Thank you, that makes total sense. I thought the latest A record would overwrite old ones. Turns out it doesn’t. I have updated it now and I’m hoping it will work in a few hours. Thanks for your help
Dear @hillary – sorry to bother you again. I tried adding aliases (simonfreund.com) and this kind of broke the whole thing and now simonfreund.xyz is nor working anymore. I deleted the alisases (simonfreund.com & www.simonfreund.com) but I can’t rewnew the certificate… Your help is much appreciated. Thank you, Simon
Can confirm, @simonfreund , that what Coel describes would absolutely block us from renewing your certificate. If you can remove that AAAA record I think everything will work as you expect.
Thank you so much for looking into this @coelmay & @fool – I have now deleted that AAAA record, hoping the issue will be solved that way. Is there anything else I have to do? Rewnew the certificate once again, for example? THANK YOU – so glad to have your help, I’m just so lost with all of those records : )
