or if it is a router issue. Thanks for your time!
hi there, i see what you are describing.
looking in the console, I see some likely reasons:
something here isn’t quite right. Are you using a development only key in a production environment or similar?
Yes you’re right Perry. I only have sandbox: api key. If I want to go live need to create a different key. Not really looking to go live. Thanks for your help.
