This is the deployment: https://main--securetech-vote.netlify.app/
GitHub Repository: ‘https://github.com/M-lakshan/REACT_sample-voting-webpage’
Deploy Config (untouched):
Runtime: -not set-
Base directory: frontend
Package directory: -not set-
Build command: npm run build
Publish directory: frontend/build
Functions directory: frontend/netlify/functions
Deploy log visibility: Logs are public
Build status: Active
Project builds & runs locally with no issues but when added to the deployment, I’m facing following errors.
- not sure why am I getting a ‘main - -’ keyword right after the ‘https://’ in my URL. (while the Netlify provided URL being: securetech-vote.netlify.app)
- even though the deployment navigated to the index.html (HTML title is visible) my webpage appearing as a blank page.
- no console errors shown by Opera & Firefox but with Chrome I get the following
(have no idea about fixing this console error)
Here is the latest deployment log from Netlify:
12:51:15 PM: Waiting for other deploys from your team to complete. Check the queue: Netlify App
12:51:35 PM: build-image version: 0143b4617dd9b5b3faed2aefa29c54a846e69aae (focal)
12:51:35 PM: buildbot version: 0143b4617dd9b5b3faed2aefa29c54a846e69aae
12:51:35 PM: Fetching cached dependencies
12:51:35 PM: Starting to download cache of 101.7MB
12:51:36 PM: Finished downloading cache in 964ms
12:51:36 PM: Starting to extract cache
12:51:37 PM: Finished extracting cache in 900ms
12:51:37 PM: Finished fetching cache in 1.91s
12:51:37 PM: Starting to prepare the repo for build
12:51:37 PM: Preparing Git Reference refs/heads/main
12:51:38 PM: Custom publish path detected. Proceeding with the specified path: “frontend/public”
12:51:38 PM: Starting to install dependencies
12:51:38 PM: Python version set to 3.8
12:51:39 PM: Attempting Ruby version 2.7.2, read from environment
12:51:39 PM: Using Ruby version 2.7.2
12:51:40 PM: Started restoring cached go cache
12:51:40 PM: Finished restoring cached go cache
12:51:40 PM: go version go1.19.13 linux/amd64
12:51:40 PM: Using PHP version 8.0
12:51:41 PM: Started restoring cached Node.js version
12:51:41 PM: Finished restoring cached Node.js version
12:51:42 PM: v18.18.0 is already installed.
12:51:42 PM: Now using node v18.18.0 (npm v9.8.1)
12:51:42 PM: Enabling Node.js Corepack
12:51:42 PM: Started restoring cached build plugins
12:51:42 PM: Finished restoring cached build plugins
12:51:42 PM: Started restoring cached corepack dependencies
12:51:42 PM: Finished restoring cached corepack dependencies
12:51:42 PM: No npm workspaces detected
12:51:42 PM: Started restoring cached node modules
12:51:42 PM: Finished restoring cached node modules
12:51:42 PM: Installing npm packages using npm version 9.8.1
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-private-methods@7.18.6: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-private-methods instead.
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-private-property-in-object@7.21.11: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-private-property-in-object instead.
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-optional-chaining@7.21.0: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-optional-chaining instead.
12:51:48 PM: npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
12:51:48 PM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use rollup/plugin-terser
12:51:48 PM: npm WARN deprecated w3c-hr-time@1.0.2: Use your platform"s native performance.now() and performance.timeOrigin.
npm WARN deprecated sourcemap-codec@1.4.8: Please use jridgewell/sourcemap-codec instead
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-numeric-separator@7.18.6: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-numeric-separator instead.
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-class-properties@7.18.6: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-class-properties instead.
12:51:48 PM: npm WARN deprecated babel/plugin-proposal-nullish-coalescing-operator@7.18.6: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use babel/plugin-transform-nullish-coalescing-operator instead.
12:51:49 PM: npm WARN deprecated workbox-cacheable-response@6.6.0: workbox-background-sync@6.6.0
12:51:49 PM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
12:51:52 PM: added 1530 packages, and audited 1531 packages in 9s
12:51:52 PM: 245 packages are looking for funding
12:51:52 PM: run npm fund
for details
12:51:52 PM: 6 high severity vulnerabilities
12:51:52 PM: To address all issues (including breaking changes), run:
12:51:52 PM: npm audit fix --force
12:51:52 PM: Run npm audit
for details.
12:51:52 PM: npm packages installed
12:51:53 PM: Site is live
12:51:53 PM: Post processing - redirect rules
12:51:53 PM: Post processing done
12:51:53 PM: Section completed: postprocessing
12:51:53 PM: Starting post processing
12:51:53 PM: Skipping HTML post processing
12:51:53 PM: Post processing - header rules
12:51:53 PM: Install dependencies script success
12:51:53 PM: No build steps found, continuing to publishing
12:51:53 PM: Starting to deploy site from “frontend/public”
12:51:53 PM: Calculating files to upload
12:51:53 PM: 0 new files to upload
12:51:53 PM: 0 new functions to upload
12:51:53 PM: Section completed: deploying
12:51:53 PM: Section completed: building
12:51:54 PM: Uploading Cache of size 101.7MB
12:51:55 PM: Section completed: cleanup
12:51:55 PM: Finished processing build request in 20.113s
