The netlify deploy fails due to a missing script. Yet, the package.json includes the build command, and when executed locally the build succeeds. What am I missing here?
Error Log:
4:15:12 PM: Build ready to start
4:15:17 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
4:15:17 PM: build-image tag: v3.4.1
4:15:17 PM: buildbot version: fcbc7a79f7372e5995cf02954ef19fc48d20c871
4:15:17 PM: Fetching cached dependencies
4:15:17 PM: Failed to fetch cache, continuing with build
4:15:17 PM: Starting to prepare the repo for build
4:15:17 PM: No cached dependencies found. Cloning fresh repo
4:15:17 PM: git clone https://github.com/basti-n/personal-website
4:15:18 PM: Preparing Git Reference refs/heads/master
4:15:19 PM: Starting build script
4:15:19 PM: Installing dependencies
4:15:19 PM: Python version set to 2.7
4:15:20 PM: v12.18.0 is already installed.
4:15:21 PM: Now using node v12.18.0 (npm v6.14.4)
4:15:21 PM: Started restoring cached build plugins
4:15:21 PM: Finished restoring cached build plugins
4:15:21 PM: Attempting ruby version 2.7.1, read from environment
4:15:23 PM: Using ruby version 2.7.1
4:15:23 PM: Using PHP version 5.6
4:15:23 PM: 5.2 is already installed.
4:15:23 PM: Using Swift version 5.2
4:15:23 PM: Started restoring cached node modules
4:15:23 PM: Finished restoring cached node modules
4:15:24 PM: Installing NPM modules using NPM version 6.14.4
4:15:54 PM: > core-js@2.6.10 postinstall /opt/build/repo/node_modules/core-js
4:15:54 PM: > node postinstall || echo "ignore"
4:15:54 PM: > nuxt@2.10.1 postinstall /opt/build/repo/node_modules/nuxt
4:15:54 PM: > opencollective || exit 0
4:15:57 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/watchpack/node_modules/fsevents):
4:15:57 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
4:15:57 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/jest-haste-map/node_modules/fsevents):
4:15:57 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
4:15:57 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
4:15:57 PM: added 1452 packages from 727 contributors and audited 1588 packages in 32.259s
4:15:58 PM: found 41667 vulnerabilities (41607 low, 35 moderate, 25 high)
4:15:58 PM: run `npm audit fix` to fix them, or `npm audit` for details
4:15:58 PM: NPM modules installed
4:15:59 PM: Started restoring cached go cache
4:15:59 PM: Finished restoring cached go cache
4:15:59 PM: go version go1.14.4 linux/amd64
4:15:59 PM: Installing missing commands
4:15:59 PM: Verify run directory
4:16:00 PM:
4:16:00 PM: ┌─────────────────────────────┐
4:16:00 PM: │ Netlify Build │
4:16:00 PM: └─────────────────────────────┘
4:16:00 PM:
4:16:00 PM: ❯ Version
4:16:00 PM: @netlify/build 3.3.0
4:16:00 PM:
4:16:00 PM: ❯ Flags
4:16:00 PM: deployId: 5f3be26f9001354f52c832ed
4:16:00 PM: mode: buildbot
4:16:00 PM:
4:16:00 PM: ❯ Current directory
4:16:00 PM: /opt/build/repo
4:16:00 PM:
4:16:00 PM: ❯ Config file
4:16:00 PM: No config file was defined: using default values.
4:16:00 PM:
4:16:00 PM: ❯ Context
4:16:00 PM: production
4:16:00 PM:
4:16:00 PM: ┌───────────────────────────────────┐
4:16:00 PM: │ 1. Build command from Netlify app │
4:16:00 PM: └───────────────────────────────────┘
4:16:00 PM:
4:16:00 PM: $ npm run build:netlify
4:16:00 PM: npm ERR! missing script: build:netlify
4:16:00 PM: npm ERR! A complete log of this run can be found in:
4:16:00 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-08-18T14_16_00_921Z-debug.log
4:16:00 PM:
4:16:00 PM: │ "build.command" failed │
4:16:00 PM:
4:16:00 PM: Error message
4:16:00 PM: Command failed with exit code 1: npm run build:netlify
4:16:00 PM:
4:16:00 PM: Error location
4:16:00 PM: In Build command from Netlify app:
4:16:00 PM: npm run build:netlify
4:16:00 PM:
4:16:00 PM: Resolved config
4:16:00 PM: build:
4:16:00 PM: command: 'npm run build:netlify'
4:16:00 PM: commandOrigin: ui
4:16:00 PM: publish: /opt/build/repo/public
4:16:01 PM: Caching artifacts
4:16:01 PM: Started saving node modules
4:16:01 PM: Finished saving node modules
4:16:01 PM: Started saving build plugins
4:16:01 PM: Finished saving build plugins
4:16:01 PM: Started saving pip cache
4:16:01 PM: Finished saving pip cache
4:16:01 PM: Started saving emacs cask dependencies
4:16:01 PM: Finished saving emacs cask dependencies
4:16:01 PM: Started saving maven dependencies
4:16:01 PM: Finished saving maven dependencies
4:16:01 PM: Started saving boot dependencies
4:16:01 PM: Finished saving boot dependencies
4:16:01 PM: Started saving go dependencies
4:16:01 PM: Finished saving go dependencies
4:16:04 PM: Error running command: Build script returned non-zero exit code: 1
4:16:04 PM: Failing build: Failed to build site
4:16:04 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1
4:16:04 PM: Finished processing build request in 47.416243212s
Here is my package.json
"name": "personalwebsite",
"description": "My personal Website",
"version": "0.0.1",
"scripts": {
"dev": "sapper dev",
"build": "sapper build --legacy",
"build:netlify": "sapper export && mv ./__sapper__/export ./public",
"export": "sapper export --legacy",
"start": "node __sapper__/build",
"cy:run": "cypress run",
"cy:open": "cypress open",
"test": "run-p --race dev cy:run"
"dependencies": {
"compression": "^1.7.1",
"polka": "next",
"sirv": "^0.4.0",
"sapper": "^0.27.0",
"svelte": "^3.0.0",
"svelte-preprocess": "^3.7.1"
"devDependencies": {
"@babel/core": "^7.0.0",
"@babel/plugin-syntax-dynamic-import": "^7.0.0",
"@babel/plugin-transform-runtime": "^7.0.0",
"@babel/preset-env": "^7.0.0",
"@babel/runtime": "^7.0.0",
"@rollup/plugin-commonjs": "11.0.2",
"@rollup/plugin-json": "^4.1.0",
"@rollup/plugin-node-resolve": "^7.0.0",
"@rollup/plugin-replace": "^2.2.0",
"autoprefixer": "^9.7.6",
"node-sass": "^4.13.1",
"npm-run-all": "^4.1.5",
"rollup": "^1.20.0",
"rollup-plugin-babel": "^4.0.2",
"rollup-plugin-svelte": "^5.0.1",
"rollup-plugin-terser": "^4.0.4"
