Site name: silverbrooksommelier
I’m on the Pro plan and would like to request the synchronous function timeout be increased to 26 seconds for this site.
Context: one of my functions calls the Anthropic API to generate an AI response, and typical execution time is 10-20 seconds depending on the complexity of the request. I’m currently hitting the default 10-second timeout regularly, which causes failed requests for users even though the function completes successfully seconds later (confirmed via function logs).
I understand this isn’t automatic even on Pro and requires a manual increase on your end. Could you please enable the 26-second synchronous timeout for this site?
Happy to provide any additional info (function names, recent invocation IDs, etc.) if that helps.
Thanks for your help.
